16LF1824 strange problem
Results 1 to 32 of 32
    Jan 2014
    Default 16LF1824 strange problem
    Hi to all
    I have some trouble with a code but I don't understand what is wrong : the code or a trouble from PBP3 compilation
    1. First time if I turn ON the PIC and then RC with "varb <140 or varb > 160", the code go directly to BEEP
    2. if I turn ON first time RC with "varb <140 or varb > 160" and then turn ON the PIC, the code wait in the INIT loop until "140 < varb < 160" and then go to BEEP
    Can somebody help me with this trouble ?
    1000 x thx in advance !
    The code:
    __CONFIG _CONFIG1, _FCMEN_OFF & _FOSC_INTOSC & _WDTE_OFF & _MCLRE_OFF & _CP_ON & _IESO_OFF & _BOREN_OFF & _PWRTE_OFF
    __CONFIG _CONFIG2, _PLLEN_OFF & _STVREN_OFF & _LVP_OFF
    Define OSC 4
    OSCCON = %01101010 'sets the internal oscillator to 4Mhz
    ADCON0 = %00000000
    ADCON1 = %00000000
    FVRCON = %11000010 'turn fixed voltage reference on & set it to 2.048V
    CM1CON0 = 0 ' COMPARATORS OFF
    CM1CON1 = 0
    CM2CON0 = 0
    CM2CON1 = 0
    CPSCON0 = 0 'CAPACTIVE SENSE MODULE OFF
    RCSTA.7 = 0 'SERIAL PORT OFF
    TRISA = %00000000
    TRISC = %00000100
    ANSELA = %00000000
    ANSELC = %00000000
    OPTION_REG.7 = 0
    WPUA = %00000000
    porta = 0
    portc = 0
    varb var byte
    init:
    pulsin portc.2 , 1, varb
    pause 20
    if varb < 140 or varb > 160 then init
    if varb > 140 and varb < 160 then goto beep
    goto init
    beep:
    ...code....
    goto beep
    Aug 2005
    Default Re: 16LF1824 strange problem
    ive seen similar issues when reading ADC's and not managed to figure it out
    Jun 2009
    Sc*nthorpe, UK
    On start up the output of the RC will be unpredictable. So add a start delay before init: begin with "pause 1000" and adjust by testing the result. This also applies to ADC all sensors I have used require a start delay for the reading to stabilise.
    looks everything perfectly obvious ...
    1) @ first pass, varb value is not initialized ... so, it may be 255, 0 or whatever you want ... not really important here, but ...
    2) your receiver may output its fail-safe value signal ( 1500µs ? ) until the Tx signal is captured .... so, a false detection may occur.
    so, remember to ALWAYS initialize your variables ... here, 0 will make it !!!
    one other little thing ...
    pause 20 is not so good, as you can miss one pulse if signal incomes @ more than 46 Hz ( Graupner/JR is 45 Hz ... tadaaaaaa ) ...
    as PULSIN waits for the pulse to occur, there's no special need for this delay ... other than pacing the detection loop.
    and also think if the Tx is off, the Pic returns 0 as a PULSIN measure ...
    Jan 2014
    Thx for your reply ...I tried with delay between 500ms and 3000 ms...the same. Also i tried with 16F1503 ...the same.
    Jan 2014
    Thx Alain !
    My Rx have not a fail-safe. When signal is missing the pulse is 0 .
    I use for test usually RC , not Graupner or Futaba JR
    I changed my code, but the same:
    varb var byte
    varb = 0
    pause 200
    init:
    goto init
    Jan 2014
    Also I tried a simple way :
    varb = 0
    init:
    pulsin portc2, 1, varb
    if varb < 50 then init
    if varb > 50 then goto beep
    goto init
    beep:
    ...code...
    goto beep
    So ,really varb = 0 but INIT loop is missing in my code.
    Jun 2009
    Sc*nthorpe, UK
    Have you a way to display varb? Using debug for example. I am thinking that your code is not the problem.
