DT Instant Interrupts
Results 1 to 39 of 39
    Sep 2007
    Default DT Instant Interrupts
    Hello All,
    Darrel,
    I love the Instant Interrupts. Is it possible to use it with multi SPWM? I need a system LED that just blinks at a constant speed like 4 times a second. to show that the pic is working.
    Best Regards,
    Kurt A. Kroh
    KrohTech
    “Goodbye and thanks for all the fish”
    I rewrote the old SPWM module to work with DT_INTS some time ago.
    DT_INTS-14 (SPWM_INT - Multiple Software PWM)
    http://darreltaylor.com/DT_INTS-14/SPWM.html
    But if you just want to blink an LED at a certain rate, the Timer Template might be more appropriate.
    DT_INTS-14 (Timer Template)
    http://darreltaylor.com/DT_INTS-14/TimerTemplate.html
    <br>
    Sep 2007
    Oh, sorry I forgou to mention I am using an 18F PIC. Can I use the timer template -14?
    Best Regards,
    Kurt A. Kroh
    KrohTech
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by krohtech View Post
    You're talking about one of my favorite 'staples' whenever I build something...I call it a 'heartbeat'...
    I have an LED connected to a specific pin...
    I set up Timer 0 to run at a decent rate according to my main clock speed...i.e. once per second-ish, 4 times per second-ish, doesn't really matter, as long as I can see it blink.
    Then every Timer 0 overflow, I increment a byte variable, last I set the LED to follow a certain bit of that variable.
    So, say I use 'temp' as my variable.
    myint:
    temp = temp + 1
    led = temp.0 'led will flash on/off every other time thru loop
    resume
    If the LED flashes too fast, I use temp.1, still too fast, maybe temp.2.
    Or, conversely, if I use temp.4, and that flash is too slow, I'll use temp.3, or temp.2, whatever...until I find a flash rate that works for me.
    DT's Fast interrupts and SSPWM code are great pieces of code...but I think they're big time overkill for what you want...
    An example cut from one of my last programs:
    'CONFIG statements semi-permanently set in PBP 18F4620 .INC file
    resetplaceholder:	'18f4620 code
    DEFINE OSC 10
    DEFINE NO_CLRWDT 1	'no extra clear watchdog timer instructions
    DISABLE
    CLEAR
    led1 var porta.5
    heartbeat var byte
    startupholder:
    goto skipsubs	'skip over all the commonly used subroutines
    ON INTERRUPT GOTO INTHANDLER
    DISABLE
    INTHANDLER:	if intcon.2 = 1 then			'timer 0 overflow interrupt handler
    			intcon.2 = 0
                           heartbeat = heartbeat + 1
                            led1 = heartbeat.0		'led flash about every ~1.6 seconds
    ' change heartbeat.0 to heartbeat.X where x = 0 - 7 to change heart beat flash rate
    INTFINISH:
    RESUME
    DISABLE
    'end of commonly used subroutines, skipsubs block for setting up registers, lcd, whatever else...
    skipsubs:
    	t0con = $84
            intcon = $e0
            cmcon = 7
            pie2 = $80
            trisa = 0
            porta = 0
            led1 = 0
            output led1
    ' change prescale value in $84 to change flash rate
    ENABLE
    mainloop:
    ' do something useless or useful here
    goto mainloop
    IF you're not using a '4620, then you'll have to figure out which registers need which values as far as interrupt and timer registers go.
    I chose porta.5 because it was available. Change that to what you need also.
    Last edited by skimask; - 9th February 2008 at 06:53. Reason: Removed runny colons....nya nya... :D
    &nbsp; ... and ...
    Oh, sorry I forgou to mention I am using an 18F PIC. ...
    I'm thinking just the Blinky example is all you need.
    DT_INTS-18 (Blinky Light)
    http://darreltaylor.com/DT_INTS-18/blinky.html
    Or, even better ...
    DT_INTS-18 (Assembly Language Interrupts)
    http://darreltaylor.com/DT_INTS-18/asm_ints.html
    Same Blinky LED, without the Basic Language Interrupt overhead.
    And no running Colon's
    <br>
    Sep 2007
    Yes, this is the code I am using but I can't get it working in the same program as the multi SPWM. I am useing multi SPWM for my 8 pwm dimmers.
    Also I have played with the prescaler to slow down the blink rate but have had no sucess. is there a formula for this like in the -14 version?
    I will also make an attempt to digest Skymask's timer 0 overflow interrupt handler in the morning.
