RF12 module need to convert some C to Basic
Results 1 to 40 of 44
    Dec 2007
    Default Still not working
    I have just read a very in depth post by Melanie about bits in bytes, and arrays etc...
    I think I understood most of it.. and have changed my code to....
    n		        VAR	BYTE
    nn		        VAR	BYTE
    cmd                            VAR            BYTE[16]
    lcdout $fe,$C0," "
    for n = 15 to 0 step -1
      CMD[n] = dout.15
      lcdout $fe,14,bin dout.15
      dout = dout << 1
    next n
    lcdout $fe,$d4," "
    for nn = 0 to 15
      lcdout $fe,$14,cmd(nn)
    next nn
    However it still doesn't seem to have solved my problem. I am still getting the wierd character in the bottom lcdout array..
    Dec 2007
    Default On the home stretch
    Latest code is...
    Start:
    lcdout $fe,$80,"RFM12B OSC test"
    lcdout $fe,$94,"1MHz to 10Mhz"
    pause 200
    dout = $C0F7
    gosub Writecmd
    goto Start
    WriteCMD:
      CMD[n] = dout.15
      dout = dout << 1
    next n
    lcdout $fe,$c0," "
    SCK = 0
    nSEL = 0
    for nn = 15 to 0 step -1
      if cmd[nn] = 1 then
        gosub write1
        gosub write0
      lcdout $fe,$14,bin cmd[nn]
    next nn
    sck = 0
    nSel = 1
    Write0:
    SDI = 0 : SCK = 0 : pauseus 16 : SCK = 1 : return
    Write1:
    SDI = 1 : SCK = 0 : pauseus 16 : SCK = 1 : return
    This displays the binary that I want to feed to the RF12 on the LCD... However it still has not changed the osc freq of the RF12. Despite being in a loop giving the command over and over...
    Dec 2007
    Default Wooooohooooo
    Ok so it is working... As far as I have set all the initialize registers as per the datasheet example with the exception of the 10MHz clock line, and a 4.5V low battery detect...
    I can now see the clock line change to 10MHz
    Working code is below...
    define osc 4
    DEFINE  LCD_DREG        PORTD            'LCD addressing
    DEFINE  LCD_DBIT        4                'L1 = $80
    DEFINE  LCD_RSREG       PORTD            'L2 = $C0
    DEFINE  LCD_RSBIT       1                'L3 = $94
    DEFINE  LCD_EREG        PORTD            'L4 = $D4
    DEFINE  LCD_EBIT        3
    lcdrw           var portd.2
    nSEL            var portb.4
    SDI             var portb.5
    SCK             var portb.6
    SDO             var portb.7
    dout            var word
    n		        VAR	BYTE
    nn		        VAR	byte
    cmd             var bit[16]
    TRISB = %00000100
    low lcdrw
    nSEL = 1
    SDI = 1
    SCK = 0
    lcdout $fe,1
    Start:
    lcdout $fe,$80,"RFM12B Initialize"
    gosub Init
    goto start
    'Subroutines
    WriteCMD:
      CMD[n] = dout.15
      dout = dout << 1
    next n
    SCK = 0
    nSEL = 0
      if cmd[nn] = 1 then
        gosub write1
        gosub write0
    next nn
    sck = 0
    nSel = 1
    Write0:
    SDI = 0 : SCK = 0 : pauseus 16 : SCK = 1 : pauseus 1 : return
    Write1:
    SDI = 1 : SCK = 0 : pauseus 16 : SCK = 1 : pauseus 1 : return
    Init:
    dout = $80D8                      'enable register, 433MHz, 12.5pf
    gosub Writecmd
    dout = $8208                      'Turn on crystal, !PA
    gosub Writecmd
    dout = $A640
    gosub Writecmd
    dout = $C647
    gosub Writecmd
    dout = $94C0                      'VDI, FAST, 134kHz
    gosub Writecmd
    dout = $C2AC
    gosub Writecmd
    dout = $CA80
    gosub Writecmd
    dout = $CA83                      'FIFO8, SYNC
    gosub Writecmd
    dout = $C49B
    gosub Writecmd
    dout = $9850                      '!mp, 9810=30kHz, Max Out
    gosub Writecmd
    dout = $E000                      'Not Used
    gosub Writecmd
    dout = $C80E                      'Not Used
    gosub Writecmd
    dout = $C0F7                      '10MHZ, 4.5V
    gosub Writecmd
    This has been very painful for me - having not touched RF before, so I'm hopeing that someone else gets some use out of my hair-pulling...
    There is much more to do, I haven't even got round to sending data yet, and I haven't worked out how you are meant to run the pic on the 1MHz clock, then set it to 10Mhz, and have it all work fine. At the moment I have it running on an external 4Mhz crystal.
    When I get a good working TX and RX bit of code I will start a new post with as much info as I can work out...
    Thanks again to all the people that helped me get this far!
    Cheers
    Note to yourself, even though in this case it doesn't matter (because the default OSC is 4), the DEFINE's MUST be in CAPS, either the DEFINE itself, or the parameters, I don't remember which. In my case, I always just put both in caps. Don't have to figure out which one then.
    DEFINE  LCD_EBIT        3
    DEFINE SHIFTPAUSE_US 16
    include "modedefs.bas"
    lcdrw var portd.2:nsel var portb.4:sdi var portb.5:sck var portb.6:sdo var portb.7
    dout var word:trisb=4:lcdrw=0:nsel=1:sdi=1:sck=0:pause 500:lcdout $fe,1
    Start:
    lcdout $fe,$80,"RFM12B Initialize":pause 500:gosub Init:goto start
    WriteCMD:
    nsel = 0 : shiftout sdi , sck , 5 , dout\16 : nsel = 1 : return
    Init:
    for temp = 0 to 12
    lookup temp , [ $80D8 , $8208 , $A640 , $C647 , $94C0 , $C2AC , $CA80 , $CA83 , $C49B , $9850 , $E000 , $C80E , $C0F7 ] , dout
    gosub writecmd
    next temp
    This should do exactly the same thing, but uses the shiftout command. Assuming your original program worked as you wanted it to work....
    Here come the colon again!
    Well, Dave, actually you are running the Oscillator of the PIC at 4MHz, but the core is running at 1MHz (/4).
    If you want the pic running at 10MHz, then you should capitalize the define on top of the program as Skimask stated like this:
    DEFINE OSC 10
    After that, compiler will take care of the rest timing.
    Dec 2007
    Default Osc
    Ioannis...
    I had defined the osc to 10, the problem was that at startup, the RFM12 only puts out a 1Mhz clock signal, and at that speed, it would not initialize the RFM12... Not exactly sure why.. I did some mucking around last night, and have now got it to start on 1Mhz, write to the LCD first, then initialize the RFM12. I'm not sure why but it did not want to do this the other way around.
    I'm glad I am now making progress..
    Let me understand what you are doing. You are clocking the PIC from a 1MHz RFM12 output?
  1. Version Control
    Last Post: - 16th October 2011, 18:12
  2. Loop with two motor and 2 sensors
  3. Replies: 1
    Last Post: - 27th July 2008, 07:14
  4. using AND as an IF statement
    By dw_pic in forum mel PIC BASIC
    Last Post: - 8th June 2006, 19:05
  5. convert Basic Stamp2 (BS2) => Pic
    By bs2rdu in forum mel PIC BASIC Pro
    Last Post: - 15th September 2005, 20:55
