Delay without using pause
Results 1 to 40 of 43
    Aug 2003
    Default Re: Delay without using pause
    It was really just a play... It's not simpler for the Human to read six months later.
    Wherever there's not likely to be a performance problem,
    and thinking of the possibility of having to adjust those constants later,
    I'd avoid the above code like the plague!
    but would personally go for the smaller block directly above that.
    Oct 2009
    That's the thing, I can see the need for tight compact code in a commercial arena where costs etc matter, but for home projects I like things more simpler to follow. As mentioned, it might not be the best way, but if it gets the end result I'm after, and there is little impact on speed then I'm happy. If it means I have to throw an overkill PIC at it to maintain the performance, or to have enough memory to hold my bloated code then so be it
  1. Replies: 6
    Last Post: - 28th October 2014, 07:08
  2. Do I need a pause?
    By tazntex in forum Serial
    Last Post: - 29th August 2008, 05:32
  3. 1 us delay
    By Pedro in forum mel PIC BASIC Pro
    Last Post: - 18th February 2006, 18:28
  4. Pause
    By blue in forum General
    Last Post: - 29th December 2005, 15:24
  5. pause 0.5
    By detail in forum mel PIC BASIC Pro
    Last Post: - 27th June 2005, 12:32
