to start with you have not fully defined how the main OSC is setup i would add
OSCCON1 = $62;
secondly you have not set a clock source for timer1, as it is it expects a clock signal on the t1clk...
a pic16f345 is not a valid pic type, perhaps a simple schematic of your actual setup is called for and
then why don't you post the code you have tried. if you don't want to post the complete project...
Is there DT_INTS-14 that works with PIC16F345 ? I have tried to modify DT_INTS-14...changed few obvious difference's in #defines for timers 0/1/2 and and few more but LED blinky does not work....
Re: Connecting 24vdc power supply to 110vac
Hmm, won't let me edit.
Demon Yesterday, 17:35I assume L is load (black wire connected to breaker), N is neutral (white wire to common bus bar).
Just wanna make sure.
