From £154.90 |
Buy it Now melabs U2 Programmer with Accessories - $119.95 Our second-generation USB programmer for PIC® MCUs More than 300 PIC microcontrollers are supported! Support for future devices can be added via FLASH firmware updates. Intelligent voltage regulation allows programming of the new, low-voltage PIC® MCUs as well as standard five-volt devices. The U2 is powered by the USB port. No additional external power adapter is needed! The 10-pin programming connection is compatible with all earlier versions of melabs Programmers. If you are upgrading from an melabs EPIC, Serial, or USB Programmer, your existing programming adapters and in-circuit programming (ICSP) cables will work with the U2. Programming Adapters: We offer an extensive line of programming adapters that allow you to program devices in DIP, Surface Mount, and PLCC packages. To find an adapter to fit the part/package that you need to program, see our Programming Adapters section.
The same software that controls the U2 Programmer can be used with all models of our programmers, including EPIC parallel port programmers and melabs Serial Programmer. The software can even control multiple programmers on one computer. The software allows you to set configuration bits on the PIC with an easy-to-use list of options. Each configuration option is selectable in a drop-down list. Configuration data may be read from a hex file or from a PIC. The consolidated view-memory window lets you view each section of memory in the PIC with a click. A formidable list of options allow you to customize the way you interact with the software. You control what areas of the device are erased, programmed, and verified. Save mouse clicks with options like "Disable completion messages" and "Erase before programming". The programmer's firmware can be upgraded electronically with the click of the mouse. You don't have to worry about whether your hardware is compatible when purchasing a software upgrade. Any required firmware changes will be included in the purchased upgrade.
melabs USB Programmer Features:
Current device support, melabs USB Programmer for Windows 98/Me/NT/2000/XP:PIC10F200, 10F202, 10F204, 10F206, 10F220, 10F222: Supported using 10F Adapter.PIC12C508(A), 12C509(A), 12C671, 12C672, 12CE518, 12CE519, 12CE673, 12CE674, 12F508, 12F509, 12F510, 12F629, 12F615, 12F635, 12F675, 12F683, 12HV615: Supported using 840Z Adapter. PIC14000: Supported using PIC14000 ZIF Adapter. PIC16C432, 16C433: Supported using In-Circuit Serial Programming. PIC16C52, 16C54, 16C55, 16C56, 16C57, 16C58, 16HV540: Not supported. PIC16C505, 16C554, 16C557, 16C558, 16C61, 16C62(AB), 16C620(A), 16C621(A), 16C622(A), 16CE623, 16CE624, 16CE625, 16C63(A), 16C64(A), 16C642, 16C65(AB), 16C66, 16C662, 16C67, 16C71, 16C710, 16C711, 16C712, 16C715, 16C716, 16C717, 16C72(A), 16C73(AB), 16C74(AB), 16C745, 16C76, 16C765, 16C77, 16C773, 16C774, 16C84: Supported using 840Z Adapter. PIC16C770, 16C771, 16C781, 16C782: Supported using 840Z Adapter. PIC16C923, 16C924, 16C925, 16C926: Supported using 68 