Because you are using the Oshonsoft compiler and "we" at this forum are using the MELABS PicBasicPro compiler (or PicBasicCompiler) - not the Oshonsoft BASIC compiler.
You need to "translate" the any examples not written for your compiler so the instructions matches your compilers instruction set. BASIC is not known for being the most standardised programming language. Most i spretty similar in the basic command set like GOTO, GOSUB, FOR-NEXT, WHILE_WEND etc but when it comes to all the "special commands" like SPI, PWM, LCD, etc etc each compiler has it's own way of handling it. There simply is no standard for those type of commands.
A quick look at the Oshonsoft site seems to indicate that what you are looking for is the [url=http://www.oshonsoft.com/picbasiccompilerreferencemanual.html#677] SPI Communication commands. Not ShiftLeft and ShiftRight - they are for shifting bits around in memory, not for shifting them in or out a pin.
Don't worry about beeing new to this, we've all been there at one time or another. However, you may get better help with your project by posting on the forum dedicated for the compiler you are using. Good luck!
Hai brother,
for now i understood the differences among the instruction set on various compiler because of your reply and thanks for that.i want you to suggest me a compiler which will be better for future developments,because i think am still a wet clay and can be shaped.currently my project is communicating a pic16f690 to a external adc(LTC2400),I hope you will support me.THANKS A LOT FOR YOUR FURTHER SUGGESTIONS.
