A strange problem
Results 1 to 12 of 12
    Jul 2006
    Lazio, Italy
    Default A strange problem
    Since storage requirements for the 18F252 I left and walked to get on 18f2620 lcd dsplay question marks instead of the value of variables that I use. This problem only affects the contents of variables, the world's other writing appear correctly. Someone has already had this problem? I enclose the listing. thanks very much.
    ' PIC Defines
    @ __CONFIG _CONFIG1H, _IESO_OFF_1H & _FCMEN_OFF_1H & _OSC_INTIO7_1H
    ' Oscillator Switch-over Disabled
    ' Fail-Safe clock Monitor Disabled
    ' Set for Internal Oscillator RA7 Enabled
    @ __CONFIG _CONFIG2L, _BOREN_OFF_2L & _PWRT_OFF_2L
    ' Brown-Out Reset Enabled
    ' Power-On Timer Enabled
    ' Brown-Out Trip set to 4.2v
    @ __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_128_2H
    ' WatchDog is OFF
    ' Watchdog Postscaler set to 1:128
    @ __CONFIG _CONFIG3H, _MCLRE_ON_3H & _PBADEN_OFF_3H & _CCP2MX_PORTC_3H
    ' MCLR is OFF (internal)
    ' PortB 4:0 is digital on Reset
    ' CCP2 is Multiplexed with PortC.1
    @ __CONFIG _CONFIG4L, _STVREN_OFF_4L & _LVP_OFF_4L & _DEBUG_OFF_4L
    ' Stack Under/Overflow will Reset System
    ' Enhanced CPU Addressing Disabled
    ' Low-Voltage Programming is OFF
    ' DEBUG is Disabled
    OSCCON = %11111110 'Internal 8 mhz Osc and stable
    'OSCTUNE.6=1 ' MOLTIPLICATORE PLL X4
    CMCON = %00000111 'Comparators Off
    DEFINE OSC 8 ' Clock a 8 Mhz
    INTCON2.7=0 'ABILITA PORTB PULLUP
    A var BYTe
    DEFINE LCD_BITS 4 'NUMERO LINEE DI COMANDO 4 O 8
    DEFINE LCD_DREG PORTB 'PORTA ChE GESTISCE LCD
    DEFINE LCD_DBIT 4 'BIT INIZIALE BUS
    DEFINE LCD_RSREG PORTB 'PORTA CHE GESTISCE RS
    DEFINE LCD_RSBIT 2 'BIT CHE GESTISCE RS
    DEFINE LCD_EREG PORTB 'PORTA CHE GESTISCE E
    DEFINE LCD_EBIT 3 'PIN CHE GESTISCE IL SEGNALE E
    DEFINE LCD_LINES 2 'NUMERO LINEE LCD
    LCDOUT $FE,1
    PAUSE 500
    LCDOUT $FE,1,"CIAO MAMMA" 'THIS IS DISPLAYED OK
    PAUSE 1000
    LCDOUT $FE,1
    for a=1 to 10
    LCDOUT $FE,DEC2 A 'HERE ARE DISPLAYED: ??????????
    PAUSE 500
    next a
    Dec 2011
    IO93ok
    Default Re: A strange problem
    Maybe try
    LCDOUT $FE, $80, DEC2 A
    Dec 2011
    IO93ok
    Or try
    LCDOUT $FE, $80, #A
    Jul 2006
    Lazio, Italy
    Thanks tasmod, with this statement "LCDOUT $ FE, $ 80, # A" now everything seems to work ok. But what has changed? I have always used "DEC A" and has always worked. What is the problem? Thank you again
    Nothing changed. You forgot $80 before your variable.
    Jul 2006
    Lazio, Italy
    No, it is so, even this statement "LCDOUT $FE,$80,DEC A" does not work.
    Dec 2011
    IO93ok
    I always did this from early PicBasic days. Can't remember why.
    #A Meaning the decimal representation of an ASCII value.
    I always assumed that in a loop declared as a character, the loop iterated the character the number of times in the loop (i.e. first time round, A=1 in decimal but A was still a character representing that value)
    Hope that makes sense.
    Jul 2006
    Lazio, Italy
    Thank you for your interest, but I do not understand is that I have used this statement thousands of times with the 18F252 that I used before. Now I'm in trouble because I need to show the value of "A" sometimes using two digits (DEC2) and sometimes three digits (DEC3) and I do not know how.
    Try it without spaces.
    I was missing something typical to the ' 2620 ... see attachment.
    Your config section looked MUCH too light ...
    ALWAYS ... "RTFM" moreover when using a new processor kind ...
    Great Alain!
    Jul 2006
    Lazio, Italy
    Thanks Acetronics, you did a great job. RTFM is the answer.
