I'm sure you have your reason but can you explain why you need 24bits?
I mean, 100bar across 24bits gives you a resolution of 0.000006bar. Does a transducer capable of measuring 100bar really resolve to that kind of precision?
If you already have your 4-20mA converted to 0-5V (and not 1-5V) you'd get ~0.1bar resolution with the built in 10bit ADC. You could do some oversampling to "emulate" a 12bit ADC giving you ~0.025bar resolution.
Just some ideas.
THANKS FOR YOUR SUGGESTION MR.HENRIK
Actually as you said the 10 bit adc gives a 0.1 resolution on 0~100bar range which is as equal to a "primary master" and thats fine,but i want to use the 24bit adc because i want learn how to communicate a external adc through "spi" to the pic and particularly the 24bit adc is because thats the one i have in my hand to give a try.can you please explain me about the "oversampling to "emulate" a 12bit ADC to give a ~0.025bar resolution"
THANKS A LOT FOR SPENDING YOUR VALUABLE TIME FOR ME.
