Sequence of statements makes code work differently. (PIC16F628A)
Results 1 to 11 of 11
    Default Sequence of statements makes code work differently. (PIC16F628A)
    Hello,
    below is the super simple code
    SIKO:
    HIGH PORTA.0
    HIGH PORTA.1
    PAUSE 500
    LOW PORTA.0
    LOW PORTA.1
    PAUSE 500
    GOTO SIKO
    There are leds connected to porta.1 and porta.0
    The above code works, but only first line
    If I place at first line code for PORTA.0 it works, but next line, for PORTA.1 does not works. If I swap them, then PORTA.1 will work, but PORTA.0 - not. But if I modify code a bit, to look like this, then it works properly.
    SIKO:
    HIGH PORTA.0
    PAUSE 500
    LOW PORTA.0
    HIGH PORTA.1
    PAUSE 500
    LOW PORTA.1
    GOTO SIKO
    [/code]
    Why this happens?
    I have no TRISA, etc defined, as manual told us, HIGH/LOW statement in PBP does all necessary, so this is why it is so slow, but it appears not to work?
    Bombay, India
    Default Re: Sequence of statements makes code work differently. (PIC16F628A)
    Without seeing your schematic, my guess would be the Read-Modify-Write issue documented in the data sheet. Try to write to PORTA as a whole rather than in bits to confirm this is the issue.
    Resistor-led-pin, that's all
    Strange, and how to write PORTA in whole? like this?
    PORTA=%00000001
    It does not work, even setting PORTA.1=1 does nothing
    Try
    SIKO:
    PORTA=%00000011
    PAUSE 500
    PORTA=%00000000
    PAUSE 500
    GOTO SIKO
    Everybody together now:
    Remember to disable analog functions...
  1. Darrels interrupts and multiple SOUND statements, will it work?
    Last Post: - 26th January 2015, 08:42
  2. Replies: 13
    Last Post: - 10th July 2012, 19:05
  3. LED chaser - Scanner Sequence PIC16F628A
    By izzyblackout in forum Code Examples
    Last Post: - 3rd February 2011, 15:09
  4. Why doesn't this servo code work?
    By artswan in forum mel PIC BASIC Pro
    Last Post: - 5th December 2009, 23:18
  5. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
