DT Instant Interrupts
Results 1 to 39 of 39
    Hi Darrel,
    could you please explain DutyVars(LoopCount) = 50 ; 50% (0-100), I understand the counter loop but do not understand the operation here. Thank You
    JS
    Anybody ???
    Anybody ???
    Nothing more than an index'd variable.
    (not code below...)
    If loopcount = 1 then the following two lines are equivalent
    -DutyVars(1) = 50
    -loopcount = 1 : DutyVars(loopcount) = 50
    At least I think that's what you were asking about.
    If that's what you were asking, the book explanation is in Chapter 4.5 of the manual...if not...whoops! My bad
    OK, so dutyvars is an array holding the changing value loopcount and that = 50 ? This really is Fuzzy . . .
     label VAR size[number of elements]
    label = DutyVar
    size = Loopcount
    what does = 50 do exactly?
    Does it give you a 16 byte array all having the value of 50?
    Sep 2007
    Hi Joe,
    50 would be the duty cycle of the PWM. In this example the SPWM_INT duty cycle was setup to be 0 - 100 so 50 would be roughly 50% at 100 Hz. See Below
    DEFINE SPWM_FREQ 100 ; SPWM Frequency = 100 Hz
    DEFINE SPWM_RES 101 ; SPWM Resolution = 0-100
    Best Regards,
    Kurt A. Kroh
    KrohTech
    “Goodbye and thanks for all the fish”
    Quote Originally Posted by krohtech View Post
    Hi Joe,
    Hi Kurt,
    I understood what the 50 stands for, but not what the array does or how it does it, does it set all PWM outputs to 50 % ? I am thinking that is what it does.
    JS
    Sep 2007
    Hi Kurt,
    JS
    Hi Joe,
    Yse in this example it does set all 16 channels to 50.
    Best Regards,
    Kurt A. Kroh
    KrohTech
    Feb 2008
    Michigan, USA
    Default Why res of 101?
    Hi Kurt, (and all)
    In post #10, you mentioned that you used a different PWM resolution of 101 instead of 100. Can you expand on that a bit? I'm working on something similar and would like to understand why that helps.
    "here is my current code, changed to 101 PWM resolution to reduce overhead"
    Mark
  1. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 21:02
  2. DT Instant Interrupts help
    By perides in forum mel PIC BASIC Pro
    Last Post: - 26th November 2008, 19:41
  3. 12F683 and DT Instant Interrupts
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2008, 13:47
  4. 18F1220 and DT Instant Interrupts
    Last Post: - 30th June 2008, 06:37
  5. Replies: 1
    Last Post: - 1st November 2006, 04:11
