- PICBASIC PRO Demo
- MPLAB
- PICKIT 2 programmer
- PICKIT 2 Low Pin Count Demo Board (DM164120-1) PIC16F690
- Windows 7 64 bits.
- Go on Microchip website and download the latest MPLAB version (As of June 22, 2011, Latest Version is 8.70)
- Extract and run the Setup file
If you're running Vista of Win 7, you want to raise your privilege, right click on the file then, click on "run as administrator" - Accept the agreement
- If you want to install only the minimum, when prompted for the Setup Type, choose Custom and follow the instructions bellow.
Unless, jump to step 7 - Use the default Destination Folder
- Check the following when you'll be prompted to select the features to install
- Microchip Device Support
8 Bit MCU - Microchip Application
MPASM Suite - MPLAB IDE
MPLAB SIM
PICKIT 2
- Continue the installation normally, wait 'till the end
- Go on Melabs Website and download PBPDemo
- Run the install file
If you're running Vista of Win 7, you want to raise your privilege, right click on the file then, click on "run as administrator"- Accept the agreement
- Use the default installation folders
- Continue the installation and decide if you want to Install Microcode Studio... or not. I suggest you do so, it's a pretty nice tool.
- I also suggest you to download and install the PICKIT 2 standalone application, there's quite a few interesting feature included in. Just Install it in the default folder.
- Create a new folder to store & test our new code. It's a good idea to create one close to the root.
Let's use C:\PBP_Prog
Now it's time to configure the programming environment. First thing to do is to add PBP Language Toolsuite to MPLAB
- Open C:\PBPDEMO\MPLAB_Plugin folder
- Run setup_PBPSUITE
Time to configure PBP within MPLAB
- Start MPLAB
- On the top menu, Click on Project
- From this menu select Set Language Toolsuite Locations
- in the Registered Tools list, click on the little + on the left side of microEngineering PICBASIC PRO Toolsuite
- Then again on the little + on the left side of Executables
- Finally click on microEngineering PICBASIC PRO Compiler (PBPMPLAB.BAT
- The Location field should indicate C:\PBPDEMO\PBPMPLAB.BAT)
- Click on OK
There's quite different way to start a new project within MPLAB. Here I'll show how to start a new PicBasic project using a PIC16F690 with the Project Wizard.
- Select Project Wizard
- Click on Next
- Choose PIC16F690 from the Device drop down list
- Click on Next
- Time to tell MPLAB we'll be using PICBASIC PRO
From the Active Toolsuite drop down list, choose microEngineering PICBASIC PRO Toolsuite... obvious I know. - Click on Next
- On the right side of Create New Project File field, Click on Browse
- Choose the folder we created to store our codes & project C:\PBP_Prog
- In the Filename Field type LedBlinky
- Click on Save
- Click on Next
- You'll be prompted to add some source code and files... click on Skip
- We're done, Click on Finish
- On the top menu click on File
- Choose New, this will open a new window called Untitled. Our source code will go there
- Let's give our source code a name.
On the top menu click on File - Choose Save As
- In the Filename field, type LedBlinky.bas
- Click on Save
- In the project explorer, right click on Source Files and then on Add Files
- On the top menu, click on Project then choose Add Files to the project
Both do the same job, I prefer the right click thing... it's up to you to decide.
- The PIC16F690 Datasheet
- Microchip's LPC Demo Board User Guide
Let's observe the board schematic (PDF page 41)
Is there some gotcha in it? Sure...
- There's no crystal attached to the PIC.
Q. And then?
A. We will need to configure the PIC to work with it's own internal OSC. If we don't do it, the PIC will never run... - LEDs are attached to some pin who have some enabled by default analog peripheral.
Q. How do you know that?
A. The PIC pinout gives some hints, but It's always a good to have a look in the datasheet,
Section 4.5 PORTC and TRISC Registers (pdf page 78-82)
Table 4-3 resume it really well, you want to dig the datasheet to see how to set them.