    Thanks Darrel and Skymask. You are both very helpful.
    Best Regards,
    Kurt A. Kroh
    KrohTech
    The original SPWM will not work with Instant Interrupts.
    They both want complete control of the interrupts. (can't happen)
    However, SPWM_INT will work with Instant Interrupts.
    And yes, the version shown in the -14 section will work on the 18F's too.
    SPWM_INT uses Timer1, so if you also want a Blinky light, you'll need to use a different Timer. (0, 2 or 3)
    And if you want to use either of the SPWM versions, then you can't use skimask's code.
    They are not compatible with ON INTERRUPT.
    <br>
    skimask's Avatar
    skimask Guest
    <br>
    And if you want my opinion (nobody really does, but that's beside the point), you'd do real good to learn how to use DT's Instant Interrupt's instead of relying on PBP's On Interrupt.
    It's not only good coding with good applications, you just plain learn a lot in the process...and then you spend more money and more time on PICs and PBP and less time on...well, wait a minute...gotta eat sometime...right?
    Sep 2007
    I have SPWM_INT working really well. I am doing 16 ch of PWM on a pic 18F2410 32 MHz. The pwm is running at 100Hz 8 bit resolution.
    <br>
    Here is where I am having trouble. I tried to add a blinky from the DT_INTS-18 example and change it to timer0 with no success. Darrel, can you point me in the correct direction?
    Best Regards,
    Kurt A. Kroh
    KrohTech
    Sep 2007
    here is my current code, changed to 101 PWM resolution to reduce overhead
    '-----------------------------SPWM INT-----------------------------
    CLEAR
    INCLUDE "DT_INTS-18.bas"            ; Base Interrupt System
    INCLUDE "SPWM_INT.bas"              ; Software PWM module
    INCLUDE "ReEnterPBP-18.bas"    ; Include if using PBP interrupts
    LED2 VAR PORTA.5
    DEFINE SPWM_FREQ  100                ; SPWM Frequency
    DEFINE SPWM_RES   101               ; SPWM Resolution
    DutyVars   VAR BYTE[16]              ; DutyCycle Variables
      DutyVar1 VAR DutyVars[0]          ; group them in an array for easy access
      DutyVar2 VAR DutyVars[1]          ; with FOR loops etc.
      DutyVar3 VAR DutyVars[2]
      DutyVar4 VAR DutyVars[3]
      DutyVar5 VAR DutyVars[4]
      DutyVar6 VAR DutyVars[5]
      DutyVar7 VAR DutyVars[6]
      DutyVar8 VAR DutyVars[7]
      DutyVar9 VAR DutyVars[8]
      DutyVar10 VAR DutyVars[9]
      DutyVar11 VAR DutyVars[10]
      DutyVar12 VAR DutyVars[11]
      DutyVar13 VAR DutyVars[12]
      DutyVar14 VAR DutyVars[13]
      DutyVar15 VAR DutyVars[14]
      DutyVar16 VAR DutyVars[15]
    SPWM_LIST  macro                    ; Define Pin's to use for SPWM
         SPWM_PIN  PORTB, 0, _DutyVar1  ; and the associated DutyCycle variables
         SPWM_PIN  PORTB, 1, _DutyVar2  ; Notice the underscore before variables
         SPWM_PIN  PORTB, 2, _DutyVar3
         SPWM_PIN  PORTB, 3, _DutyVar4
         SPWM_PIN  PORTB, 4, _DutyVar5
         SPWM_PIN  PORTB, 5, _DutyVar6
         SPWM_PIN  PORTB, 6, _DutyVar7
         SPWM_PIN  PORTB, 7, _DutyVar8
         SPWM_PIN  PORTC, 0, _DutyVar9
         SPWM_PIN  PORTC, 1, _DutyVar10
         SPWM_PIN  PORTC, 2, _DutyVar11
         SPWM_PIN  PORTC, 3, _DutyVar12
         SPWM_PIN  PORTC, 4, _DutyVar13
         SPWM_PIN  PORTC, 5, _DutyVar14
         SPWM_PIN  PORTC, 6, _DutyVar15
         SPWM_PIN  PORTC, 7, _DutyVar16
      SPWM_INIT  SPWM_LIST              ; Initialize the Pins
            INT_Handler   TMR1_INT,  SPWMhandler,  ASM,  yes
            INT_Handler   TMR0_INT,  _ToggleLED2,  PBP,  yes
        INT_CREATE                      ; Creates the interrupt processor
    T0CON = %10010010             ; T0 = 16-bit, Prescaler 8
    @ INT_ENABLE  TMR1_INT        ; enable Timer 1 interrupts
    @ INT_ENABLE  TMR0_INT        ; enable Timer 0 interrupts
    '-----------------------------Main Program-----------------------------
    Best Regards,
    Kurt A. Kroh
    KrohTech
    I think the Cut&Paste didn't catch everything.
