Let me do a modest contribution by wrapping it all into a single routine that identify everything from 24LC00 to 24LC512. This is provided that pins A0, A1, and A2 of the I2C memory = 0 (grounded). A later evolution would be to add address detection as well.
<<< DOWNLOAD THE FILE HERE: EEPROM_detect.pbp >>>
SOURCE CODE:
'* Name : EEPROM_detect.pbp *
'* Author : Antoine Bercovici *
'* Date : 02/10/2010 iEMMMt *
'* Version : 1.1 ......UMMMMMMMMMM. *
'* .,:i,:.. . .;AMMMMMMS *
'* :i:.. .WMMMM@ *
'* .i;. . YMMMMMMMWv YMMMMMi *
'* i:;. ..... @M#UU0MMMMMU ... 0MMMMMZ *
'* :EMMM, ......... oMMM0 .,.,.. oMMMMMMM *
'* i@MMMMMM ........... . MMMM ii;i;:, MMMMMMMM *
'* #MMMMMMMMS ..........,.,. .iBMMMM:.:iiiii,.7MMMMMMMM# *
'* MMMMMMMMMA .......,,iii,iMMMMMMM0 .:ii;iiii.oMMMMM@SM# *
'* .MMMMMMMMMM ...,.i:;ii:.7MMMAv. ,:ii;i;ii,,MMMMM2 vM. *
'* CM6AMMMMMMMU .,,ii;ii:: .; .,,ii;i;;;i;:i,MM#i ,M#@$ *
'* #M: 0MMMMMM@. ..iiiiii::MMMMM.ii;;;;;i;ii,iviQB MM0@ *
'* WM vMMMMMM0. ..,iii,,MMMMM::;i;i;i;i;vb@@#@I XQ@Mi *
'* :MMMMMMMS. ..,. :ci.,i::,,.:v7icM@bb@# MM1 *
'* @MMMMMMMM097;,..:i;ii;Yn$@n7;.MM#W0. BM$ *
'* 0MMMMMMMMMzzMM7XvQMMMMMM.i,. .#MY tMM *
'* CMMMMM@C2WMM .. MM$W@o nM# @E *
'* .6i WMBBS ,o$@v .MM. *
'* ,@U#0 bMb @M, *
'* M@S iM@ . *
'* BMn MM. *
'* 7M$ ib *
'* .MM *
'* C6 *
'* USAGE 1. Place INCLUDE EEPROM_detect.pbp within your program and *
'* modify the user defined variable below to suit your program *
'* 2. Call first ReadMemoryIDTag routine to identify the EEPROM by *
'* its ID tag. If no ID tag is present the program will perform *
'* data destructive identification on the EEPROM followed by a *
'* complete erase. Result of identification is given by *
'* variables MemType, MemSize and PageSize *
'* 3. Call MemoryErase when you need to perform full erase *
'* 4. Call MemoryRead when you need to read data at MemAddressLong *
'* address. Data is retrieved in DataValue *
'* 5. Call MemoryWrite to write DataValue at MemAddressLong *
'Variable declaration for controlling the EEPROM
MemAddressLong VAR WORD '16 bit address variable for memory from 24C32 to 24C512
MemAddress VAR BYTE '8 bit address variable for memory up to 24C16
Control VAR BYTE 'Control byte for EEPROM test
MemType VAR BYTE 'Type of memory after size control: 11=24C00, 10=24C01, 9=24C02, 8=24C04, 7=24C08, 6=24C16, 5=24C32, 4=24C64, 3=24C128, 2=24C256, 1=24C512
PageSize VAR BYTE 'Size of memory pages in bytes
PageSizeBis VAR BYTE 'For internal use
MemSize VAR WORD 'Size of EEPROM in bytes
Blank VAR BYTE [16] 'Define EEPROM blanking array
WriteDelay VAR BYTE 'Delay after writing to EEPROM
TagAddress VAR BYTE 'EEPROM ID tag
DataValue VAR BYTE 'Data to be written in EEPROM
InternalCounter VAR BYTE 'For internal use
'MODIFY THESE VARIABLES TO SUIT YOUR APPLICATION
SCLpin VAR PORTB.6 'SCL Pin
SDApin VAR PORTB.4 'SDA Pin
Writedelay = 5 'Use a 5ms delay between write operations, Increase to 10 if needed by your EEPROM
TagAddress = 12 'EEPROM address where you want to record your ID tag (from 0 to 15, limited by 24C00)
'EEPROM Size detection for 24C16 and smaller (8bit Address)
