Since this question has come up again, I thought I'd throw this module out to the masses. It is something I worked on a while back, with DT's help. Amid life's other priorities, it got put on the shelf to collect dust.
The basic idea is that by adding the module as an INCLUDE and inserting a couple of commands inside your code, you can have the PIC send timing data to your PC via the hardware serial port. It's made for 18F PICs (although some 16Fs may work too). You also need a timer that is not being used for anything else.
1) Instructions are included, as well as a small example.
2) It worked well for me, and as I recall, DT in testing.
3) Use it however you want.
4) I won't be able to offer much support, but figure there are enough knowledgeable folks around here that can help those who need it.
Best Regards,
SteveB
Thanks Darrel for all your help!
This is code partially generated by Claude. However, it gives assembly error on compilation. As I can understand, it has something to do with variables?
CuriousOne Today, 11:36ty;----[16F1937 Hardware...
