Tim C
' Name : TMR1CLK.pbp
' Target PIC : PIC18F452 or similar 18F types
' Hardware : PIC-WEB ver A board with added LCD
' Oscillator : 10MHz crystal. You May have to modify default 18F452 fuses for > 4Mhz
' Resolution : Expect to get +- 5sec/day or better
' Description : PicBasic Pro program using external 32K watch xtal and Timer1
' interrupt for a real-time clock.
' Origional ver from: http://melabs.com/resources/samples/18f/tmr1clk18.htm
DEFINE OSC 10 ' We're using a 10MHz oscillator
DEFINE LOADER_USED 1 ' Boot-Loader is being used
Define INTHAND myint ' Define interrupt handler
Symbol LED_0 = PORTD.5
symbol BUTTON_0 = PORTB.0
wsave VAR BYTE bankA system ' Saves W
ssave VAR BYTE bankA system ' Saves STATUS
seconds VAR BYTE bankA ' variables within myint must be in bank 0.
minutes VAR Byte ' Elapsed minutes
hours var byte
' LCD config
Define LCD_DREG PORTD
Define LCD_DBIT 0
Define LCD_RSREG PORTE
Define LCD_RSBIT 0
Define LCD_EREG PORTE
Define LCD_EBIT 1
ADCON1 = 7 ' Set PORTA and PORTE for digital operation
Low PORTE.2 ' Enable the LCD
Pause 150 ' Pause to allow LCD to initialize
LCDOut $fe,1 ' Clear LCD
hours = 2
minutes = 23 ' Pre Set time here then add seconds to clock using button
seconds = 0
T1CON.7=0 ' 8 Bit r/w (16 bit seems to cause problems)
T1CON.5=0 ' Part 1 of 1:1 prescale
T1CON.4=0 ' Part 2 pf 1:1 prescale
T1CON.3=1 ' turn on the low freq clock osc
T1CON.2=1 ' Do not Sync low Freq clock with main clock
T1CON.1=1 ' use 32Khz xtal as the Timer1 source
T1CON.0=1 ' enable Timer1
PIE1 = $01 ' Enable TMR1 overflow interrupt
INTCON = $C0 ' Finally Enable global interrupt and peripheral interrupts
GoTo mainloop ' jump over the interrupt handler and sub
' Assembly language interrupt handler
' simplified by Bruce
@myint ; create myint label
TMR1H.7=1 ' Set TMR1 high bit for 1 second overflows
seconds = seconds+1 ' Increment seconds
PIR1.0=0 ' Clear TMR1 int flag
@ retfie FAST ; Return with 'auto restore' of WREG, STATUS and BSR
' Subroutine to update the time variables
get_time:
if seconds > 59 then
seconds = seconds - 60 ' better then making seconds=0
minutes = minutes + 1
if minutes > 59 then
minutes = 0
hours = hours + 1
if hours > 12 then ' simple 12 hour clock format
hours = 1
mainloop:
GoSub get_time ' Update minutes and seconds
TOGGLE LED_0
LCDOut $fe,2,"Time: ",DEC hours, ":", DEC2 minutes, ":", DEC2 seconds, " "
Pause 300 ' Pause to see LED blink. Also help with debounce
if button_0 = 0 then
LCDOut $fe,$C0,"+1s "
seconds = seconds + 1
LCDOut $fe,$C0," "
GoTo mainloop ' Repeat main loop
