Have been using Richard's include for the SSD1306 (32*128) display with sucess.
I was now trying to display a single dot which would move on the display according to an X and Y...
Sorry for late reply :)
All I need is for it to play loud and clear.
I've added extra RC filtering circuit, as shown in manual, also I have external transistor amplifying the sound, but output is...
The loop in one line:
Claude scopes and specifies → Local LLM writes each module → Claude reviews each module → Local LLM fixes → Claude does integration review → Warp builds, flashes, and...
And in plain English, which will use more tokens , but is way easier to understand
Same example: WiFi-connected ESP32 that monitors a digital input, logs state changes with a timestamp to internal...
Because FREQOUT is using PWM with the ability to output two tones at the same time, so filtering is required to produce a, relatively clean, sinewave-looking tone.
As posted above, the two commands work completely different so one cannot compare them.
Ioannis Today, 20:17They were designed for different tasks.
What exactly is your need?
If you need one tone only, use...