    Can you post the Main: and Handler parts?
    Thanks.
    OH!, nevermind!
    ADCON1 = $0F
    Sep 2007
    Thanks Darrel,
    That worked, I think I need to learn that register, TIME TO HIT THE DATA SHEET...
    Best Regards,
    Kurt A. Kroh
    KrohTech
    Thumbs up
    That's a good one to learn.
    You'll need some variation of it in almost every program you write.
    Also, Since the TMR0_INT handler is only toggling a pin, it's not using any PBP system variables.
    You can change the TMR0_INT's "Type" to ASM.
    Then it won't be saving all the system variables when it doesn't need to. Time is critical with that many simultaneous PWM's.
    Then you can remove the ReEnterPBP-18.bas include file, which will save some RAM and Code space.
    Sep 2007
    Thanks again Darrel,
    I just fully tested the SPWM_INT running 16 channels @ 100Hz 0-100 resolution. I tested each channel with a 7 amp led cluster (Agilight Brightstrip see below) of typical sign led strips powered through a MOSFET. This worked great. I am able to dim all the way down to 1% without any flicker and smoothly fade up to 100% with no flicker or noticeable stair stepping effect. This is smoother than when I used the older multi SPWM program.
    I really appreciate you help
    http://www.agilight.com/brightstrip/index.htm
    Best Regards,
    Kurt A. Kroh
    KrohTech
    Thumbs up
    Great Testimonial Kurt!
    Mind if I use it on my website?
    <br>
    I may missed that little but critical details. Are these described somewhere Darrel?
    And may be others too that I am not aware off...
    Sep 2007
    <br>
    Darrel,
    Feel free to use my testimonial in any way you see fit.
    Best Regards,
    Kurt A. Kroh
    KrohTech
    Thanks Kurt!
    Ioannis,
    I've mentioned it a couple times here in the forum, but I just spent about an hour trying to find them, and failed.
    I really should write some more pages for the website.
    Anyone got a Cloning Machine? I need another Me.
    Sep 2007
    Hay Darrel,
    In the DT_INTS-14 (SPWM_INT - Multiple Software PWM) It says:
    DutyVars   VAR BYTE[3]              ; DutyCycle Variables
    I do not know how to use arrays or how it can benefit in loops. The way I am doing it now is very cumbersome and code intensive. I have searched the forum and RTFM but I can't get my head around how this concept. Can anyone point me in the correct direction.
    Best Regards,
    Kurt A. Kroh
    KrohTech
    Default Simple example ...
    If you wanted to set all LED's to the same brightness, you could ...
    LoopCount  VAR BYTE
    FOR LoopCount = 0 to 15         ; 16 channels
        DutyVars(LoopCount) = 50    ; 50% (0-100)
    NEXT LoopCount
    <br>
    LoopCount  VAR BYTE
    NEXT LoopCount
    <br>
    Hi Darrel,
    could you please explain DutyVars(LoopCount) = 50 ; 50% (0-100), I understand the counter loop but do not understand the operation here. Thank You
    JS
    Sep 2007
    Hi Derrel,
    Thanks for the code, Unfortunately I was hoping for something that would allow me to set different values to the duty cycle of each channel. The way I have it configured I use CH# as the var name:
      CH1 VAR DutyVars[0]          ; group them in an array for easy access
      CH2 VAR DutyVars[1]          ; with FOR loops etc.
