More Powerful LCD Commands
Results 1 to 32 of 32
    Jun 2006
    California
    I know this an old post, but could you elaborate a little more on how one would store strings in an external EEPROM and retrieve them. I can see where this might come in handy when building menus. "HSEROUT" is a little hungry for code space. I did a search on the forum, but nothing jumped out.
    Thanks, David
    Usually i use an external EEPROM to save the strings. As i use always the same routine to display strings, i format my strings to fit directly on the LCD, then, if i have to display results right, left or somewhere esle on the string i use specific structure to store LCD address in the EEPROM or in the program to point directly on the wanted LCD location.
    Using a HEX editor make things easy to figure out how your data will be display on your LCD.
    It's flexible even if it use a bit much EEPROM storage.
    OR, Using another EEPROM structure, you can specify the origine point, the string lenght and do what you need with.
    Quote Originally Posted by DavidK View Post
    Thanks, David
    Use a HEX editor, create your Menus (i used HEXWorkshop from bpsoft), then dump it in your EEPROM with a EEPROM programmer or else fancy method, like a custom PC application which will send the EEPROM dump to your PIC via Rs232 or USB.
    An then, depending your EEPROM you really just need I2CREAD/SHIFTIN then a LCDOUT.
    That's one method, you can also use the following method using the code space.
    http://www.pbpgroup.com/modules/wfse...p?articleid=10
    And there's a load of different version of it in this forum to.
    HTH
    Jun 2006
    California
    Yes I use the embedded strings as part of my Logo Display. Works great BTW.
    I also tried the custom approach and built a HyperTerm interface to an 24LC128 EEPROM, but the problem is viewing all the lines at once or editing a single entry. I will look at your Hex Workshop.
    Thanks for the info
    David
    HTH
    Aug 2003
    A routine very similar to mister_e's could easily be used to centre text to the LCD screen.
    It's almost funny to see such a request of the language itself.
    For a 16 character display, count the length of the message to display, divide that by 2,
    and print the message that many spaces to the left of centre (or 8 minus that figure).
    If you want to print it all to the right, start from 16 (or length of the LCD screen) minus the length of the message.
    To use EEPROM, set a two byte qualifier recognised by your program, then you can count the bytes until
    you reach the next qualifier to gain the length of the message.
    You only need to use the LCDOUT command once in your whole program to send one single variable byte at a time.
    Same with serout, sound, etc. as they can be called from other routines. any more is overkill.
    PBP only includes these routines once in your program, no matter how many times you use them.
    There's no reason why the programmer should do any different.
    Jun 2006
    California
    Art
    Interesting!!
    I may need a little coaching. My goal is to print up a set of instructions, save them as a text file (formatted for screen width), convert to hex then burn to an EEPROM. Calls would be made to EEPROM strings by line number. Not sure this is all possible but nice idea. This could be used for either LCD, RS-232 or USB connections.
    David
    Apr 2008
    Thumbs up 16F84 serial slave code
    OK, two things, 16F84 is rapidly becoming part of history and there is a lot of stock around to use yet. I have a lot of various types of LCD's of the standard 44780 type and it would be great to dedicate several 84's to becoming an 8 bit LCD driver with serial in essentially making it a serial display. Sure, serial displays are common now, but they are still $30 or more and basic 44780 displays are available in surplus outlets for $1. I'd rather save a couple of bytes of mem by using the display in 8 bit mode.
    Second, is the LCDOUT modifiable so that a standardized PIC to LCD pin out can be used? There are about as many ways to wire an LCD as there pins. I like to use B0-B7 and A0-A2 for all 8 bit LCD configurations with 84, 627,628. And, what is the code standard for a serial in LCD module, it gets very confusing out there, everyone has an opinion.
    Move along, these aren't the droids we are looking for
    Check the post 16 on this thread: http://www.picbasic.co.uk/forum/showthread.php?t=4972
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 19:14
  3. Need help with LCD number display.
  4. LCD will not start
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 14:44
