LCD serial backpacks
Results 1 to 40 of 68
Threaded View
    Default LCD serial backpacks
    Hi Everyone,
    It seems as if, . . . the LCD serial backpack device must be the
    Crown Jewels, of PICdome as I have been unable to wrestle suitable
    code out of the internet. Posted below is a modified version of some code
    I found somewhere, probably for a BS1, anyway I tweaked it some and it works after a fashion, but I think it needs something in the way of a buffer
    and some code to make changes on the fly, like does the cursor blink or not
    etc. . . I think it would be way cool to fashion a workable public domain
    serial unit, so newbies and non-newbies have access without forking up $35 bucks for a serial LCD.
    Anyone up to the challange? As I have been coding PIC micros only since 08/06, My coding skills are not there yet, but thanks to you all I am learning.
    Joe
    @ DEVICE pic16F628A, HS_OSC
    @ DEVICE pic16F628A, WDT_ON
    ' Watchdog Timer
    @ DEVICE pic16F628A, PWRT_ON
    ' Power-On Timer
    @ DEVICE pic16F628A, MCLR_ON
    ' Master Clear Options (Internal)
    @ DEVICE pic16F628A, BOD_OFF
    ' Brown-Out Detect
    @ DEVICE pic16F628A, LVP_OFF
    ' Low-Voltage Programming
    @ DEVICE pic16F628A, CPD_OFF
    ' Data Memory Code Protect
    ' Set to CPD_OFF for Development Copy
    ' Set to CPD_ON for Release Copy
    @ DEVICE pic16F628A, PROTECT_OFF
    ' Program Code Protection
    ' Set to PROTECT_OFF for Development Copy
    ' Set to PROTECT_ON for Release Copy
    trisb = %00000001
    trisA = %11110011
    include "modedefs.bas"
    Define LCD_DREG PORTB
    Define LCD_DBIT 4
    Define LCD_RSREG PORTB
    Define LCD_RSBIT 2
    Define LCD_EREG PORTB
    Define LCD_EBIT 3
    DEFINE LCD_LINES 4         'Define using a 2 line LCD
    DEFINE LCD_COMMANDUS 2000    'Define delay time between sending LCD commands
    DEFINE LCD_DATAUS 50     'Define delay time between data sent.
    DEFINE OSC 20
    char Var byte ' Storage for serial character
    CMCON = 7 ' PORTA is digital
    Pause 100 ' Wait for LCD to startup
    high PortA.2 ' power for backlight
    low PortA.3 ' backlight ground
    Lcdout $FE, 1 ' Initialize and clear display
    LCDOUT $FE, $0C
    LCDOUT "My Flash Text"
    pause 800
    Lcdout $FE, 1,$FE, 2
    goto loop
    loop: Serin PORTB.1,N9600,char ' Get a char from serial input
    Lcdout char ' Send char to display
    Goto loop ' Do it all over again
  1. 16f688 LCD what have I done wrong
    Last Post: - 8th August 2009, 20:54
  2. Please help with EDE702 - Serial to LCD interface
    Last Post: - 30th October 2008, 03:48
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  4. Serial LCD
    By Tobias in forum mel PIC BASIC Pro
    Last Post: - 15th November 2007, 09:31
  5. Need help with LCD number display.
    Last Post: - 27th June 2007, 00:07
