DT Instant Interrupts
Results 1 to 39 of 39
    Quote Originally Posted by krohtech View Post
    I need a system LED that just blinks at a constant speed like 4 times a second. to show that the pic is working.
      ... and ...
    Oh, sorry I forgou to mention I am using an 18F PIC. ...
    I'm thinking just the Blinky example is all you need.
    DT_INTS-18 (Blinky Light)
    http://darreltaylor.com/DT_INTS-18/blinky.html
    Or, even better ...
    DT_INTS-18 (Assembly Language Interrupts)
    http://darreltaylor.com/DT_INTS-18/asm_ints.html
    Same Blinky LED, without the Basic Language Interrupt overhead.
    And no running Colon's
    Sep 2007
    Yes, this is the code I am using but I can't get it working in the same program as the multi SPWM. I am useing multi SPWM for my 8 pwm dimmers.
    Also I have played with the prescaler to slow down the blink rate but have had no sucess. is there a formula for this like in the -14 version?
    I will also make an attempt to digest Skymask's timer 0 overflow interrupt handler in the morning.
    Thanks Darrel and Skymask. You are both very helpful.
    Best Regards,
    Kurt A. Kroh
    KrohTech
    “Goodbye and thanks for all the fish”
    The original SPWM will not work with Instant Interrupts.
    They both want complete control of the interrupts. (can't happen)
    However, SPWM_INT will work with Instant Interrupts.
    And yes, the version shown in the -14 section will work on the 18F's too.
    DT_INTS-14 (SPWM_INT - Multiple Software PWM)
    http://darreltaylor.com/DT_INTS-14/SPWM.html
    SPWM_INT uses Timer1, so if you also want a Blinky light, you'll need to use a different Timer. (0, 2 or 3)
    And if you want to use either of the SPWM versions, then you can't use skimask's code.
    They are not compatible with ON INTERRUPT.
    And if you want my opinion (nobody really does, but that's beside the point), you'd do real good to learn how to use DT's Instant Interrupt's instead of relying on PBP's On Interrupt.
    It's not only good coding with good applications, you just plain learn a lot in the process...and then you spend more money and more time on PICs and PBP and less time on...well, wait a minute...gotta eat sometime...right?
    Sep 2007
    I have SPWM_INT working really well. I am doing 16 ch of PWM on a pic 18F2410 32 MHz. The pwm is running at 100Hz 8 bit resolution.
    Here is where I am having trouble. I tried to add a blinky from the DT_INTS-18 example and change it to timer0 with no success. Darrel, can you point me in the correct direction?
    Best Regards,
    Kurt A. Kroh
    KrohTech
    Sep 2007
    here is my current code, changed to 101 PWM resolution to reduce overhead
    '-----------------------------SPWM INT-----------------------------
    CLEAR
    INCLUDE "DT_INTS-18.bas"            ; Base Interrupt System
    INCLUDE "SPWM_INT.bas"              ; Software PWM module
    INCLUDE "ReEnterPBP-18.bas"    ; Include if using PBP interrupts
    LED2 VAR PORTA.5
    DEFINE SPWM_FREQ  100                ; SPWM Frequency
    DEFINE SPWM_RES   101               ; SPWM Resolution
    DutyVars   VAR BYTE[16]              ; DutyCycle Variables
      DutyVar1 VAR DutyVars[0]          ; group them in an array for easy access
      DutyVar2 VAR DutyVars[1]          ; with FOR loops etc.
      DutyVar3 VAR DutyVars[2]
      DutyVar4 VAR DutyVars[3]
      DutyVar5 VAR DutyVars[4]
      DutyVar6 VAR DutyVars[5]
      DutyVar7 VAR DutyVars[6]
      DutyVar8 VAR DutyVars[7]
      DutyVar9 VAR DutyVars[8]
      DutyVar10 VAR DutyVars[9]
      DutyVar11 VAR DutyVars[10]
      DutyVar12 VAR DutyVars[11]
      DutyVar13 VAR DutyVars[12]
      DutyVar14 VAR DutyVars[13]
      DutyVar15 VAR DutyVars[14]
      DutyVar16 VAR DutyVars[15]
    SPWM_LIST  macro                    ; Define Pin's to use for SPWM
         SPWM_PIN  PORTB, 0, _DutyVar1  ; and the associated DutyCycle variables
         SPWM_PIN  PORTB, 1, _DutyVar2  ; Notice the underscore before variables
         SPWM_PIN  PORTB, 2, _DutyVar3
         SPWM_PIN  PORTB, 3, _DutyVar4
         SPWM_PIN  PORTB, 4, _DutyVar5
         SPWM_PIN  PORTB, 5, _DutyVar6
         SPWM_PIN  PORTB, 6, _DutyVar7
         SPWM_PIN  PORTB, 7, _DutyVar8
         SPWM_PIN  PORTC, 0, _DutyVar9
         SPWM_PIN  PORTC, 1, _DutyVar10
         SPWM_PIN  PORTC, 2, _DutyVar11
         SPWM_PIN  PORTC, 3, _DutyVar12
         SPWM_PIN  PORTC, 4, _DutyVar13
         SPWM_PIN  PORTC, 5, _DutyVar14
         SPWM_PIN  PORTC, 6, _DutyVar15
         SPWM_PIN  PORTC, 7, _DutyVar16
      SPWM_INIT  SPWM_LIST              ; Initialize the Pins
            INT_Handler   TMR1_INT,  SPWMhandler,  ASM,  yes
            INT_Handler   TMR0_INT,  _ToggleLED2,  PBP,  yes
        INT_CREATE                      ; Creates the interrupt processor
    T0CON = %10010010             ; T0 = 16-bit, Prescaler 8
    @ INT_ENABLE  TMR1_INT        ; enable Timer 1 interrupts
    @ INT_ENABLE  TMR0_INT        ; enable Timer 0 interrupts
    '-----------------------------Main Program-----------------------------
    Best Regards,
    Kurt A. Kroh
    KrohTech
    I think the Cut&Paste didn't catch everything.
    Can you post the Main: and Handler parts?
    Thanks.
    OH!, nevermind!
    ADCON1 = $0F
  1. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 21:02
  2. DT Instant Interrupts help
    By perides in forum mel PIC BASIC Pro
    Last Post: - 26th November 2008, 19:41
  3. 12F683 and DT Instant Interrupts
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2008, 13:47
  4. 18F1220 and DT Instant Interrupts
    Last Post: - 30th June 2008, 06:37
  5. Replies: 1
    Last Post: - 1st November 2006, 04:11
