why timer3 ?
any timer that can provide a 10mS interrupt could be employed, the self configuring aspect of the code will not function for modern pic chips. the code will need a tickle to adapt it...
removed debug messages that are sent before spbrg set to correct value
since 1827 has more resources have increased buffer size, u may not need pacing any longer to compensate for
the 4 bit lcd...
works OK with LCD Backlight On/Off
works OK sending text over the serial port
works OK sending commands to LCD over serial port
On power up LCD shows...
Re: I'm also stuck with FSR error when using DT's elapsed timer on 16F1936
why timer3 ?
richard Today, 00:56any timer that can provide a 10mS interrupt could be employed, the self configuring aspect of the code will not function for modern pic chips. the code will need a tickle to adapt it...
