well, for some esoteric reasons the thing started to work by itself after a few restart... this I hate
I noticed one time i've got one capacitor disconnected on the Xtal... and it seems the PIC woulndt bother?? replugged it live and it kept working.
since I was sending data from a PC, I assume it was regular RS232.
Tried to get data from my PIC heartbeat system(which is using N9600) and as you said this format is not ok as is, text was garbaged. I'll need a max232 one day to invert signal.
In the little time I had to play with the thing, I wondered how I could send data to drive other functions, else than display text?
Can I do custom characters?
clear screen? etc
Another weird thing is that the LCD believe it's second line is the 3rd, when I send a long text. It start filling 1st, then 3rd, then 2nd, and finally 4th one?
anyways I was just sooooo happy to see some text scrolling
BUT, this morning it doesn't wan't to behave again, showing garbage text with the same steup! arg :/
I suspect power problem from my regulator, although it's rated for 1amp.
it's running way too hot when I plug the backlight of this 4lines monster. I guess this may cause some power problems.
Actually, this is what fried my other LCD! PLugged in too many things, the regulator busted and started shooting 10V or so...smoke show B]
for now I just keep doing short tests.
thanks for the infos!
