This example divides a 25 volt source into about 4.38 volts for the PIC's A/D converter to handle.
The ratio of the voltage divider is (R1+R2)/R2. To scale up the A/D reading you just multiply the value times the total resistance of the divider (R1+R2) then divide that number by R2.
If the input is 25Vdc then the output voltage will be 25v/((R1+R2)/R2) or 25v / ((4700+1000)/1000)) = about 4.38 Vdc. With 10-bit A/D you should get an ADCin of around 898. If you first scale that A/D value up to match the voltage divider ratio, you can then calculate the voltage the same way you would if you were reading 0-5 V.
898 * 5700 / 1000 = 5118 This is what the A/D would be if it could actually read 0-25 volts directly.
Now then, for 1 decimal place, multiply that by 50 and divide by 1023. For 2 decimal places, multiply by 500 instead.
5118 * 50 / 1023 = 250 or 25.0Vdc
The program below is one way to do it in PBP.
HTH,
Darrel
Res1 Var Word
Res2 Var Word
Rt Var Word
Volts Var Word
AD Var Word
GetReadings:
ADCin 0, AD
Res1 = 4700 ' Change these to match your Voltage divider
Res2 = 1000 ' resistor values for the Solar Cell
Gosub CalcVoltage
LCDout $FE,2,"Solar= ",DEC Volts/10,".",DEC1 Volts Dig 0," Vdc"
ADCin 1, AD
Res1 = 2200 ' Change these to match your Voltage divider
Res2 = 1000 ' resistor values for the Battery
Gosub CalcVoltage
LCDout $FE,$C0,"Batt = ",DEC Volts/10,".",DEC1 Volts Dig 0," Vdc"
goto GetReadings
CalcVoltage:
Rt = Res1 + Res2 ' Total resistance of Voltage Divider
Volts = AD * Rt ' Scale the AD reading accordingly
Volts = DIV32 Res2
Volts = Volts * 50 ' Convert AD to Voltage
Volts = DIV32 1023
Re: ssd1306 Include Question
The ssd1306 has no support for setting individual pixels because the smallest write sets 8 pixels as a minimum and the i2c versions have no method to read back displayed data.
richard Today, 00:21so my small footprint...