    ' Twinair Lights 3
    ' Lights and gear driver for Robbe Twinair
    ' Input is a 3 positions switch, Gear servo signal.
    ' Outputs 2 positions servo signal 1.1 and 1.9 ms and 8 digital outputs to drive
    ' position lights, Cabin Lights, Landing lights, Flashes ( 3 sep. ) and Beacons ( 2 Sep. ).
    ' short push on button ( park pos. ) enables system to restart without power OFF
    ' long push ( park pos. ) enables gear to go up and lock for transportation.
    ' 16F1825 or equ. processor with two+ Hard PWM module.
    ' Use ICD2/3 or PicKit3 as a programmer !!!
    ' OK On September 8th 2013
    ' 16F1825 ... 1977 Lines
    ' Defines
    #DEFINE BEC_First 1		' Wait for signal @ Power ON
    DEFINE OSC 8
    DEFINE PULSIN_MAX 6500
    'Config
    	__CONFIG    _CONFIG1, _FOSC_INTOSC & _WDTE_ON & _PWRTE_ON  & _MCLRE_OFF & _CP_OFF  & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
     	__CONFIG 	_CONFIG2, _WRT_ALL & _PLLEN_OFF & _STVREN_OFF & _BORV_HI & _LVP_OFF
    OSCCON 		= %01110000 ' Internal RC @ 8Mhz
    OSCTUNE		= %00000000	' Internal osc Adjustment
    INTCON		= 0
    PIE1		= 0
    PIE2		= 0
    CM1CON0.7	= 0
    CM2CON0.7	= 0
    CPSCON0 	= 0
    CPSCON1 	= 0
    DACCON0 	= 0
    FVRCON 		= 0
    CCP1CON		= %00001100
    CCP2CON		= %00001100
    CCP3CON		= %00000000
    CCP4CON		= %00000000
    'ADC parameters
    ADCON0		= 0				' all digital. A/D disabled
    ADCON1		= %10000000
    ANSELA 		= %00000000
    ANSELC 		= %00000000
    ' Port parameters & Aliases
    OPTION_REG.7	= 0			' Global Pull Up Enable
    PORTA 		= %00000000
    PORTC 		= %00000000
    WPUA		= %00000000
    TRISA		= %00101000
    TRISC		= %00010000
    WPUC		= %00010000		' Enable Weak Pull Up for Manual Gear drive
    Poslight_		VAR	PORTA.0				' Position Lights
    CabinLight_ 	VAR PORTA.1				' Cabin Lights
    Landlight_		VAR PORTA.2				' Landing Lights
    Signal_			VAR PORTA.3				' Gear Signal Input
    Gearout_		VAR PORTA.4				' Gear Signal Output
    Batt_			VAR	PORTA.5				' Battery level Input ( 4.3v / 4.7v )
    Flashlight1_	VAR PORTC.0				' FlashLight #1
    Flashlight2_	VAR PORTC.1				' FlashLight #2
    Flashlight3_	VAR PORTC.2				' FlashLight #3
    Beacon1_		VAR PORTC.3 			' Beacon #1 need CCP2 Output !
    Manual_			VAR PORTC.4				' Manual Gear retract input
    Beacon2_		VAR PORTC.5 			' Beacon #2 need CCP1 Output !
