Delay without using pause
Results 1 to 40 of 43
    Oct 2014
    Lagos Nigeria
    Default Re: Delay without using pause
    THANKS TO YOU ALL FOR TRYING TO HELP.
    I have thrown together some wobbly code to try and explain what i'm trying to do.
    I know it might not be the best way, but i can't seem to wrap my head around the whole idea. I just want to be able to use pause in a way that I won't sit and wait for the time to elapse.
    in the mainloop here, i have 4 blocks (which could be doing many different things aside from toggling pins). Each block has a pause somewhere set by the value loaded in DELAYREGx
    Then in the ISR INTERUPTING EVERY 1ms;
    MYISR1:
    IF DELAYREG1>0 THEN
    DELAYREG1=DELAYREG1-1
    IF DELAYREG1=0 THEN
    DELAY1flag=1
    IF DELAYREG2>0 THEN
    DELAYREG2=DELAYREG2-1
    IF DELAYREG2=0 THEN
    DELAY2flag=1
    IF DELAYREG3>0 THEN
    DELAYREG3=DELAYREG3-1
    IF DELAYREG3=0 THEN
    DELAY3flag=1
    IF DELAYREG4>0 THEN
    DELAYREG4=DELAYREG4-1
    IF DELAYREG4=0 THEN
    DELAY4flag=1
    ; END OF ISR
    Then in the mainloop,
    MAINLOOP:
    BLOCK0:
    IF LED0_UPDATE THEN
    HIGH PORTB.0 ;IS IT TIME TO UPDATE LED0?
    @ myPAUSE 1000,1 ;MAKE PORTB.0 HIGH FOR 1000 ms USING DELAYREG1
    LED0_UPDATE=0 ;BUT DON'T WAIT FOR THE TIME TO ELAPSE
    GOTO BLOCK1
    IF DELAY1flag THEN ;WILL BE SET IN THE ISR ATFTER 1 SECOND
    LOW PORTB.0 ;HAVE WE COME TO THE END OF 1 SECOND?
    ENDIF ;END OF myPAUSE
    BLOCK1:
    IF LED1_UPDATE THEN
    HIGH PORTB.1 ;IS IT TIME TO UPDATE LED1
    @ myPAUSE 4000,2 ;MAKE PORTB.1 HIGH FOR 4000 ms USING DELAYREG2
    LED1_UPDATE=0 ;BUT DON'T WAIT FOR THE TIME TO ELAPSE
    GOTO BLOCK2
    IF DELAY2flag THEN ;WILL BE SET IN THE ISR ATFTER 4 SECOND
    LOW PORTB.1 ;HAVE WE COME TO THE END OF 4 SECOND?
    BLOCK2:
    IF LED2_UPDATE THEN
    HIGH PORTB.2 ;IS IT TIME TO UPDATE LED2
    @ myPAUSE 2000,3 ;MAKE PORTB.2 HIGH FOR 2000 ms USING DELAYREG3
    LED2_UPDATE=0 ;BUT DON'T WAIT FOR THE TIME TO ELAPSE
    GOTO BLOCK3
    IF DELAY3flag THEN ;WILL BE SET IN THE ISR ATFTER 2 SECOND
    LOW PORTB.2 ;HAVE WE COME TO THE END OF 2 SECOND?
    BLOCK3:
    IF LED3_UPDATE THEN
    HIGH PORTB.3 ;IS IT TIME TO UPDATE LED3
    @ myPAUSE 400,4 ;MAKE PORTB.3 HIGH FOR 400 ms USING DELAYREG4
    LED3_UPDATE=0 ;BUT DON'T WAIT FOR THE TIME TO ELAPSE
    GOTO BLOCK0
    IF DELAY1flag THEN ;WILL BE SET IN THE ISR ATFTER 0.4 SECOND
    LOW PORTB.3 ;HAVE WE COME TO THE END OF 0.4 SECOND?
    GOTO MAINLOOP
    Here is what i mean by using pbp within ASM macro;
    MACRO myPAUSE msec,subID
    movlw msec
    movwf delay_temp
    movlw subID
    movwf KeepTrack
    SELECT CASE KeepTrack
    CASE 1
    DELAYREG1=delay_temp
    DELAY1flag=0
    CASE 2
    DELAYREG2=delay_temp
    DELAY2flag=0
    CASE 3
    DELAYREG3=delay_temp
    DELAY3flag=0
    CASE 4
    DELAYREG4=delay_temp
    DELAY4flag=0
    CASE ELSE
    @ NOP
    END SELECT
    @ ENDM
    I hope someone might understand and help me...
    thanks.
    Stanon1, I see where you are clearing: LED0_UPDATE=0 but where are you setting it to TRUE? I think you are on the right track but it could be made much more simplistic.
    EN82fn
    Oct 2014
    Lagos Nigeria
    Exactly! It could be made simpler. That is the crux of the matter.
    You are right i didn't show where i am setting LED0_UPDATE. these flags themselves, at the right time based on certain parameters, are set by other isr running in parrallel with the heartbeat timer
    thanks for the reply
    I can suggest a little different approach which I have used...... its similar to how operating systems work ... and since you are using interrupts, you already are doing most of the work...
    I will explain more unless your intent on proceeding with what you have been doing.
    don
    Oct 2014
    Lagos Nigeria
    don
    hi amgen, pls any suggestions you have is welcome. my aim was to let you guys understand what i'm trying to do; i am not good at coding so that is where i need help: how best to go about it to get the expected results... i will be glad if you would explain
    before adding your code, set up a real time loop with interrupt every 100 milliseconds (that gives 10 times per second and allows for many microsecond instructions to run within main timing loop) don't use any pauses....just set/start/check counters in loop sections as each pass is exactly .1 seconds.
    So program runs main loop including your individual code parts..... then waits at the bottom in a while command until the interrupt sends it back to main loop ......
    as long as all your code operates within 100 milliseconds (that's many 1 and 2 microsecond machine code instructions) then the loop will always wait until retriggered after looping through your code in the while loop.
    You set up a few flag type bits or bytes that get set/reset/checked for program flow.
    sorry if explanation is messy.
    First get the main .1 second loop working (blink/toggle an led as an indicator) then add in your code relying on the .1 second looping time.
    http://www.picbasic.co.uk/forum/asse...1&d=1311957346
  1. Replies: 6
    Last Post: - 28th October 2014, 07:08
  2. Do I need a pause?
    By tazntex in forum Serial
    Last Post: - 29th August 2008, 05:32
  3. 1 us delay
    By Pedro in forum mel PIC BASIC Pro
    Last Post: - 18th February 2006, 18:28
  4. Pause
    By blue in forum General
    Last Post: - 29th December 2005, 15:24
  5. pause 0.5
    By detail in forum mel PIC BASIC Pro
    Last Post: - 27th June 2005, 12:32
