You've probably noticed that when using the Analog to Digital converter, the numbers are NEVER stable. At best, the result will always be bouncing back and forth between two numbers.
While it's extremely annoying, there is a reason for it, and the number of times it bounces between those two numbers is actually indicating the values of more bits of resolution that are not included in the original 10-bit result.
This effect can be exploited to increase the effective number of bits in the result.
By taking a number of consecutive samples and averaging the results with a lower divisor, you can get up to 16-bit accuracy from that poor little 10-bit converter.
http://www.darreltaylor.com/DT_Analog/
An explanation of the Oversampling technique can be found on Wikipedia.
http://en.wikipedia.org/wiki/Oversampling
Re: DS3231 code using hardware I2C capabilities?
it works spasmodically theses days. [one more nail in pbp coffin]
richard - 10th December 2025, 23:04i find it will work with edge or chrome , sometimes incognito window works better