    ' Variables
    Servoval	VAR WORD
    ServovalOld	VAR WORD
    Servomes 	VAR WORD
    Gearval		VAR WORD
    Sample		VAR BYTE
    I			VAR BYTE
    J			VAR BYTE
    Bad 		VAR BYTE
    Delay		VAR BYTE
    HPWMVal1	VAR BYTE
    HPWMVal2	VAR BYTE
    HPWMVal3	VAR BYTE
    HPWMValue1	VAR BYTE
    HPWMValue2	VAR BYTE
    Battlo		VAR BIT
    Beacons		VAR BIT
    FlashLight	VAR BIT
    FirstPass   VAR BIT
    ' Constants
    Beacon1		CON 1		' Alias for HPWM ch.1
    Beacon2		CON 2		' Alias for HPWM ch.2
    Stabsample	CON 10		' Nb of samples before command being accepted
    GearDown	CON 220		' Down Gear Pulse ( x5 ms )
    GearUp		CON 380		' Up Gear Pulse ( x5 ms )
    Losig		CON 21400 	' 22500 - Geardown*5
    Upsig		CON 20600	' 22500 - GearUp*5
    CLEAR
    PORTA = %00100000		' Batt prepos. to 1 ( Ok level )
    First: ' Wait for Signal and Verify Voltage: lock if low
    #IF BEC_First			' Wait for R/C Signal if Power ON First
    	PULSIN Signal_,1,servomes
    	IF ( servomes < 160 ) OR ( servomes > 440 ) THEN First
    #ENDIF
    PAUSE 100				' Voltage settling time ...
    IF !Batt_ OR Battlo THEN
    	Battlo = 1
    	LOW Gearout_
    	GOTO FIRST
    ' is there Someone alive here ???
    Alive:
    IF ( servomes < 160 ) OR ( servomes > 440 ) THEN First ' just to be sure ...
    IF Servomes <= 330 THEN 		' No ... Gear Pulse is NOT High
    								' do Place Gear switch to HIGH Gear
    	I = (I + 1)// 25
    	IF !I THEN 					' Flash LandLights until High Gear
    		HIGH LandLight_
    		LOW LandLight_
    	GOTO Alive
    LOW LandLight_					' Yes, Switch in the good position let's go on
    I = 0
    ' Send GearUP signal to unlock gear
    FOR I = 1 to 10							' Blink PosLights for 6.8 sec
    	HIGH PosLight_
    	FOR J = 1 to 15						' 22.5 ms*15
    		LOW GearOut_
    		PULSOUT GearOut_, GearUp
    		PAUSEUS Upsig
    	NEXT J
    	LOW PosLight_
    		LOW GearOut_
    		PAUSEUS Upsig
    	NEXT J
    NEXT I
    Gearval = GearUp						' initialize Gearval
    'Switch is in UP position and Gear is UP and unlocked ...
    ' We can place it down now ... without any unwanted movement.
    WHILE !Manual_
    WEND
    FirstPass = 1
    WHILE 1
    start:
    		Battlo = 1
    		GOTO Nosignal					' Endless loop if Batt LOW
    Start1:
    	Sample = sample + 1
    		Bad = ( Bad + 1 ) MIN 16		' stop if Bad.4 = 1
    		IF Bad.4 THEN
    		 GOTO nosignal					' 16 false pulses ... warning !!!
    		 GOTO Start						' Check closer for EACH frame ...
    							' before processing.
    	IF Sample = 0 THEN Bad = 0		' Clear Bad only if 256 good frames (~ 5-6 secs )
    										' for better glitch catching !!!
    	Servoval = Servomes				' Signal is then good ...
    	IF ABS(Servomes - ServovalOld) < 3 AND I => Stabsample THEN Fast
    				' But we need 10 samples to avoid switching on transients !
    							' Let's allow +/- 10 µs jitter
    	IF I = 0 THEN ServovalOld = Servoval				' let's initialize Refvalue
    	IF ABS( Servoval - ServovalOld ) > 2 THEN	' Too different ... let's restart sampling
    		I = 0
    		LOW Gearout_
    		PULSOUT Gearout_, Gearval			' Continue sending last servo pulses
    		GOTO Start
    	I = I + 1
    	IF I < Stabsample THEN						' Not enough samples !
