It will run on your PICDem board.
This example is actually 3 parts in one.
Part number 1 (GetCharInput) is a routine that allows you to type and send text to the PIC. It echoes back valid characters, and lets you backspace if you make an error. It "rubs out" the backspace(d) characters, and it terminates when you hit <ENTER> or <ESC>. If you hit <ENTER> it returns the input in an array. If you hit <ESC> it wipes out the array and returns. If you do nothing for 9 seconds, it returns with an empty string.
Part number 2 (ConvertToUpper) takes the input in mixed-case and converts all the alpha characters to upper case. It leaves numbers and punctuation "as-is". This is handy when you do compares, since people may or may not capitalize the right letters when they type something in.
Part number 3 (ParseIt) takes the array and searches for any number of strings. When it finds a match, it returns a number that indicates which of the strings matched. This is really useful if you get random data from something like a GPS receiver, or from a network port - or anything.
Enjoy.
;Name : Code Example
'* Author : Charles Linquist
'* Date : 9/10/2011
'* Version :1.0
'* Notes : For the Forum
DEFINE OSC 40
DEFINE NO_CLRWDT 1
DEFINE _18F8723 1
DEFINE HSER_RCSTA 90H
DEFINE HSER_TXSTA 20H
DEFINE HSER_BAUD 9600
DEFINE HSER_CLROERR 1
DEFINE LOADER_USED 1
TRISC = %10111111
MaxChars var byte
Inputstring var byte [12]
Timeout var word
X var byte
CharInput var byte
InputString_Len Var Byte
CMD VAR BYTE
MaxChars = 10
InputString_Len = MaxChars
Timeout = 9000
BS con 8
CR CON 13
LF CON 10
ESC CON 27
SP CON 32
topp:
Gosub GetCharInput
Gosub ConvertToUpper
Gosub Parseit
goto topp
GetCharInput:
HSEROUT [CR,LF,"Input ? "]
TextIn:
ArrayWrite InputString,[REP 0\MaxChars] ; zero out the string to start with
X = 0
TextIn2:
HSERIN Timeout,NoInput,[CharInput]
IF CharInput = CR Then Goto DoneInput
If CharInput = ESC THEN goto NoInput
IF CharInput = BS THEN
IF X = 0 THEN
Goto TextIn2
HSEROUT [BS,SP,BS]
X = X - 1
InputString[x] = 0 ; zero out the backspaced char
GOTO TextIn2
InputString[X] = CharInput
HSEROUT [CharInput] ; Show what we got
IF X >= MaxChars then goto DoneInput
X = X + 1
GOTO TextIn2
DoneInput:
NoInput:
ArrayWrite InputString,[REP 0\MaxChars] ; wipe everything
out
hserout [CR,LF,"No Input!",CR,LF]
ConvertToUpper:
For X = 0 to MaxChars
IF InputString[X] > 96 and INputString[X] < 123 then
InputString [X] = Inputstring[X] & %11011111
Next X
Parseit:
Parse01: Cmd=01 : ARRAYREAD InputString,InputString_Len,Parse02,[WAIT("AGE")] : GOTO Foundit
Parse02: Cmd=02 : ARRAYREAD InputString,InputString_Len,Parse03,[WAIT("BIRTHDAY")] : GOTO Foundit
Parse03: Cmd=03 : ARRAYREAD InputString,InputString_Len,Parse04,[WAIT("CITY")] : GOTO Foundit
Parse04: Cmd=04 : ARRAYREAD InputString,InputString_Len,Parse05,[WAIT("STATE")] : GOTO Foundit
Parse05: Cmd=05 : ARRAYREAD InputString,InputString_Len,Parse06,[WAIT("COUNTRY")] : GOTO Foundit
Parse06:
Cmd=255
Foundit:
Select Case Cmd
Case 1
Hserout [CR,LF,"You typed 'AGE'",CR,Lf]
CASE 2
Hserout [CR,LF,"You typed 'BIRTHDAY'",CR,Lf]
CASE 3
HSEROUT [CR,LF,"You typed 'CITY'",CR,Lf]
CASE 4
HSEROUT [CR,LF,"You typed 'STATE'",CR,Lf]
CASE 5
HSEROUT [CR,LF,"You typed 'COUNTRY'",CR,Lf]
CASE ELSE
HSEROUT [CR,LF,"Invalid command",CR,LF]
END SELECT
