More Powerful LCD Commands
Results 1 to 32 of 32
    Mar 2008
    Sorry i don't follow you could you shed some light on that?
    Why not updating only some fields on the LCD? Do you need Left/Right Aligned thingy?
    if you say this:
    VAR = 1
    LCDOUT $FE, 1, " ", DEC VAR 'three spaces
    you will get on the screen
    >___1< but lets say your variable becomes 100, you will get:
    >___100< i want to get it to say:
    >_100<
    so the first digit of the variable is the "setpoint," and if its one or 5 digits long, the first one will always be in the same place. not too big of a deal, but if you want to run 2 or 3 variables on the screen at the same time (and vary from 1 to 100), then it kinda sucks to program that....
    Quote Originally Posted by reaper0995 View Post
    if you say this:
    VAR = 1
    >_100<
    This is why i asked
    just clear the specific LCD areas where you need to write to.. then yes you must implement some kind of text justification. For that, you'll need to implement a kind of LEN(YourVar) who return the length of your variable, amount of character.
    Think about a simple loop, begin with a variable (says LENof) set to 1. Divide your variable to display by ten.. if the result is still greater increment Lenof variable... loop until your result is still greater than 10. once your done, you know the LENof your variable. Then it's just a matter to use or not REP " "\AmountOfSpace the right way for your text justification.
    That's one way.
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 19:14
  3. Need help with LCD number display.
  4. LCD will not start
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 14:44