    		LOW GearOut_
    		GOTO Start
    ' We have 10 "equal" Samples: We can continue and process the command
    Fast:
    	SELECT CASE Servoval
    		Case is > 330 				' Hi pos = Flight
    			IF FirstPass THEN 			' Save lights Batt on ground
    				HIGH CabinLight_		' Just CabinLights ON
    				GOTO Powersave
    			Beacons		= 1				' Beacons ON
    			FlashLight 	= 1				' FlashLight ON
    			HIGH Poslight_				' Position Lights ON
    			LOW CabinLight_				' Cabins Lights OFF
    			LOW Landlight_				' Landing Lights OFF
    Powersave:
    			Gearval = GearUp			' Gear UP
    		Case is => 270				' Mid Pos @ 300 = TakeOff
    			FirstPass	= 0				' Enable Lights
    			HIGH Landlight_				' Landing Lights ON
    			LOW CabinLight_				' CabinsLights OFF
    			Gearval = GearDown			' Gear Down
    		Case else   				' Lo Pos = Parking
    			Beacons  	= 0				' Beacons OFF
    			FlashLight 	= 0				' Flashlights OFF
    			LOW Poslight_				' POSITION Lights OFF
    			HIGH CabinLight_			' CabinsLights ON
    			Gearval = GearDown			' Gear LOW
    '			Check for Manual Gear UP
    			Delay = 0
    			BUTTON Manual_, 0, 255, 0, Delay, 1, GearUP_
    	END SELECT
    Not_so_sure:
    	LOW Gearout_
    	IF Beacons THEN 					' Let's run the Beacons	@ +/- 1Hz ( 45 x 22.5 ms )
    		LOOKUP HPWMVal1,[0,0,0,0,0,0,0,0,0,1,2,5,8,10,15,40,70,100,130,160,195,230,237,255 _
    						,237,230,195,160,130,100,70,40,15,10,8,5,2,1,0,0,0,0,0,0,0],HPWMValue1
    		LOOKUP HPWMVal2,[0,0,0,0,0,0,0,0,0,1,2,5,8,10,15,40,70,100,130,160,195,230,237,255 _
    						,237,230,195,160,130,100,70,40,15,10,8,5,2,1,0,0,0,0,0,0,0],HPWMValue2
    		HPWMVal1 = ( HPWMVal1 + 1 )//45
    		HPWMVal2 = ( HPWMVal2 + 1 )//43
    		HPWMVal3 = ( HPWMVal1 + 1 )//42
    		HPWM Beacon1 ,HPWMValue1,5000			' Beacon1 Control
    		HPWM Beacon2 ,HPWMValue2,5000			' Beacon2 Control
    		HPWMVal1 = 0
    		HPWMVal2 = 0
    		HPWMVal3 = 0
    		HPWM Beacon1,0,5000
    		HPWM Beacon2,0,5000
    	IF FlashLight THEN				' Let's run the 3 double Flashlights ** @ +/- 1Hz
    		IF ( HPWMVal1 => 15 AND HPWMVal1 < 20 ) OR ( HPWMVal1 => 27 AND HPWMVal1 < 32 ) THEN
    			HIGH Flashlight1_
    			LOW Flashlight1_
    		IF ( HPWMVal2 => 19 AND HPWMVal2 < 24 ) OR ( HPWMVal2 => 31 AND HPWMVal2 < 36 ) THEN
    			HIGH Flashlight2_
    			LOW Flashlight2_
    		IF ( HPWMVal3 => 25 AND HPWMVal3 < 30 ) OR ( HPWMVal3 => 37 AND HPWMVal3 < 42 ) THEN
    			HIGH Flashlight3_
    			LOW Flashlight3_
    		LOW Flashlight1_
    		LOW Flashlight2_
    		LOW Flashlight3_
    WEND
    nosignal: ' Land lights Blink @ 2.5 Hz , Gear Down , others OFF
     LOW  PosLight_
     LOW  CabinLight_
     LOW  Flashlight1_
     LOW  Flashlight2_
     LOW  Flashlight3_
    IF FirstPass THEN next3						' If signal cut Gear stays UP
     HPWM 1,0,500
     HPWM 2,0,500
     LOW Beacon1_
     LOW Beacon2_
     HPWMVal1 		= 0
     HPWMVal2		= 0
     HPWMVal3		= 0
    WHILE 1										' Endless loop
     	HIGH LandLight_
     	FOR I = 1 to 10							'	~ 200 ms
    		LOW Gearout_
    		PULSOUT Gearout_, Geardown			' Gear Down !