Q. What if I don't care about the datasheet and just go ahead typing some code for...what kind problem it may cause?
A. You'll be the really first one on earth
Your milleage may vary, but usually a LED connected to an analog pin doesn't work at all. Have a good look at This thread for more infos.
Code Example #1: Led Blinky
Time to get dirty. Copy/Paste the following code in the source code windows
'-------------------------------< LED Blinky >------------------------------------
' File name : LedBlinky.bas
' Version : 1.0
' Company : Mister E
' Programmer : Steve Monfette
' Date : June 22, 2011
' Device : PIC16F690
'---------------------------< Project description >-------------------------------
' Beginner code example to blink a Led on PORTc.0 using:
' 1) PBPDEMO version
' 2) MPLAB
' 3) PICKIT 2 Programmer
'----------------------------< Hardware listing >---------------------------------
' - Microchip Low Pin Count Demo Board
' - PIC16F690 installed
' - *** All jumper have to be installed ***
' - Target board will be powered by the PICKIT 2
' Pic Configuration
' All PIC configuration fuses (Configuration bits) are listed in the
' C:\PBPDEMO\p16f690.inc file. Also see datasheet section 14.1
@ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON & _CP_OFF & _CPD_OFF & _FCMEN_OFF & _IESO_OFF & _BOR_ON & _PWRTE_ON
' _INTRC_OSC_NOCLKOUT: Using Internal Oscillator
' _WDT_ON: Enable Watch Dog Timer
' _MCLRE_ON: Enable MCLR
' _CP_OFF: Disable Code Protection
' _CPD_OFF: Disable Data Code Protection
' _FCMEN_OFF: Disable Fail Safe Clock Monitor
' _IESO_OFF: Disable Internal/External switchover
' _BOR_ON: Enable Brown out detect
' _PWRTE_ON: Enable Power up Timer
OSCCON = %01110000 ' datasheet section 3
' -x-------- n/a
' --111----- IRCF<2:0> Internal Oscillator Frequency Select Bits (8MHz)
' -----xxxx- Read Only
DEFINE OSC 8 ' tells PBP we use a 8 MHZ clock
' Hardware assignment
' Here we assign Aliases to PORT pin
' this makes the code easier to read
' I'll use the Aliases name as written on the schematic
' LEDs
DS1 VAR PORTC.0
DS2 VAR PORTC.1
DS3 VAR PORTC.2
DS4 VAR PORTC.3
' Hardware configuration
' I/Os (Datasheet section 4.0 & above)
TRISA = 0 ' All PORTA I/O set as Output (When capable of)
TRISB = 0 ' All PORTB I/O set as Output
TRISC = 0 ' All PORTC I/O set as Output
' ADCs (datasheet section 9)
ANSEL = 0 ' Disable all
ANSELH = 0 ' ADCs
' Comparator (datasheet section 8)
' At Power On, the comparator are already disabled
' but let's play safe.
CM1CON0 = 0 ' Disable comparator 1
CM2CON0 = 0 ' Disable comparator 2
' Software/Hardware initialisation
PORTA = 0 ' clear PORTA output pins (0v)
PORTB = 0 ' clear PORTB output pins (0v)
PORTC = 0 ' clear PORTC output pins (0v)
WHILE !OSCCON.2 : Wend ' Wait untill the internal OSC get stable
'------------------------------< Main program >-----------------------------------
Start:
ds1 = 1 ' turn ON LED DS1
PAUSE 500 ' wait 500 mSec
ds1 = 0 ' turn OFF LED DS1
GOTO Start ' do it again
- From the top menu, click on Project
- Choose Compile (F10 also work but that's your job to find some shortcuts
Oh noes...
ERROR: Unable to execute mpasmwin.Error[118] C:\PBP_PROG\LEDBLINKY.ASM 63 : Overwriting previous address contents (2007)
Welcome in real life! Compilation error happen! Deal with it now!