MemorySizeCheck:
FOR InternalCounter = 6 to 11
MemAddress = 255
Control = %10100000
If InternalCounter = 6 then Control = %10101110
If InternalCounter = 7 then Control = %10100110
If InternalCounter = 8 then Control = %10100010
IF InternalCounter = 10 THEN MemAddress = 127
IF InternalCounter = 11 THEN MemAddress = 15
I2CWRITE SDApin, SCLpin, Control, MemAddress, [InternalCounter]
PAUSE WriteDelay
NEXT InternalCounter
I2CRead SDApin, SCLpin, %10101110, 255, [MemType]
IF MemType = 6 THEN GOTO DoneChecking
I2CRead SDApin, SCLpin, %10100110, 255, [MemType]
IF MemType = 7 THEN GOTO DoneChecking
I2CRead SDApin, SCLpin, %10100010, 255, [MemType]
IF MemType = 8 THEN GOTO DoneChecking
I2CRead SDApin, SCLpin, %10100000, 255, [MemType]
IF MemType = 9 THEN GOTO DoneChecking
I2CRead SDApin, SCLpin, %10100000, 127, [MemType]
IF MemType = 10 THEN GOTO DoneChecking
I2CRead SDApin, SCLpin, %10100000, 15, [MemType]
IF MemType = 11 THEN GOTO DoneChecking
IF MemType < 6 OR MemType > 11 THEN
GOSUB BigMemorySizeCheck
'EEPROM Size detection for 24C32 to 24C512 (16bit Address)
MemAddressLong = 65535
FOR InternalCounter = 1 TO 5
Control = %10100000
I2CWRITE SDApin, SCLpin, Control, MemAddressLong, [InternalCounter]
MemAddressLong = MemAddressLong >> 1
PAUSE WriteDelay
I2CRead SDApin, SCLpin, Control, MemAddressLong, [MemType]
DoneChecking:
IF MemType = 0 OR MemType > 10 THEN
MemSize = 0
IF MemType = 11 THEN MemSize = 15
MemSize = 65535 >> (MemType - 1)
IF (MemType > 10) OR (MemType = 0) THEN
PageSize = 0
PageSize = 8
IF MemType < 9 THEN PageSize = 16
IF MemType < 6 THEN PageSize = 32
IF MemType < 4 THEN PageSize = 64
IF MemType = 1 THEN PageSize = 128
'Read EEPROM
MemoryRead:
Control = 160
SELECT CASE MemType
CASE 11, 10, 9, 8, 7, 6
MemAddress = MemAddressLong.byte0
IF MemAddressLong.8 = 1 THEN Control = Control + 2
IF MemAddressLong.9 = 1 THEN Control = Control + 4
IF MemAddressLong.10 = 1 THEN Control = Control + 8
I2CREAD SDApin, SCLpin, Control, MemAddress, [DataValue]
CASE 5, 4, 3, 2, 1
I2CREAD SDApin, SCLpin, Control, MemAddressLong, [DataValue]
END SELECT
'Write EEPROM
MemoryWrite:
Control = 160
SELECT CASE MemType
I2CWRITE SDApin, SCLpin, Control, MemAddress, [DataValue]
CASE 5, 4, 3, 2, 1
I2CWRITE SDApin, SCLpin, Control, MemAddressLong, [DataValue]
END SELECT
PAUSE WriteDelay
'Erase EEPROM
MemoryErase:
GOSUB MemorySizeCheck
For InternalCounter = 0 to 15 'Fill Blank array with blank data for EEPROM
Blank[InternalCounter] = $FF
Next InternalCounter
SELECT CASE MemType
CASE 11
Control = 160
For MemAddress = 0 TO MemSize
I2CWRITE SDApin, SCLpin, Control, MemAddress, [$FF]
Pause WriteDelay
NEXT MemAddress
CASE 10, 9, 8, 7, 6
PageSizeBis = PageSize / 2
For Control = 160 TO 174 STEP 2
FOR MemAddress = 0 to MemSize Step PageSize
I2CWRITE SDApin, SCLpin, Control, MemAddress, [STR Blank\PageSizeBis, STR Blank\PageSizeBis]
Pause WriteDelay
NEXT MemAddress
IF MemType = 1 OR MemType = 2 THEN GOTO WriteMemoryIDTag
IF MemType = 3 AND Control = 162 THEN GOTO WriteMemoryIDTag
IF MemType = 4 AND Control = 166 THEN GOTO WriteMemoryIDTag