Pin PLCC Adapter. PIC16F505, 16F506, 16F54, 16F616, 16F627(A), 16F628(A), 16F630, 16F631, 16F636, 16F639, 16F648A, 16F676, 16F677, 16F684, 16F685, 16F687, 16F688, 16F689, 16F690, 16F716, 16F72, 16F73, 16F737, 16F74, 16F747, 16F76, 16F767, 16F77, 16F777, 16F785, 16F818, 16F819, 16F83, 16F84(A), 16F87, 16F870, 16F871, 16F872, 16F873(A), 16F874(A), 16F876(A), 16F877(A), 16F88, 16F883, 16F884, 16F886, 16F887, 16F913, 16F914, 16F916, 16F917, 16HV616, 16HV785: Supported using 840Z Adapter. PIC16F57: Supported using F5 28-Pin ZIF Adapter. PIC16F59: Supported using F5 40-Pin ZIF Adapter. PIC16F946: Supported using 64TQFP Adapter. PIC17C42(A), 17C43, 17C44: Not supported. PIC17C752, 17C756(A): Supported using 1768 PLCC Adapter. PIC17C762, 17C766: Supported using 1784 PLCC Adapter. PIC18C242, 18C252, 18C442, 18C452: Supported using 840Z Adapter. PIC18C601, 18C658: Supported using 1868 PLCC Adapter. PIC18C801, 18C858: Supported using 1884 PLCC Adapter. PIC18F1220, 18F1230, 18F1320, 18F1330, 18F2220, 18F2221, 18F2320, 18F2321, 18F2331, 18F2410, 18F242, 18F2420, 18F2431, 18F2439, 18F2450, 18F2455, 18F248, 18F2480, 18F2510, 18F2515, 18F252, 18F2520, 18F2525, 18F2539, 18F2550, 18F258, 18F2580, 18F2585, 18F2610, 18F2620, 18F2680, 18F2682, 18F2685, 18F4220, 18F4221, 18F4320, 18F4321, 18F4331, 18F4410, 18F442, 18F4420, 18F4431, 18F4439, 18F4450, 18F4455, 18F448, 18F4480, 18F4510, 18F4515, 18F452, 18F4520, 18F4525, 18F4539, 18F4550, 18F458, 18F4580, 18F4585, 18F4610, 18F4620, 18F4680, 18F4682, 18F4685: Supported using 840Z Adapter. PIC18F6310, 18F6390, 18F6410, 18F6490, 18F6520, 18F6525, 18F6527, 18F6585, 18F6620, 18F6621, 18F6622, 18F6627, 18F6680, 18F6720, 18F6722: Supported using 1864 TQFP Adapter. PIC18F8310, 18F8390, 18F8410, 18F8490, 18F8520, 18F8525, 18F8527, 18F8585, 18F8620, 18F8621, 18F8622, 18F8627, 18F8680, 18F8720, 18F8722: Supported using 1880 TQFP Adapter. PIC18F24J10, 18F25J10, 18F44J10, 18F45J10, 18F63J11, 18F63J90, 18F64J11, 18F64J90, 18F65J10, 18F65J11, 18F65J15, 18F65J90, 18F66J10, 18F66J15, 18F66J60, 18F66J65, 18F67J10, 18F67J60, 18F83J11, 18F83J90, 18F84J11, 18F84J90, 18F85J10, 18F85J11, 18F85J15, 18F85J90, 18F86J10, 18F86J15, 18F86J60, 18F86J65, 18F87J10, 18F87J60, 18F96J60, 18F96J65, 18F97J60, 18LF24J10, 18LF25J10, 18LF44J10, 18LF45J10: Supported using In-Circuit Serial Programming. PicStic1, PicStic1 2K, PicStic2, PicStic2 2K, PicStic3, PicStic 3 2K, PicStic4, PicStic4 2K, and PicStic5: Supported using PicStic Adapter. rfPIC12C509AG: Supported using 840Z Adapter. rfPIC12C509AF, rfPIC12F675F, 675H, 675K: Supported using 20 Pin SSOP Adapter. dsPIC30F2010, 30F2011, 30F2012, 30F3010, 30F3011, 30F3012, 30F3013, 30F3014, 30F4011, 30F4012, 30F4013: Supported using dsPIC ZIF Adapter. dsPIC30F5011, 30F5015, 30F6011A, 30F6012A, 30F6015: Supported using dsPIC 64 Pin TQFP Adapter. dsPIC30F5013, 30F5016, 30F6010A, 30F6013A, 30F6014A: Supported using dsPIC 80 Pin TQFP Adapter. dsPIC30F6010, 30F6011, 30F6012, 30F6013, 30F6014: Supported using ICSP. MCP25020, 25025, 25050, 25055: Supported using MCPZ Adapter. |
Yes sure.
