I would give the PBP demo a try if I were you
http://melabs.com/pbpdemo.htm
thanks for the compiler,but when i bought the pic kit 2 it comes with that compiler.ill try to utilize that.how to handle the timing feature on the adc-LTC2400,do you have any idea?if have then please give me a sample code to get the data from the adc in picbasic.i connected the ltc2400 in 3 wire communication mode.thanks a lot for spending your valuable time with me.
IF YOU BORN POOR ITS NOT BECAUSE OF YOU BUT IF YOU DIE POOR ITS BECAUSE OF YOU.
The ****IN command in PBP will handle the timing for you when the correct MODE is selected.
The best I can do at the moment because I have not used the ADC you have is to have you look at the sample I linked you to and compare that to the data sheet of your ADC.
But I have to ask... Why use the external when the 690 has an ADC built in?
I'm sure you have your reason but can you explain why you need 24bits?
I mean, 100bar across 24bits gives you a resolution of 0.000006bar. Does a transducer capable of measuring 100bar really resolve to that kind of precision?
If you already have your 4-20mA converted to 0-5V (and not 1-5V) you'd get ~0.1bar resolution with the built in 10bit ADC. You could do some oversampling to "emulate" a 12bit ADC giving you ~0.025bar resolution.
Just some ideas.
THANKS FOR YOUR SUGGESTION MR.HENRIK
Actually as you said the 10 bit adc gives a 0.1 resolution on 0~100bar range which is as equal to a "primary master" and thats fine,but i want to use the 24bit adc because i want learn how to communicate a external adc through "spi" to the pic and particularly the 24bit adc is because thats the one i have in my hand to give a try.can you please explain me about the "oversampling to "emulate" a 12bit ADC to give a ~0.025bar resolution"
THANKS A LOT FOR SPENDING YOUR VALUABLE TIME FOR ME.
I'd say learning qualifies as a (very) valid reason ;-) By all means try using the 24bit ADC but perhaps you should start with interfacing to something "easier" like a EEPROM to begin with so you learn the basics about how the SPI interface works. I haven't looked at the datasheet for your ADC though, perhaps it's pretty straight forward.
As for the oversampling, all you really do is take a bunch of readings and then average them. If you take 16 readings with your 10bits ADC, add them all together and divide the result by 4 you'll get a value ranging from 0-4096.
You can read a bit more about here. Note, you can not use that code with Oshonsoft, the theory behind it obviously applies to any language/compiler though.
Good luck!