NEXT Control
CASE 5, 4, 3, 2, 1
PageSizeBis = PageSize / 8
FOR MemAddressLong = 0 to MemSize Step PageSize
I2CWRITE SDApin, SCLpin, 160, MemAddressLong, [STR Blank\PageSizeBis, STR Blank\PageSizeBis,_
Pause WriteDelay
NEXT MemAddressLong
END SELECT
WriteMemoryIDTag:
MemAddressLong = TagAddress
DataValue = MemType
GOSUB MemoryWrite
'Retrieve preprogrammed EEPROM ID tag at address TagAddress
ReadMemoryIDTag:
MemAddress = TagAddress
I2CREAD SDApin, SCLpin, %10100000, MemAddress, [MemType]
IF MemType = 0 OR MemType > 11 THEN
I2CREAD SDApin, SCLpin, %10100000, MemAddressLong, [MemType]
GOSUB MemoryErase
GOSUB DoneChecking
Note that the EEPROM detection routine does erase part of the data, and should not be used on a memory that contain code. To perform a "data safe" identification, a location in EEPROM is chosen for subsequent ID.
- Place EEPROM_detect.pbp within your project file and call INCLUDE EEPROM_detect.pbp within your program. Some declarations needs to be modified within EEPROM_detect.pbp: change SDApin and SCLpin to match your I/O ports, and declare an EEPROM address where you'd like the ID tag to be stored (provided it exists in the smallest memory, the 24C00).
- Call first ReadMemoryIDTag routine in your program initialization to identify the EEPROM by its ID tag. If no ID tag is present the program will perform data destructive identification on the EEPROM followed by a complete erase. Result of identification is given by the following variables:
MemType (11=24C00, 10=24C01, 9=24C02, 8=24C04, 7=24C08, 6=24C16, 5=24C32, 4=24C64, 3=24C128, 2=24C256, 1=24C512)
MemSize (15, 127, 255, 511, 1023, 2047, 4095, 8191, 16383, 32767, 65535, 0=detection failed) in bits
PageSize (0, 8, 16, 32, 64, 128) in bytes per pages
- Call MemoryErase routine when you need to perform full memory erase within your program. A 24C512 takes about 5 seconds to be erased with page-write mode.
- Call MemoryRead routine when you need to read data. Use MemAddressLong variable (WORD) as your address pointer, data will be dumped in DataValue.
- Call MemoryWrite routine when you need to write data. Use MemAddressLong variable (WORD) as your address pointer, place data in DataValue.
SAMPLE CODE:
Below is a quick and dirty little example that identify an EEPROM and display results on LCD (add all the defines for your LCD).
'******************************************************* 'Display EEPROM size on LCD '******************************************************* INCLUDE EEPROM_detect.pbp GOSUB ReadMemoryIDTag LCDOUT $FE,1, "Memory type:" Select CASE MemType CASE 11 LCDOUT $FE,$C0, "24LC00, 16B" CASE 10 LCDOUT $FE,$C0, "24LC01, 128B" CASE 9 LCDOUT $FE,$C0, "24LC02, 256B" CASE 8 LCDOUT $FE,$C0, "24LC04, 512B" CASE 7 LCDOUT $FE,$C0, "24LC08, 1kB" CASE 6 LCDOUT $FE,$C0, "24LC16, 2kB" CASE 5 LCDOUT $FE,$C0, "24LC32, 4kB" CASE 4 LCDOUT $FE,$C0, "24LC64, 8kB" CASE 3 LCDOUT $FE,$C0, "24LC128, 16kB" CASE 2 LCDOUT $FE,$C0, "24LC256, 32kB" CASE 1 LCDOUT $FE,$C0, "24LC512, 64kB" CASE ELSE LCDOUT $FE,$C0, "Not recognized" END SELECT
lester Today, 06:43