First of, have a good reading at this thread, at least POST #1 & POST #5. Post #5 explain how to fix it. Once you've fixed the 16F690.inc file, hit F10, and it will compile fine.
Loaded C:\PBP_Prog\LedBlinky.COF.
BUILD SUCCEEDED: ...
Aaaaahhhh, feel better now. Now let's program the PIC and do some light show.
- On the top menu, click on Programmer
- Click on Select Programmer and choose PICKIT 2
- The Output window should show you a message like
Initializing PICkit 2 version 0.0.3.63
Found PICkit 2 - Operating System Version 2.32.0
Target power not detected - Powering from PICkit 2 ( 5.00V)
PIC16F690 found (Rev 0x5)
PICkit 2 Ready
There's no real problem with the above message, in fact, it confirm we have the right PIC installed, and the PICKIT 2 WILL provide the 5Volt to our target board. Fabulous! - On the top menu, click on Programmer
- Click on Program
OutPut
Programming Target (2011-06-23 01:35:20)
Erasing Target
Programming Program Memory (0x0 - 0x4F)
Verifying Program Memory (0x0 - 0x4F)
Programming Configuration Memory
Verifying Configuration Memory
PICkit 2 Ready
How to?
- Click on Settings
- Check Run after a sucessful program option
- Click on Apply
- Click on OK
- Still nothing there, just program your PIC again and see what happen
Code Example 2: ADC Reading
- Start a new project in MPLAB, name it ADCToLed
- Create a new source code file, name it ADCToLed
- Add the source code to the project
- Copy/Paste the following code to the source code windows
'--------------------------------< ADCToLed >------------------------------------
' File name : ADCToLed.bas
' Version : 1.0
' Beginner code example to display the ADC reading from channel AN0 to 4 LEDs
' attached on PORTC<3:0>
' 2) MPLAB
' Pic Configuration
' -x-------- n/a
' LEDs
DS1 VAR PORTC.0
DS2 VAR PORTC.1
DS3 VAR PORTC.2
DS4 VAR PORTC.3
LED VAR PORTC
TRISA = %00000001
' -xx------- n/a
' ---00000-- Output: When capable of
' --------1- Input: AN0, ADC input
ANSEL = %00000001
' -0000000-- AN<7:1> = Digital I/O
' --------1- AN0 = Analog
ANSELH = 0 ' AN<11:8> = Digital I/O
DEFINE ADC_BITS 8 ' Set number of bits in result
DEFINE ADC_CLOCK 3 ' Set clock source (rc = 3)
DEFINE ADC_SAMPLEUS 50 ' Set sampling time in
' Software variable
bADC VAR BYTE ' Hold the ADC reading
Start:
ADCIN 0, bADC ' read AN0 and store it to bADC variable
' Since we use only 4 LED and the ADC is a 8 Bit result, we
' need to adjust it so the ADC range will fit a 4 BITs LED reading
' To do so we will shift the ADC by 4 bits
bADC = bADC>>4
LED = bADC ' show the result
PAUSE 100 ' wait 100 mSec
- Compile
- Program
Soon you'll discover you can't turn on the 4 LED together. The reason is simple. Inside the PICKIT 2, both PGD & PGC (ICSPDAT & ICSPCLK) pins are pulled down with 4.7K resistor. Now leaving the PICKIT 2 connected to your board, R7 make a voltage divider with those internal internal pull-down. So the voltage never go up to 5 volt on the ADC input...
To solve this problem you could disconnect your PICKIT 2 and use an external power supply OR modify your code to use another ADC channel OR just lift the pin 4 of the ICSP header. Still plausible to trick the ADC by using anothe Vref... oh well it's up to you now.
Enjoy, be creative, have fun!
I know I know, it's almost a copy/paste thread from the MicroCode studio one... so?
The FREQIUT is the way to go.
Ioannis Today, 11:19You did not post the circuit of transistor amplifier. I suppose you did add a good bias to the transistor, right?
