pulsin again!anyone plz help!
Results 1 to 36 of 36
    Mar 2011
    Default Re: pulsin again!anyone plz help!
    sir how can i output the value of a button?? im using a sony tv remote...
    so i guess no way to output the value....
    Dave meant the value of the IRBUTTON variable.
    When developing software, sometimes you want to monitor what's happening INSIDE the PIC. Like Variables, Register, etc. The debatable lazy way is to use Simulator, but it doesn't solve any real life problem. So what many here do, is to send/display variables value on a LCD... or send it serially to your PC using Hyperterminal, MicroCode Studio Serial Communicator OR else so called "Terminal". If you have a PICKIT 2, you can use the built-in terminal utility.
    To me, when you do PIC stuff, you should have at least the following tools:
    1) Serial adapter To send/receive data to/from your PC AND/OR LCD (serial or Parallel)
    2) Logic Analyzer
    3) Scope
    For IR stuff, using a logic analyzer to record the incoming data make the whole thing a real piece of cake. You could also record the data with your PC soundcard with any decent Wav/Audio editor (SoundForge, Audacity, etc). Once you know what kind of signal comes in (or to be expected), it's easier to create/debug your code.
    HTH
    Mar 2011
    oh right thanks let me try it out!
    Mar 2011
    ok i have another question.my code is working the below one.
    as i am very new to pic basic pro i just have one more question and i know that it is a piece of cake for u guys. ok in my code the sensor is on portb.2
    and i am showing the output on portb.5.ok
    the portb.5 is being turned high infinitly when it detects an incoming signal.i want to turn it back low (infinetly)when it detects the signal again and again back high when detects the signal again. can it be done???
    maybe using an ISR?can anyone guide me or help me out???
    '*  Notice  : Copyright (c) 2011 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 5/23/2011                                         *
    'include "ALLDIGITAL.pbp"
    @ DEVICE pic16F877a, WDT_OFF  ' Watchdog Timer
    @ DEVICE pic16F877a, PWRT_OFF  ' Power-On Timer
    @ DEVICE pic16F877a, BOD_OFF  ' Brown-Out Detect
    @ DEVICE pic16F877a, LVP_OFF  ' Low-Voltage Programming
    @ DEVICE pic16F877a, CPD_OFF  ' Data Memory Code Protect
    @ DEVICE pic16F877a, PROTECT_OFF ' Program Code Protection
    @ DEVICE pic16F877a, HS_OSC
    Define OSC 20
    cmcon=2
    Header var word
    Body var word
    i var byte
    tmp var Byte
    irButton var byte
    irDevice var byte
    irIN var PortB.2
    SonyLED var PortB.5
    'TrisA = %00000100
    TrisB = %00000100
    Start:
    LOW SONYLED
    IRBUTTON=255: IRDEVICE=255
    Pulsin irin,0,header
    if header < 1000 or header > 1350 then goto Start
    check:
    for i =0 to 11
    pulsin irin,0,tmp
    if tmp >= 500 then
    Body.0[i]=1 'Sony Logic 1 is 120
    Body.0[i]=0 ' Sony Logic 0 is 60
    next
    IRBUTTON = Body & %01111111
    if IRBUTTON <=9 then
    loop:
    high Sonyled
    goto loop
    goto start
    You could use the INT INT on RB0, I think if you used RBC interrupts the other B pins would interfere, but RB0 has a seperate INT INT interrupt which would be unaffected, but yes and I would use Darrel's instant interrupts
    INCLUDE "DT_INTS-14.bas"
    INT_LIST  macro   ; IntSource,        Label,  Type, ResetFlag?
            INT_Handler    INT_INT,    _YourINTHandler,   ASM,  no
    @   INT_ENABLE   INT_INT     ; enable external (INT) interrupts
    YourINTHandler:
    put your code here . . .
    @  INT_RETURN
    Aug 2010
    Maryland, USA
    No need for interrupts here. First thing to know, outputs will stay in the state you make them until something makes them change. So no need for this:
    loop:
    High sonyled
    Goto loop
    all you need is
    High sonyled. That will keep the led on forever if nothing tells it to turn off. Further in your code, you have trapped the program to never leave the loop.
    Next, if you want to "toggle" the led everytime you get the valid pulse, use
    Toggle sonyled instead of high sonyled.
    Hth.
    -Bert
    Mar 2011
    @ cncmachineguy
    sir it doesnt work because
    the led is high only when IRbutton is detected.... i want to keep it on forever ntil the next command without pressing the button...... is there any way?? maybe a function etc...???
    @archangel
    sir its difficult for me to understand it..the interrupt portion maybe if u could elaborate a little...
    or could point me out to an exmaple program....
