16LF1824 strange problem
Results 1 to 32 of 32
    Jan 2014
    Default Re: 16LF1824 strange problem
    @ Amoque - Also, I tried with () but no effect
    @ Alain - 1000X thx for your example. I'm a begginer and I see in my eyes more fog ....but was a inspiration for me and I solved . I think that is a unusually code, but work !
    Code :
    init:
    pulsin portc.2 , 1, varb
    for i = 1 to 50
    varb = varb +1
    next i
    if varb > 60 then
    goto init2
    goto init
    goto init
    init2:
    if varb > 160 or varb <140 then goto init
    if varb > 140 and varb < 160 then goto beep
    goto init2
    beep:
    ...code...
    goto beep
    Thx to all for help!
    Jun 2009
    Sc*nthorpe, UK
    Quote Originally Posted by midali View Post
    In your code () will have no effect because the simple comparisons work as expected. But using () makes the code easier to read and it is good practice to always use them.
    Alain's code is almost the same as yours
    varb var byte
     varb = 0
     pause 200
     init:
     if varb < 140 or varb > 160 then init
     goto init
    Except he added a pause 100 and a retry just to make sure
    varb var byte
     varb = 0
     pause 200
     init:
     if (varb < 140) or (varb > 160) then init
     if (varb > 140) and (varb < 160) then goto beep
     goto init
    Your code that works is adding delays in a complicated way and also has a retry.
    init:
    for i = 1 to 50
        varb = varb +1
    next i
    if varb  > 60 then
        goto init2
        goto init
    goto init
    init2:
    goto init2
    beep:
    ...code...
    goto beep
    It looks to me that on starting the RC a "false signal" is received that satisfies the "if varb > 140 and varb < 160 then goto beep" condition and by adding the delay and retry these "false signals" are trapped. Can you try your modified code above, the one with the added pause 100 and retry in red?
  1. A strange problem
    By mombasa in forum mel PIC BASIC Pro
    Last Post: - 25th January 2012, 21:08
  2. Very strange problem...
    By alanmcf in forum mel PIC BASIC Pro
    Last Post: - 7th May 2011, 06:28
  3. strange serout2 problem
    By KaanInal in forum mel PIC BASIC Pro
    Last Post: - 7th January 2010, 09:33
  4. Strange problem with PBP 2.50
    Last Post: - 16th October 2007, 20:45
  5. strange problem 12f675
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 5th July 2007, 13:47