      CH3 VAR DutyVars[2]
      CH4 VAR DutyVars[3]
      CH5 VAR DutyVars[4]
      CH6 VAR DutyVars[5]
      CH7 VAR DutyVars[6]
      CH8 VAR DutyVars[7]
      CH9 VAR DutyVars[8]
      CH10 VAR DutyVars[9]
      CH11 VAR DutyVars[10]
      CH12 VAR DutyVars[11]
      CH13 VAR DutyVars[12]
      CH14 VAR DutyVars[13]
      CH15 VAR DutyVars[14]
      CH16 VAR DutyVars[15]
    and change the duty in this manor:
    gosub CKINPUT
    CH1 = 100
    CH2 = 0
    CH3 = 0
    CH4 = 0
    CH5 = 0
    CH6 = 0
    CH7 = 0
    CH8 = 0
    CH9 = 0
    CH10 = 0
    CH11 = 0
    CH12 = 0
    CH13 = 0
    CH14 = 0
    CH15 = 0
    CH16 = 0
    gosub CKINPUT
    PAUSE T5
    CH1 = 100
    CH2 = 100
    CH3 = 0
    CH4 = 0
    CH5 = 0
    CH6 = 0
    CH7 = 0
    CH8 = 0
    CH9 = 0
    CH10 = 0
    CH11 = 0
    CH12 = 0
    CH13 = 0
    CH14 = 0
    CH15 = 0
    CH16 = 0
    gosub CKINPUT
    PAUSE T5
    and so on... If anyone can suggest a better method I would be very interested in learning better ways to program.
    Best Regards,
    Kurt A. Kroh
    KrohTech
    skimask's Avatar
    skimask Guest
    gosub CKINPUT
    CH1 = 100
    CH2 = 0
    CH15 = 0
    CH16 = 0
    gosub CKINPUT
    PAUSE T5
    CH1 = 100
    CH2 = 100
    CH3 = 0
    CH4 = 0
    CH15 = 0
    CH16 = 0
    gosub CKINPUT
    PAUSE T5
    I don't see what the problem is...
    You've already got CH1 an as alias to DUTYCYCLE[0]...therefore:
    CH1 = 0 (or whatever)
    is equal to
    DUTYCYCLE[0] = 0 (or whatever)
    They are functionally equivalent....
    Therefore, if you had to use a loop:
    for temp = 0 to 16 : dutycycle[ temp ] = 0 : next temp
    would be equal to
    ch1 = 0
    ch2 = 0
    and so on until....
    ch15 = 0
    ch16 = 0
    Sep 2007
    Hi Skymask,
    Maybe I can clarify what I am trying to do. I didn’t post my entire code because it is very long. I will attach as a text file. I am designing a sign controller AKA sign animator AKA sign speller. What I need to do is CH1 ON pause X, add CH2 on Pause X, add CH3 pause X … This is an oversimplification but you can get the idea. It will allow me to program patterns left to right, right to left, center out, outside in, fade from left to right etc.
    I guess I was hoping for was some kind of nested for next loop with an array?
    I probably am not phrasing it correctly as I am a beginning programmer. Most of my experience is in programming large theatrical RGB lighting clusters which is not really programming in the same use of the word. I really haven’t “written code” since high school.
    I do appreciate all the help and am enjoying the journey!!!
    Best Regards,
    Kurt A. Kroh
    KrohTech
    skimask's Avatar
    skimask Guest
    Hi Skymask,
    Where do you plan on storing all of this data? On chip eeprom, program memory, off chip serial eeprom, CF card?
    I can see using a FONT table to store all of the characters, each character being a mini-array of points. Then depending on how you read out those points from that array, it may look like the character is shifting left/right/up/down, whatever.
    I think you need to setup an array of data and do matrix operations on that array when dealing with the full screen.
    I.E.
    4 x 4 array = 16 data points, array var byte[16]
    x / y = 4 / 4 = 16
    point 0,0
    x + (y*4) = point in array, in this case point 0, first byte in array
    point 3,3
    x + (y*4) = point in array, in this case point 15, last byte in array
    PBP doesn't do multi-dimensional arrays but you can easily overcome that with some simple math.
    Sep 2007
    Thanks Skimask
    I will have to play with this to absorb it. I will give it a try this weekend.
    Best Regards,
    Kurt A. Kroh
    KrohTech
    Sep 2007
    I was planning on storing the data in the program memory as it will probably not need to be changed once the sign is installed.
    Best Regards,
    Kurt A. Kroh
    KrohTech
    Default More Examples
    I don't know if I can explain the whole Arrays and Loops category. Would need a full book.
    But here's some more examples (untested) that might nurture some thoughts.
