16LF1824 strange problem
Results 1 to 32 of 32
    Jan 2014
    Default Re: 16LF1824 strange problem
    Something is strange. Now it work with the same variable in init and in main loops. Yesterday I tried a many time and don't worked.
    @ richard : thx for your suggestions
    Here is working code :
            __CONFIG _CONFIG1, _FCMEN_OFF & _FOSC_INTOSC & _WDTE_OFF & _MCLRE_OFF & _CP_ON & _IESO_OFF & _BOREN_OFF & _PWRTE_OFF
            __CONFIG _CONFIG2, _PLLEN_OFF & _STVREN_OFF & _LVP_OFF
    DEfine  OSC 4
    OSCCON = %01101010   'sets the internal oscillator to 4Mhz
    ADCON0 = %00000000
    ADCON1 = %00000000
    FVRCON = %11000010     'turn fixed voltage reference on & set it to 2.048V (last two bits set the voltage ...01 =1.024V,10=2.048
    CM1CON0 = 0   ' COMPARATORS OFF
    CM1CON1 = 0
    CM2CON0 = 0   ' COMPARATORS OFF
    CM2CON1 = 0
    CPSCON0 = 0   'CAPACTIVE SENSE MODULE OFF
    RCSTA.7  = 0   'SERIAL PORT OFF
    TRISA   = %00000000
    TRISC   = %00000100
    ANSELA = %00000000
    ANSELC = %00000000
    OPTION_REG.7 = 0
    WPUA  =  %00000000
    PORTA = 0
    PORTC = 0
    Symbol front  = PORTA.4
    x      var  byte
    varb   var  byte
    divf   var  byte
    x        = 0
    varb   = 0
    divf    = 0
    init:
    pulsin portc.2 , 1, varb
     if (varb < 140) or (varb > 160) then init
     if (varb > 140) and (varb < 160) then goto beep
    goto init
    beep:
    hpwm 1 , 10, 3000
        high front
        pause 80
        low front
        pause 200
    hpwm 1 , 5, 1200
        high front
        pause 80
        low front
        pause 200
    hpwm 1 , 10, 3000
        high front
        pause 80
        low front
    hpwm 1 , x, 1954
    '=======================miss signal=========================
    if varb < 50 then
         varb = 150
         x=0
         low front
    '========================front===============================
    if varb> 160  then
            high front
        if varb > 190 then varb = 190
            divf=255*(varb-160)/30
        if x > 255 then x = 255
        if divf > 255 then divf = 255
        if divf >x then x=x+2
        if divf <x then x=x-6
    '==================== stay ==================================
    if varb < 160 and varb > 140 then
        low front
        x= 0
    '==========================light==============================
    if varb < 140 and varb > 50 then
         high PORTA.0
        low PORTA.0
    Jun 2009
    Sc*nthorpe, UK
    Well done you have made a lot of progress. Just a couple of small points
    DEfine  OSC 4
    should be
    if only to make it more readable.
    not that it matters in this case and simply to further understanding.
    _FOSC_INTOSC directs the internal oscillator to be used
    OSCCON = %01101000 sets the oscillator defined by FOSC to 4Mhz
    OSCCON = %01101010 switches to the internal oscillator and sets it to 4Mhz
    So what difference does it make? It looks like there are two methods for achieving the same thing.
    "not that it matters in this case and simply to further understanding." I beg your pardon? When using the internal oscillator, "OSCCON" register is the only way to select the internal oscillator speed. Unless it is set it will default to 500Khz.
    EN82fn
    Jun 2009
    Sc*nthorpe, UK
    I am asking a question not stating anything why say "I beg your pardon?" did I say something wrong.
    You are correct Dave, about the speed did I say otherwise?
    The question is why are there two methods to select the internal oscillator and what is the difference. In the code FOSC is used to select the internal oscillator and also OSCCON is used to select the internal oscillator.
    FOSC in the configs tells the type of oscillator used. In this case internal.
    OSCCON sets the speed of the internal with bits 6-3.
    Bit 1-0 of OSCCON is for two-speed start-up. If internal is selected in the config, two-speed start-up is disabled.
    Jun 2009
    Sc*nthorpe, UK
    From the datasheet.
    5.4.1 TWO-SPEED START-UP MODE
    CONFIGURATION
    Two-Speed Start-up mode is configured by the
    following settings:
    • IESO (of the Configuration Word 1) = 1; Internal/
    External Switchover bit (Two-Speed Start-up
    mode enabled).
    • SCS (of the OSCCON register) = 00.
    • FOSC<2:0> bits in the Configuration Word 1
    configured for LP, XT or HS mode.
    Which I take to mean that SCS has to be 00 for Two-Speed Start-up to work. I am not certain this is the same as
    This section of the datasheet is the source of the issue
    5.2.2.1 HFINTOSC
    The High-Frequency Internal Oscillator (HFINTOSC) is
    a factory calibrated 16 MHz internal clock source. The
    frequency of the HFINTOSC can be altered via
    software using the OSCTUNE register (Register 5-3).
    The output of the HFINTOSC connects to a postscaler
    and multiplexer (see Figure 5-1). One of nine
    frequencies derived from the HFINTOSC can be
    selected via software using the IRCF<3:0> bits of the
    OSCCON register. See Section 5.2.2.7 “Internal
    Oscillator Clock Switch Timing” for more information.
    The HFINTOSC is enabled by:
    • Configure the IRCF<3:0> bits of the OSCCON
    register for the desired HF frequency, and
    • FOSC<2:0> = 100, or
    • Set the System Clock Source (SCS) bits of the
    OSCCON register to ‘1x’.
    Which as I read it states either set FOSC<2:0> = 100 or SCS to '1x' but not both. Yet in the code
    DEfine  OSC 4
    Both are set.
    Obviously the code works and setting SCS to '1x' is having no detrimental effect in this case. Am I interpreting the datasheet wrong?
    best way to view it
    from the data sheet
    bit 1-0 SCS<1:0>: System Clock Select bits
    1x = Internal oscillator block
    01 = Timer1 oscillator
    00 = Clock determined by FOSC<2:0> in Configuration Word 1.
    when FOSC<2:0> = 100 is equivalent to 1x = Internal oscillator block ie they both set the same option (logical or )
    but watch out if you want the pll engaged
  1. A strange problem
    By mombasa in forum mel PIC BASIC Pro
    Last Post: - 25th January 2012, 22:08
  2. Very strange problem...
    By alanmcf in forum mel PIC BASIC Pro
    Last Post: - 7th May 2011, 07:28
  3. strange serout2 problem
    By KaanInal in forum mel PIC BASIC Pro
    Last Post: - 7th January 2010, 10:33
  4. Strange problem with PBP 2.50
    Last Post: - 16th October 2007, 21:45
  5. strange problem 12f675
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 5th July 2007, 14:47
