Wire SDA and SDC to your pic (using 4.7k pullups) and ground A0 and A1 (or change the address in the code). For TMP101, A1 is replaced by ALERT which you can wire to an interrupt pin of the PIC.
When powered up, the TMP100 does automatic sampling. The following line can be sent to configure the sensor to 12bit resolution:
SCLpin VAR PORTB.6 SDApin VAR PORTB.4 TempH VAR Byte TempL VAR Byte I2CWRITE SDApin,SCLpin,$90,$01,[%01100100] 'Set continuous sampling at 12bit resolution I2CREAD SDApin,SCLpin,$90,$00,[TempH,TempL] 'Read temperature sample
SCLpin VAR PORTB.6 SDApin VAR PORTB.4 TempH VAR Byte TempL VAR Byte I2CWRITE SDApin,SCLpin,$90,$01,[%01100101] 'Set 12 bit resolution, turn sensor off SamplingLoop: I2CWRITE SDApin,SCLpin,$90,$01,[%11100101] 'one-shot sample PAUSE 350 I2CREAD SDApin,SCLpin,$90,$00,[TempH,TempL] 'Read temperature sample GOTO SamplingLoop
Temperature is read as a 16 bit value (TempH being MSB and TempL LSB). Here is the conversion routine to display the value on LCD (initialize your LCD first!):
TempSign VAR Byte
TempDec VAR Word
'Convert temperature to LCD
ConvertTemp:
IF TempH.7 = 1 THEN
TempSign = "-"
TempL = TempL ^ %11110000 'bitwise invert on the 4 MSB
TempL = TempL + 16 'adding 1 temperature unit
TempH = TempH ^ %11111111 'bitwise invert
IF TempL = 0 THEN
TempH = TempH + 1
TempSign = "+"
TempDec = 0
IF TempL.7 = 1 THEN TempDec = 5000
IF TempL.6 = 1 THEN TempDec = TempDec + 2500
IF TempL.5 = 1 THEN TempDec = TempDec + 1250
IF TempL.4 = 1 THEN TempDec = TempDec + 625
LCDOUT $FE,1, TempSign, #TempH, ".", #TempDec DIG 3, #TempDec DIG 2, #TempDec DIG 1, #TempDec DIG 0, "°C"
lester Today, 06:43
