Want to install a virtual Comm port on your PC?
Want to send serial commands to your PIC?
Its REALLY easy! Here's how.
Get yourself a PIC18F2455/2550/4455 chips that has USB support. And connect the Usb to to your PIC as shown below.
Note if using the USB bus power to power your pic remember that the max current your pic circuit can draw is 100ma! Anymore and you may blow your usb port! If in doubt stick in a fuse, or use external power.
For this demo though you can safely use the Bus Power. Mecanique has a good circuit diagram you can follow here. http://www.mecanique.co.uk/products/...atic-large.gif
Pin Name Cable color Description
1 VCC Red +5 VDC (Vdd)
2 D- White Data - (RC4)
3 D+ Green Data + (RC5)
4 GND Black Ground (Vss)
Once your hardware is setup follow on....
STEP ONE.
In your PBP folder, copy the entire contents of the USB18 folder into a new folder where you store your pic programs;
eg... copy c:\pbp\usb18\*.* c:\cdcdemo
STEP TWO.
Open the USB descriptors file (called USBDESC.asm)
There are three lines of code in there, change the ; so that CDCDESC.ASM is used.
; include "MOUSDESC.ASM" ; USB descriptors for mouse demo
; include "JADESC.ASM" ; USB descriptors for Jan Axelson's demo
include "CDCDESC.ASM" ; USB descriptors for CDC demo
Copy this code and save it into the c:\cdcdemo folder and then compile using pbp.
DEFINE OSC 48
Buffer VAR BYTE[16]
Cnt VAR BYTE
B0 VAR BYTE
B1 VAR BYTE
ADCON1 = 15 ' Set all I/Os to Digital
CMCON = 7 ' Disable Comparators
Cnt = 16
USBInit ' Initialize USART
for b0 = 0 to 15
lookup b0,["USB CONNECTED!",10,13],B1
BUFFER(B0) = B1
NEXT B0
' Main Program Loop
Loop:
USBService ' Must service USB regularly
USBOut 3, Buffer, Cnt, loop
goto loop
run your progam.
Windows will detect the PIC as a USB device and install the Microchip CDC driver.
STEP FOUR.
Open up Hyperteminal and select the virtual comport that was just installed. you should see USB CONNECTED! repeated.
Congratulations, you can send data from the PIC to the PC via a quasi Serial connection.
Ok How about sending and receiving data?
Program this code below into your pic:
buffer Var Byte[16]
cnt Var Byte
LED Var PORTB.0
Define OSC 48
USBInit
Low LED ' LED off
' Wait for USB input
idleloop:
cnt = 1 ' Specify input buffer size
USBIn 3, buffer, cnt, idleloop
' Message received
Toggle LED
outloop:
USBOut 3, buffer, cnt, outloop
Goto idleloop ' Wait for next buffer
Try sending a large text file. Does it keep up?
Wow your becoming an expert now aren't you!
Stay Tuned....
Squib
lester Yesterday, 06:43