    Value       VAR BYTE
    X           VAR BYTE
    Y           VAR BYTE
    MarqueeCnt  VAR BYTE
    RepeatCnt   VAR BYTE
    Rnd         VAR WORD : Rnd = 123
    MaxChannel  CON 15
        Value = DIM
        GOSUB ALL2Value
        Pause 2000
        GOSUB Marquee
        GOSUB Scan
        GOSUB DoRandom
    GOTO Main
    Marquee:
        Value = 0
        Gosub ALL2value
        For RepeatCnt = 1 to 50
            MarqueeCnt = (MarqueeCnt + 1) // 4
            For X = 0 to MaxChannel STEP 4
                For Y = X to X + 3
                    Lookup ((Y-X) + MarqueeCnt),[0,25,75,25,0,25,75,25],Value
                    DutyVars(Y) = Value
                Next Y
            Next X
        Next RepeatCnt
    Scan:
        Value = 0
        Gosub ALL2value
        For RepeatCnt = 1 to 20
                DutyVars(X) = MED
                Pause 200
                DutyVars(X) = 0
            Next X
        Next RepeatCnt
    DoRandom:
        For RepeatCnt = 1 to 100
                RANDOM Rnd
                DutyVars(X) = Rnd // 100
            Next X
            Pause 200
        Next RepeatCnt
    ALL2value:
            DutyVars(X) = Value
        Next X
    HTH,
    Sep 2007
    Can anyone recomend a good book on PBP or BASIC that may help with the finer points of arrays and loops etc. I am very willing to read and research to learn more.
    Thanks Darrel,
    I will have more time this weekend to try this.
    Best Regards,
    Kurt A. Kroh
    KrohTech
    skimask's Avatar
    skimask Guest
    Can anyone recomend a good book on PBP or BASIC that may help with the finer points of arrays and loops etc. I am very willing to read and reserarch to learn more.
    Thanks Darrel,
    I don't think there really is such an animal as a book that would explain the finer points of loops/arrays, and such, and except for some oddball things about PBP variables (indexing and such), I'm kinda thinking that there aren't any finer points of loops and arrays.
    I think this is one of those cases when you have to play with the structure of the loops and arrays until you get it how you like it and can understand it the best, whether you pull the data from eeprom, or make it up on the spot or whatever.
    I think it boils down to your 'coding style' (many think my 'coding style' sucks for instance because I use too many colons).
    There are lots of good books on coding, I haven't read any of them (refer to the earlier statement about coding style).
    Quote Originally Posted by Joe S. View Post
    Hi Darrel,
    JS
    Anybody ???
    skimask's Avatar
    skimask Guest
    Anybody ???
    Nothing more than an index'd variable.
    (not code below...)
    If loopcount = 1 then the following two lines are equivalent
    -DutyVars(1) = 50
    -loopcount = 1 : DutyVars(loopcount) = 50
    At least I think that's what you were asking about.
    If that's what you were asking, the book explanation is in Chapter 4.5 of the manual...if not...whoops! My bad
    OK, so dutyvars is an array holding the changing value loopcount and that = 50 ? This really is Fuzzy . . .
     label VAR size[number of elements]
    label = DutyVar
    size = Loopcount
    what does = 50 do exactly?
    Does it give you a 16 byte array all having the value of 50?
    Sep 2007
    Hi Joe,
    50 would be the duty cycle of the PWM. In this example the SPWM_INT duty cycle was setup to be 0 - 100 so 50 would be roughly 50% at 100 Hz. See Below
    DEFINE SPWM_FREQ 100 ; SPWM Frequency = 100 Hz
    DEFINE SPWM_RES 101 ; SPWM Resolution = 0-100
    Best Regards,
    Kurt A. Kroh
    KrohTech
    Hi Joe,
    Hi Kurt,
    I understood what the 50 stands for, but not what the array does or how it does it, does it set all PWM outputs to 50 % ? I am thinking that is what it does.
    JS
    Sep 2007
    Hi Kurt,
    JS
    Hi Joe,
    Yse in this example it does set all 16 channels to 50.
    Best Regards,
    Kurt A. Kroh
    KrohTech
    Feb 2008
    Michigan, USA
    Default Why res of 101?
    Hi Kurt, (and all)
    In post #10, you mentioned that you used a different PWM resolution of 101 instead of 100. Can you expand on that a bit? I'm working on something similar and would like to understand why that helps.
    "here is my current code, changed to 101 PWM resolution to reduce overhead"
    Mark
    Feb 2008
    Michigan, USA
    Just wondering if anyone knew why that resolution of 101? Kurt must have missed my question.
    Mark
  1. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 20:02
  2. DT Instant Interrupts help
    By perides in forum mel PIC BASIC Pro
    Last Post: - 26th November 2008, 18:41
  3. 12F683 and DT Instant Interrupts
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2008, 12:47
  4. 18F1220 and DT Instant Interrupts
    Last Post: - 30th June 2008, 05:37
  5. Replies: 1
    Last Post: - 1st November 2006, 03:11