    		PAUSEUS losig
    	NEXT I
    	LOW LandLight_
    		LOW Gearout_
    		PAUSEUS losig
    	NEXT I
    WEND
    GearUP_: ' Button has to be pressed for more than 7 seconds to place gear UP
      LOW Cabinlight_							' Just PosLights !
    ' let's	verify if we are really sure ...
    	FOR I = 1 to 3							' Blink Poslights for 2 sec
    		HIGH PosLight_
    		FOR J = 1 to 15
    			LOW GearOut_
    			PULSOUT GearOut_, GearDown
    			PAUSEUS Losig
    		NEXT J
    		LOW PosLight_
    		FOR J = 1 to 15
    			LOW GearOut_
    			PAUSEUS Losig
    		NEXT J
    	NEXT I
    		Delay = 0
    		BUTTON Manual_, 0, 255, 0, Delay, 1, pushed		' Test if Button still pushed
    released:												' Let Gear down and wait
    WHILE 1									' send DownGear Signal Forever
    	LOW Gearout_
    	PULSOUT Gearout_, GearDown			' Let Gear Down !
    	PAUSEUS Losig
    ' Rearm system w/Button, no Power OFF needed... or let Gear Down if power OFF !
    	IF !Manual_ THEN					' Wait for Button release before continue
    		PAUSE 1000						' Time to release button
    		GOTO Main
    WEND												' NO we Continue Looping.
    pushed:
    	FOR I = 1 to 7									' Blink Poslights for 4.8 sec
    		HIGH PosLight_
    		FOR J = 1 to 15
    			LOW GearOut_
    			PAUSEUS Losig
    		NEXT J
    		LOW PosLight_
    		FOR J = 1 to 15
    			LOW GearOut_
    			PAUSEUS Losig
    		NEXT J
    		Delay = 0
    		BUTTON Manual_, 0, 255, 0, Delay, 1, nextI		' Test Button
    		I = 0											' IF YES ... jump to nextI
    		GOTO Not_so_sure								' IF NO ... return
    nextI:
    	NEXT I
    next1:' is Button still pushed ???
    	Delay = 0
    	BUTTON Manual_, 0, 255, 0, Delay, 1, next2		' YES ... jump to next2
    	GOTO Not_so_sure								' NO ... return
    next2:' still pushed ??? ... you really sure ???
    	Delay = 0
    	BUTTON Manual_, 0, 255, 0, Delay, 1, next3		' YES ... we proceed !!!
    next3:
    ' Switch OFF all Lights
     'LOW PosLight_	 									' already being done !!!
     'LOW Cabinlight_	 								' already being done !!!
     LOW LandLight_
     LOW Flashlight1_
     LOW Flashlight2_
     LOW Flashlight3_
     HPWM Beacon1,0,5000
     HPWM Beacon2,0,5000
     LOW Beacon1_
     LOW Beacon2_
     HPWMVal1 		= 0
     HPWMVal2		= 0
     HPWMVal3		= 0
    WHILE 1									' send UpGear Signal Forever
    	LOW Gearout_
    	PULSOUT Gearout_, GearUP			' Gear UP !
    	PAUSEUS Upsig
    WEND
    But this works more than fine ...
    Jan 2014
    Tomorrow I'll have a little oscilloscope. Something its strange, because I verified with a simple way the level pulse: I put in parallel with portc.2 a simple device with 10F202 that turn ON a LED when signal is missing (< 0,5 ms) and turn OFF LED when signal is different to 0 (>0,5ms) and work perfectly.
