Most of us here use this to compile
http://store.melabs.com/prod/pbp.html
I am not familiar with oshonsoft compiler. I did not notice that you were using that earlier.
Basically you will have three pins on something like this.
DATA
CLOCK (SCK)
LATCH or Chip Select
i now understood the use of "sck" that it is used to control the serial clk (pin) of the adc,but in the oshonsoft i cant find any command to do that.it simply got spicson and spicsoff to control the "cs" pin of the adc and no more to control the spi clk.please give me a good idea to do my project.As i mentioned above
my project is to communicate the LTC2400 to a pic 16f690 and to display on a 16*2 lcd.The lcd portion working good.THANKS FOR NOW AND THANKS A LOT FOR YOUR FURTHER SUGGESTIONS.
