mister-e , in the "C" psuedo-code give on the link mentioned above ,
This is what i understood so far.
To send any data to the LCD, the "LCDNybble" function has to be called twice with the character / command data in the variable "Nybble".
The Nybble variable should be fed with the corresponding upper and lower bits sequentially.
Does the "LCDNybble" function take care of pulsing the E pin of LCD?
Myke has mentioned that before strobing the E pin, a 450ns pause is necessary.
Will PAUSEUS 1 work?
could you shed some light on that?