    Sometime , 1 from 15 tries, my code work good. Between tests I wait few minutes and I discharged the 10uF capacitor from Vcc line.
    Apr 2011
    Welches, Oregon
    The manual describes using parenthesis in IF/ THEN statements as so:
    IF (X) AND (Y) THEN
    IF (X) OR (Y) THEN
    This forces evaluation of the conditions prior to making the comparison. It does not appear, from the code posted, that you are doing so.
    Jan 2014
    @ Amoque - Also, I tried with () but no effect
    @ Alain - 1000X thx for your example. I'm a begginer and I see in my eyes more fog ....but was a inspiration for me and I solved . I think that is a unusually code, but work !
    Code :
    init:
    for i = 1 to 50
    varb = varb +1
    next i
    if varb > 60 then
    goto init2
    goto init
    goto init
    init2:
    if varb > 160 or varb <140 then goto init
    goto init2
    beep:
    ...code...
    goto beep
    Thx to all for help!
    Jun 2009
    Sc*nthorpe, UK
    Quote Originally Posted by midali View Post
    In your code () will have no effect because the simple comparisons work as expected. But using () makes the code easier to read and it is good practice to always use them.
    Alain's code is almost the same as yours
    varb var byte
     varb = 0
     pause 200
     init:
     goto init
    Except he added a pause 100 and a retry just to make sure
    varb var byte
     varb = 0
     pause 200
     init:
     if (varb < 140) or (varb > 160) then init
     if (varb > 140) and (varb < 160) then goto beep
     goto init
    Your code that works is adding delays in a complicated way and also has a retry.
    init:
    for i = 1 to 50
        varb = varb +1
    next i
    if varb  > 60 then
        goto init2
        goto init
    goto init
    init2:
    goto init2
    beep:
    ...code...
    goto beep
    It looks to me that on starting the RC a "false signal" is received that satisfies the "if varb > 140 and varb < 160 then goto beep" condition and by adding the delay and retry these "false signals" are trapped. Can you try your modified code above, the one with the added pause 100 and retry in red?
    Jan 2014
    I tried your code...the same. But is something what I don't understand ... I used 2 different variables and work great . It don't work if I use the same variable ! Today I'll try initialisation from Alain's code. In this moment my code work good, but I want to understand whats happen inside.
    varb var byte
    vara var byte
    varb = 0
    vara = 0
    pause 200
    init:
    pulsin portc.2 , 1, vara
    if vara < 140 or vara > 160 then init
    if vara > 140 and vara < 160 then goto beep
    goto init
    bepp:
    ....code....
    goto beep
    1000 x THX
    bepp:
    ....code....
    goto beep
    1000 x THX
    something rings your bell ???
    Jan 2014
    wow ...you see quickly
    Yeap..I edit bepp...does not matter.
    Jun 2009
    Sc*nthorpe, UK
    varb var byte
    vara var byte
    varb = 0
    vara = 0
     pause 200
    init:
     goto init
    beep:
    ....code....
    goto beep
    1000 x THX
    Are you saying the init routine works but beep does not work if vara is used but does work if varb is used?
    If so I am puzzled.
    Can you post the code in beep?
    Jan 2014
    Its very strange! If I use the same variable in init and in main(another loop), no work properly. If I use different variables, work great. Totally mistake!
