Well, the way I achieve that is to take say 16 ADC readings, sort them in sequential order of value, junk the top and bottom four readings as being 'out-of-range', sum and average the middle eight... this makes ADC readings in industrial applications pretty much bomb-proof...
Now, whilst there's quite a few tricks and treats within this, here's a simple sort routine for doing just that (when you analyse it, it's pretty similar to your example Trent albeit a little more compact)... The Data to be sorted sits in an array called RawData, and when it falls out of the subroutine, RawData is in sequential order. Change DataA and RawData variables to WORDS if you need them. Those that know will notice that the additional variable DataA is only needed because PBP's SWAP command doesn't work with arrays.
CounterA var Byte
DataA var Byte
RawData var Byte [16]
' Sort Array
SortArray:
CounterA=0
SortLoop:
If RawData(CounterA+1) < RawData(CounterA) then
DataA=RawData(CounterA)
RawData(CounterA)=RawData(CounterA+1)
RawData(CounterA+1+0)=DataA
If CounterA > 0 then CounterA=CounterA-2
CounterA=CounterA+1
If CounterA < 15 then goto SortLoop
;Initialize your hardware first
A VAR WORD
B VAR WORD
TempA VAR WORD
TempB VAR WORD
LCDOUT $FE,1
For A = 0 to 65535
LCDOUT $FE,2,"A=",DEC A
For B = 0 to 65535
TempA = A
TempB = B
TempA = TempA ^ TempB
TempB = TempA ^ TempB
IF (TempA <> B) OR (TempB <> A) THEN ; Test Failed
LCDOUT $FE,1,"Test Failed",$FE,$C0,"A=",DEC A,", B =",DEC B
STOP
Next B
Next A
LCDOUT $FE,1,"Test Passed!"
STOP
you would no doubt see the message "Test Passed!" on the LCD.
Only a half hour into it, but it's still passing. Kinda obvious what the result will be.
Update: 43hrs, Test Passed! (obviously)
CuriousOne Yesterday, 15:088 note polyphony with multiple sinewave per single note.
