Serial LCD
Results 1 to 4 of 4
Thread: Serial LCD
    Default Serial LCD
    First off, I got my ICSP sorted out. Much thanks to the forum. While looking for a few components, I found a serial LCD from my STAMP days. I tried to attach a ZIP file of the spec sheet but it is over the attachment size limit. I thought to myself that this would be pretty handy to debug a new board and/or code. I can insert a few lines of code into my program, solder one wire to a free pin, provide the LCD with 5v and ground, then be sorting out a new program much quicker using this display.
    So I am testing this on a PIC18F4523. I looked up the SerOut command and came up with the following code. I also set the serial LCD up for a baud rate of 9600 using the DIP switches on the back of its housing.
    include "bs2defs.bas"
    define OSC 40
    ADCON1 = 7 ' Set PORTA and PORTE to digital
    LCD var PortA.2
    high LCD
    SEROUT LCD,N9600, ["Grace",10 ] ' Display "Grace"
    The results of the code is just an underscore in the first space on the the first line. I think the underscore is like a default when no data is received though.
    I know one variable is if I am getting the 'mode' correct in the SEROUT command. I have tried the other three X9600 with the same results.
    I would have imagined this would be a pretty easy crossover from STAMP to PIC with this serial LCD. Please clue me in on what I am missing.
    include "modedefs.bas"
    I     con 254 'instruction
    CLR   con 1  'clear screen
    L1  con 128 'line 1
    L2  con 192 'line 2
    L3  con 144 'line 3
    L4  con 208 'line4
    Serout2 LCD,16468,[I,CLR]
    PAUSE   1
    Serout2 LCD,16468,[I,L1,"MACKRACKIT"]
    include "bs2defs.bas"  'DO NOT NEED
    define OSC 40
    LCD var PortA.2
    high LCD                     'DO NOT DO THIS
    			--- Yes needed unless he manually define
    			    the value of N9600
    define OSC 40
    LCD var PortA.2
    		             --- Yes do it for true mode unless
    			        the first character might be screwed up.
    			        with N9600, use LOW instead.  Not
                                    a bad idea to add a few mSec delay after
    And you ADCON1 setting is false, the way you have set it gives...
    AN<12:8> digital
    AN<7:0> analog
    so you want to open the datasheet section 19.0, register 19-2, pdf page 230 and use
    ADCON1=$0F
    <hr>
    In case it doesn't work, there's some missing information here... configuration fuses, crystal speed etc etc (yeah i know 40Mhz is the end results... but PLL or not etc etc).... you know all annoying stuff to post but how much useful for us
    The code I gave works for running the LCD. The things I said are not needed or do not do is if you use the code for the LCD as I gave.
    Sorry for any confusion.
  1. LCD serial backpacks
    By Archangel in forum Serial
    Last Post: - 30th December 2010, 05:51
    Last Post: - 8th August 2009, 20:54
  3. Please help with EDE702 - Serial to LCD interface
    Last Post: - 30th October 2008, 03:48
  4. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  5. Need help with LCD number display.
    Last Post: - 27th June 2007, 00:07