    varb var byte
    vara var byte
    x var byte
    divf var byte
    divf = 0
    varb = 0
    vara = 0
    x = 0
    pause 200
    init:
    goto init
    beep:
    hpwm 1 , 10, 3000
    high front
    pause 80
    low front
    pause 200
    hpwm 1 , 5, 1200
    high front
    pause 80
    low front
    pause 200
    hpwm 1 , 10, 3000
    high front
    pause 80
    low front
    hpwm 1 , x, 1954
    '========================miss signal===========================
    if varb < 50 then
    varb = 150
    x=0
    low front
    if varb> 160 then
    high front
    divf=255*(varb-160)/30
    if varb > 190 then varb = 190
    if x > 255 then x = 255
    if divf > x then x=x+2
    if divf < x then x=x-6
    if x < 15 then x=15
    if varb < 160 and varb > 140 then
    low front
    x = 0
    would it be possible to post the actual code you are using (in code tags preferably) not some edited portion.what are your config settings ? a schematic sketch could be in order. without the full story any solutions are just speculation
    whats "front" ? where is that defined
    this sort of code seems pretty awkward and may not really address the problem
    init:
    goto init
    have a go at something like this
    DEFINE PULSIN_MAX 500   ; why wait longer if its already out of limits (may need adjustment)
    init_ok  var bit
    init_ok=0
    init:
    while portc.2    ;  wait till portc.2 goes low
    wend
    while ! init_ok   ; or init_ok=0 if you like
    if abs(vara-150)<=10 then init_ok=1
    wend
    or 5 good pulses in a row
    init_ok  var byte
    init_ok=5
    init:
    wend
    while  init_ok   ; or init_ok>0 if you like
    init_ok=init_ok -1
    init_ok=5
    wend
    Jan 2014
    Something is strange. Now it work with the same variable in init and in main loops. Yesterday I tried a many time and don't worked.
    @ richard : thx for your suggestions
    Here is working code :
    DEfine  OSC 4
    ADCON0 = %00000000
    ADCON1 = %00000000
    FVRCON = %11000010     'turn fixed voltage reference on & set it to 2.048V (last two bits set the voltage ...01 =1.024V,10=2.048
    CM1CON1 = 0
    CM2CON0 = 0   ' COMPARATORS OFF
    CM2CON1 = 0
    TRISA   = %00000000
    TRISC   = %00000100
    ANSELA = %00000000
    ANSELC = %00000000
    OPTION_REG.7 = 0
    WPUA  =  %00000000
    PORTA = 0
    PORTC = 0
    Symbol front  = PORTA.4
    x      var  byte
    varb   var  byte
    divf   var  byte
    x        = 0
    varb   = 0
    divf    = 0
    init:
    goto init
    beep:
    hpwm 1 , 10, 3000
        high front
        pause 80
        low front
        pause 200
    hpwm 1 , 5, 1200
        high front
        pause 80
        low front
        pause 200
    hpwm 1 , 10, 3000
        high front
        pause 80
        low front
    hpwm 1 , x, 1954
    '=======================miss signal=========================
    if varb < 50 then
         varb = 150
         x=0
         low front
    '========================front===============================
    if varb> 160  then
            high front
        if divf > 255 then divf = 255
        if divf >x then x=x+2
        if divf <x then x=x-6
    '==================== stay ==================================
        low front
        x= 0
    '==========================light==============================
    if varb < 140 and varb > 50 then
         high PORTA.0
        low PORTA.0
    Jun 2009
    Sc*nthorpe, UK
    Well done you have made a lot of progress. Just a couple of small points
    DEfine  OSC 4
    should be
    if only to make it more readable.
    not that it matters in this case and simply to further understanding.
    _FOSC_INTOSC directs the internal oscillator to be used
    OSCCON = %01101000 sets the oscillator defined by FOSC to 4Mhz
    OSCCON = %01101010 switches to the internal oscillator and sets it to 4Mhz
    So what difference does it make? It looks like there are two methods for achieving the same thing.
    "not that it matters in this case and simply to further understanding." I beg your pardon? When using the internal oscillator, "OSCCON" register is the only way to select the internal oscillator speed. Unless it is set it will default to 500Khz.
    EN82fn
    Jun 2009
    Sc*nthorpe, UK
    I am asking a question not stating anything why say "I beg your pardon?" did I say something wrong.
    You are correct Dave, about the speed did I say otherwise?
    The question is why are there two methods to select the internal oscillator and what is the difference. In the code FOSC is used to select the internal oscillator and also OSCCON is used to select the internal oscillator.
    FOSC in the configs tells the type of oscillator used. In this case internal.
