RF12 module need to convert some C to Basic
Results 1 to 40 of 44
    Dec 2007
    Default thankyou
    Thanks mackrackit... I just found that out as you posted...
    Pity no-one has example code of these modules in picbasic.. would make my learning procedure easier...
    Have you just tried to send this binary string with shiftout?
    I think there is not much needed to make it work. Just send the string. Serout will not work here.
    Dec 2007
    Default Shiftout
    Ioannis,
    I have not used shiftout before... I have just tried..
    SCK             var portb.6
    SDO             var portb.7
    shiftout SDO, SCK, 1, [%1100000011110111]
    This did not change the osc... still 1Mhz. Is my syntax ok?
    If you check it with the manual, I understand that you cannot send a binary string that way. You have to use, as with most of the commands, a variable. Either byte or word size defined on top.
    So put the string in two byte variables or a word sized variable and then send it out with shiftout command. Check also if MSB or LSB is needed by the module.
    The 1100000011110111 string is exaclty 16bits.
    Dec 2005
    There is an example on the meLabs website showing how to use the synchronous serial port hardware to read/write from/to an SPI slave (e.g. RF12).Also, here is a link to a BasCOM program written for the RF12. While BasCOM is not PBP and an AVR chip is not a PIC, it should still give you a good understanding of what you need to do.
    Dec 2007
    Default Shiftout
    Ioannis,
    I realised this not long after I posted.. I tried the following with no difference in results..
    dout            var word
    dout = $C0F7
    shiftout SDO, SCK, 1, [dout]
    Tried with the HEX, and the binary values.
    I don't think it matters, but also tried [dout\16]
    Dhouston,
    Thanks for the links, I will study them closely tomorrow.
    Jun 2008
    Varese , Italy
    Default Re: RF12 module need to convert some C to Basic
    Thank for the link.
    The program is written in German... but it is a great help.
    regards,
    Ambrogio
    Jan 2013
    Is this thread still open?
    I would like to ask questions
    Camerart
    Aug 2003
    Nops in this function are a delay. The function (subroutine as you worked out) sends a single zero value out of the SPI bus.
    If you were to set SCK low, and then high again in the very next instruction, the receiving device might miss the signal.
    Especially if the external device runs slower than the transmitting device. You can use @nop in PBP.
    Since there are several flavours of SPI, it would be better to reproduce this then use PBP SHIFTOUT (unless it’s already working).
    They are really only turning two port bits on & off.
    writezero:
    portb.something = 0’ clear SPI data
    portb.something = 0’ clear clock pin, the receiver will look at the value of the SPI data bit now.
    delay
    portb.something = 1’ set the clock pin, the receiver will look for the next bit on the next rising edge (next time you call this function, or the writeone function).
    void Write0( void )
      SDI=0;
      SCK=0;
      NOP();
      NOP();
      NOP();
      NOP();
      NOP();
      NOP();
      NOP();
      NOP();
      NOP();
      NOP();
      NOP();
      NOP();
      NOP();
      NOP();
      NOP();
      NOP();
      SCK=1;
      NOP();
  1. Version Control
    Last Post: - 16th October 2011, 18:12
  2. Loop with two motor and 2 sensors
  3. Replies: 1
    Last Post: - 27th July 2008, 07:14
  4. using AND as an IF statement
    By dw_pic in forum mel PIC BASIC
    Last Post: - 8th June 2006, 19:05
  5. convert Basic Stamp2 (BS2) => Pic
    By bs2rdu in forum mel PIC BASIC Pro
    Last Post: - 15th September 2005, 20:55
