Delay without using pause
Results 1 to 40 of 43
    Oct 2009
    Default Re: Delay without using pause
    Thanks for the suggestions guys.
    Dave, your suggestions sounds simple enough for me to understand. I guess I could have a variable that is updated every time the program goes around the main loop, then when it reaches a certain value display one set of data for the 1st probe, then when reaches another it displays the second set etc... I'll have a look at implementing that. I guess that provided the program doesn't loop more than 65535 times in 8 seconds then I will be able to use a word variable and each update would be visible for 2 seconds
    Quote Originally Posted by Scampy View Post
    And . . . . if you average several samples of each you would see it displayed longer, side bonus a "flier" reading would not upset you as much when averaged than it will if not averaged or discarded.
    Miami, Florida USA
    Since you are using DT interrupts, another approach would be to use a variable to count every time the program goes to the interrupt routine. After so many hits, then you update the LCD display. Depending on how long you set the time intervals for the interrupts, this might be a "cleaner" solution.
    Anonymous
    Oct 2009
    Guys, thanks for your continued input.
    I've hit a hurdle and it's doing my head in. In the original code the readings from the 4 sensors were displayed constantly on the LCD, so within the main program loop there is a for next loop which runs through and reads the 4 DS18B20's and puts the results into a 4 line array. This results in a fast response in updating the display when temperatures change. Now that I'm also reading an AM2302 and want to display data from that too, the LCD looks cluttered if I follow the same method, hence my idea of displaying the readings from each vivarium on a single line, which would overwrite the values for each vivarium every few seconds. The problem is that if I opt to change this so the for next loop which reads the sensors is changed so that it reads sensor 1 and then goes to a subroutine to display the results for two or three seconds it means that it can take 8 - 12 seconds to go round the loop to read all four sensors, which defeats the object of having fast response times, and in 12 seconds the temp in the vivarium could become dangerously high as this would effect the PID timings.
    I think to only option is to use two 20 x 4 LCD's or one 40 x 4 LCD, or possibly a GLCD
    Jan 2013
    Texas USA
    Can you post a mockup of your display in text and how you use it and how you see using it?
    TABSoft
    Oct 2009
    This was the best match, but I have no room to display the time.
    This is what I'm trying to achieve
    With line 2 being updated with data for Viv2, Viv3 etc
    Aug 2003
    "which would overwrite the values for each vivarium every few seconds. “
    It sounds like you just need to overwrite the appropriate value into the 4 line buffer instead of updating the whole display buffer for every variable,
    or update the LCD location directly, but I would do the former, and write a complete screen every time.
    Aug 2003
    Does viv mean vivarium? Before you listen to me you should see how professional my setup is
    I like the way the LCD doesn’t have a backlight so I faked it with an LED.
  1. Replies: 6
    Last Post: - 28th October 2014, 06:08
  2. Do I need a pause?
    By tazntex in forum Serial
    Last Post: - 29th August 2008, 04:32
  3. 1 us delay
    By Pedro in forum mel PIC BASIC Pro
    Last Post: - 18th February 2006, 17:28
  4. Pause
    By blue in forum General
    Last Post: - 29th December 2005, 14:24
  5. pause 0.5
    By detail in forum mel PIC BASIC Pro
    Last Post: - 27th June 2005, 11:32
