RF12 module need to convert some C to Basic
Results 1 to 40 of 44
    I really wonder if the skimask's example will work because is the same shiftout command.
    I have also ordered a couple of the modules (the high power ones) but will be delay and cannot test them right now.
    It is the same...
    I think the only difference is toggling the SEL line.
    Dec 2007
    Default nSEL
    Skimask,
    Thankyou for doing that... From the little bit of C that I have learnt in the last 24 hours, that looks good.
    I did try nSEL last night with a couple of code attempts, but I did not try it consistantly.
    I did also try to use the SSP last night for a short period. No luck yet, but I didn't expect it to be easy, I haven't used the SSP yet.
    I am off to work now, but will try again later today.
    Thanks for the assistance.
    It could be a timing issue. No time to check now. If anyone could?
    Dec 2007
    Default word to bit[16]
    I am just getting started on this again tonight...
    I the example from Skimask above, the variable CMD is I assume an array of 16 bits? so I should declare..
    CMD  VAR  bit[16]
    Am I correct?
    My next question is how do I get my word variable into series of 16 bits?
    dout = $D0F7
    for n = 16 to 0 step -1
      CMD[n] = %dout.15
      dout << 1
    next n
    Keep in mind I am almost certain that the above example will not work... It's just to show that I am trying, not just asking everyone else to make my project for me...
    For this CMD[n] = %dout.15 try as:
    CMD.0[n] = %dout.15
    Dec 2007
    Default almost!
    My current attempt is....
    cmd             var byte[15]
    dout = $C0F7
    lcdout $fe,$C0," "
    for n = 16 to 1 step -1
      CMD.0[n] = dout.15
      dout = dout << 1
      lcdout $fe,14,bin dout.15
    next n
    This results in ... 1000000111101110 ... and I want ... 1100000011110111 ...
    i.e. It has chopped the 1 off the start, and added a 0 on the end...
  1. Version Control
    Last Post: - 16th October 2011, 18:12
  2. Loop with two motor and 2 sensors
  3. Replies: 1
    Last Post: - 27th July 2008, 07:14
  4. using AND as an IF statement
    By dw_pic in forum mel PIC BASIC
    Last Post: - 8th June 2006, 19:05
  5. convert Basic Stamp2 (BS2) => Pic
    By bs2rdu in forum mel PIC BASIC Pro
    Last Post: - 15th September 2005, 20:55
