PBP projects for R/C models
Results 1 to 40 of 772
    Nov 2009
    Fitchburg, Mass
    Cool No, but I never thought about echoing echos
    I've added a PAUSE of 1/10sec between the front trigger and the side trigger. This noticeably slows down the flashing of the LEDs on the SRF05s. In the audible range I can easily hear echos in a room. I have no experience with ultra-sound in the range that the SRF05 emits. The spec shows a time line in which the pulses seem to be a square wave of 2usec cycles. That is a little burst of 500,000 cycles per second sound that appears to last about 20 usec.
    This little project keeps gets interestinger and interestinger!
    If there were five cars racing near each other on this gymnasium track, would their SRF05's get confused. I don't think so, but I am not sure....
    Ken
    They SURE would. That is what I noted on my previous post. Your sensors are hearing echoes that keep coming long after the transmission stopped. No matter which of the SRF05's did the transmission. Keep note of that.
    Maybe an IR sensor would be more appropriate here. Also faster.
    Nov 2009
    Fitchburg, Mass
    Question A product suggestion would be greatly appreciated.
    If I went with IR proximity sensing, the reflections would be from brick, wood and cardboard. Distance one to five feet should do it. Any suggestions?
    Ken
    I have not used them, but here is one that is within your measurement range GP2Y0A02YK:
    http://sharp-world.com/products/devi...gp2y0a02_e.pdf
    One thing that isn't so good, is that you will get a false reading if you are closer than 8 inches.
    Nov 2009
    Fitchburg, Mass
    Cool Things are not simple any more
    Today I took some cardboard boxes to my gymnasium race track. I arranged them in the middle of the floor about six feet from the walls.
    The car did not behave as expected. It is futile to try to describe what it did. I shall video tape it (probably not for public consumption) and try to analyze what is happening.
    The SRF05 flashing LEDs are constantly illuminated. That should be good.
    My present code has only two 'regular' states.
    1. Going forward being guided by the side looking SRF05. The forward pings are monitored for something close enough to merit turning hard left while still going forward.
    2. Going backward and turning to the right because the front looking pinger sees something too close. The backward state is left by either timing out, or by the forward looking pinger saying that the obstruction is no longer there.
    With the car on blocks and me manipulating a large piece of card board, the wheels move true to concept. In the gym was something else.
    Interesting stuff, real time control code. I made my living in data communication hardware and software development. Nothing actually 'moved' in the common sense of the word.
    Ken
    Nov 2009
    Fitchburg, Mass
    Red face A youtube video. Not very enlightening...
    I made this video of my car on my "race track"
    As I speed up the car the behavior becomes less consistent.
    Take a look see if you like. It's only a couple minutes long and the car does work correctly sometimes.
    Ken
    Nov 2009
    Fitchburg, Mass
    Question I need some help
    I want to use the interrupt system to make my Pulse Width Modulated pulses output at 50hz. I am hoping that will give me finer control of the wheel speed and maybe a quicker steering response.
    I understand that I need to preset TMR1 with a number so that it rolls over every 20 ms. thereby triggering the interrupt. How do I figure out what that preset number should be and how do I set it using PBP?
    Ken
    California, USA
    They're on 2mm (0.079") centers.
    Digikey has a whole variety of them. Here's one flavor with 12 pins, right angle.
    http://search.digikey.com/scripts/Dk...me=S5802-12-ND
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 13:55
    Last Post: - 28th September 2021, 12:26
    Last Post: - 2nd May 2006, 20:01
    Last Post: - 18th December 2005, 00:30
    By forgie in forum General
    Last Post: - 25th October 2005, 17:24
