Here's another quick example that simulates a Cylon or Kitt car scanner.
It's running on a 16F887 with 8Mhz internal OSC. The PCB is the Microchip 44-pin Demo Board that comes with the PICkit2 Debug Express package.
It's not too bad with 8 LEDs, but 16 would be better. The sequence will automatically use however many LEDs you define.
By adjusting the constants, you can make it look like most of the different seasons of the shows. (Excluding the New "Knight Rider" 2009). 2009 can be done too, but it'll take a little modification.
http://www.pbpgroup.com/files/MIBAM/Cylon.MOV
The main difference is in the way the Duytcycle variables are declared.
By grouping them in an Array, they can be used with FOR loops to control all the LEDs, instead of having to access each one individually like the RGB's.
;----[ MIBAM Setup ]--------------------------------------------------------
BAM_COUNT CON 8 ; How many BAM Pins are used?
INCLUDE "MIBAM.pbp" ; Mirror Image BAM module
BAM_DUTY VAR BYTE[BAM_COUNT]
LED1 VAR BAM_DUTY[0] ; group them in an array for easy access
LED2 VAR BAM_DUTY[1] ; with FOR loops etc.
LED3 VAR BAM_DUTY[2]
LED4 VAR BAM_DUTY[3]
LED5 VAR BAM_DUTY[4]
LED6 VAR BAM_DUTY[5]
LED7 VAR BAM_DUTY[6]
LED8 VAR BAM_DUTY[7]
BAM_LIST macro ; Define PIN's to use for BAM
BAM_PIN (PORTD,0, LED1) ; and the associated Duty variables
BAM_PIN (PORTD,1, LED2)
BAM_PIN (PORTD,2, LED3)
BAM_PIN (PORTD,3, LED4)
BAM_PIN (PORTD,4, LED5)
BAM_PIN (PORTD,5, LED6)
BAM_PIN (PORTD,6, LED7)
BAM_PIN (PORTD,7, LED8)
BAM_INIT BAM_LIST ; Initialize the Pins
Speed CON 6 ; Smaller=Faster
TracerSpeed CON 15 ; Smaller=Faster Left/Right
Brightness CON 200 ; Tracers DutyCycle
DrainSpeed CON 30 ; Smaller=Shorter Trail
Idx VAR BYTE
LoopCount VAR BYTE
NextLED VAR BYTE
TraceDIR VAR BIT
TraceDIR = 0
LoopCount = 0
NextLED = 0
if LoopCount = TracerSpeed then ; __[ Cylon/Kitt Scanner ]__
LoopCount = 0
BAM_DUTY(NextLED)=Brightness
if TraceDIR then ; if scanning left
NextLED = NextLED - 1
if NextLED = 0 then TraceDIR = 0
else ; else scanning right
NextLED = NextLED + 1
if NextLED = BAM_COUNT-1 then TraceDIR = 1
FOR Idx = 0 to BAM_COUNT - 1 ; Drain all dutycycles
IF BAM_DUTY(Idx) > 0 then
BAM_DUTY(Idx)=BAM_DUTY(Idx)*DrainSpeed/(DrainSpeed+1)
NEXT Idx
pause Speed
LoopCount = LoopCount + 1
CuriousOne Today, 19:32