    OSCCON sets the speed of the internal with bits 6-3.
    Bit 1-0 of OSCCON is for two-speed start-up. If internal is selected in the config, two-speed start-up is disabled.
    Jun 2009
    Sc*nthorpe, UK
    From the datasheet.
    5.4.1 TWO-SPEED START-UP MODE
    CONFIGURATION
    Two-Speed Start-up mode is configured by the
    following settings:
    • IESO (of the Configuration Word 1) = 1; Internal/
    External Switchover bit (Two-Speed Start-up
    mode enabled).
    • SCS (of the OSCCON register) = 00.
    • FOSC<2:0> bits in the Configuration Word 1
    configured for LP, XT or HS mode.
    Which I take to mean that SCS has to be 00 for Two-Speed Start-up to work. I am not certain this is the same as
    This section of the datasheet is the source of the issue
    5.2.2.1 HFINTOSC
    The High-Frequency Internal Oscillator (HFINTOSC) is
    a factory calibrated 16 MHz internal clock source. The
    frequency of the HFINTOSC can be altered via
    software using the OSCTUNE register (Register 5-3).
    The output of the HFINTOSC connects to a postscaler
    and multiplexer (see Figure 5-1). One of nine
    frequencies derived from the HFINTOSC can be
    selected via software using the IRCF<3:0> bits of the
    OSCCON register. See Section 5.2.2.7 “Internal
    Oscillator Clock Switch Timing” for more information.
    The HFINTOSC is enabled by:
    • Configure the IRCF<3:0> bits of the OSCCON
    register for the desired HF frequency, and
    • FOSC<2:0> = 100, or
    • Set the System Clock Source (SCS) bits of the
    OSCCON register to ‘1x’.
    Which as I read it states either set FOSC<2:0> = 100 or SCS to '1x' but not both. Yet in the code
    DEfine  OSC 4
    Both are set.
    Obviously the code works and setting SCS to '1x' is having no detrimental effect in this case. Am I interpreting the datasheet wrong?
    Jan 2014
    Are informations are welcome.
    From yours discussions and from datasheet I understand:
    - in Config , _FOSC_INTOSC set osc to internal ; default speed is set to 500KHz
    - OSCCON or DEFINE OSC set speed
    best way to view it
    from the data sheet
    bit 1-0 SCS<1:0>: System Clock Select bits
    1x = Internal oscillator block
    01 = Timer1 oscillator
    00 = Clock determined by FOSC<2:0> in Configuration Word 1.
    when FOSC<2:0> = 100 is equivalent to 1x = Internal oscillator block ie they both set the same option (logical or )
    but watch out if you want the pll engaged
    Jun 2009
    Sc*nthorpe, UK
    OSCCON sets the speed and DEFINE from the manual
    Note that "DEFINE OSC" doesn't set or change the actual clock frequency. It only tells PBP what to expect.
    Jan 2014
    Thx for patience!
    Now its clear in my mind. This was the 6th writed code in my life, so I have not experience, but step by step I hope that I'll understand this field.
    Jun 2009
    Sc*nthorpe, UK
    Thx for patience!
    No patience required on my part.
    I was in your position 40 years ago and learned step by step usually by trial and error as there was no internet and obviously no forum.
    If you want more help just ask.
    http://www.picbasic.co.uk/forum/showthread.php?t=19648
    Post moved to a new thread
  1. A strange problem
    By mombasa in forum mel PIC BASIC Pro
    Last Post: - 25th January 2012, 21:08
  2. Very strange problem...
    By alanmcf in forum mel PIC BASIC Pro
    Last Post: - 7th May 2011, 06:28
  3. strange serout2 problem
    By KaanInal in forum mel PIC BASIC Pro
    Last Post: - 7th January 2010, 09:33
  4. Strange problem with PBP 2.50
    Last Post: - 16th October 2007, 20:45
  5. strange problem 12f675
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 5th July 2007, 13:47
