The ****IN command in PBP will handle the timing for you when the correct MODE is selected.
The best I can do at the moment because I have not used the ADC you have is to have you look at the sample I linked you to and compare that to the data sheet of your ADC.
But I have to ask... Why use the external when the 690 has an ADC built in?
