More Powerful LCD Commands
Results 1 to 32 of 32
    Feb 2004
    Germany
    Quote Originally Posted by mister_e
    Fantastic situation to use any of your forgiven or useless PIC. Like PIC16F84, 16C54 etc etc
    Hey Steve, looks like you still have plenty of F84's & C54's on the shelf.
    (Probably even C84's)
    How about RoHS compliance of your stock ;-)
    regards
    Ralph
    HEY RALPH! Well i followed your suggestion a while back (more than 2 years ago) (http://www.picbasic.co.uk/forum/show...88&postcount=7) ... i use them on my pinboard... or as staple
    Reuse
    Old and
    Hassling
    Stock
    C84?
    PS: i know you love'em, so i can send you a few LMAO!
    Jun 2006
    Bangalore, India
    Question
    So how exactly am i suppose to use I2CWRITE or SHIFTOUT to print on LCD using the circuit i had attached earlier ?
    Will i have to do some modification to the circuit or will it directly work if i just send the LCD commands to SHIFTOUT ? ? ?
    Quote Originally Posted by shahidali55 View Post
    That circuit/idea was never designed for I2C, it's always been for SHIFTOUT. I've got one of his books, that's what it says, that's the way it's designed.
    Jun 2006
    Bangalore, India
    Question 2-wire
    Has anyone designed a HD44780 2-wire (or 3-wire) LCD interface?
    Has anyone got an example code in picbasic?
    TX side - SEROUT directly replaces LCDOUT (pick your serial transmit format, i.e. baud rate, parity, etc)
    RX side - SERIN data feeds byte information directly to LCDOUT (again, pick your serial receive format to math the transmit side)
    3 wires - power, ground, serial transmit data
    2 Wire: The master side may use I2CWRITE. On the slave side, you will need to build your OWN I2C routine, using the MSSP or Bit banging. Maybe you could use some part of the following...
    http://www.melabs.com/resources/samp...p/i2cslave.bas
    Still possible to set a PIC USART in Synchronous mode.
    3 wire: The master side may use SHIFTOUT. On the slave side, same rule apply..
    http://www.melabs.com/resources/samp...p/spislave.bas
    To me, a 1 wire solution is more valuable. But if your board already have a I2C bus... it's tempting to use it.
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. Need help with LCD number display.
  4. LCD will not start
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 15:44
