DT Instant Interrupts
Results 1 to 39 of 39
    Thumbs up
    Great Testimonial Kurt!
    Mind if I use it on my website?
    Sep 2007
    Darrel,
    Feel free to use my testimonial in any way you see fit.
    Best Regards,
    Kurt A. Kroh
    KrohTech
    “Goodbye and thanks for all the fish”
    Thanks Kurt!
    Ioannis,
    I've mentioned it a couple times here in the forum, but I just spent about an hour trying to find them, and failed.
    I really should write some more pages for the website.
    Anyone got a Cloning Machine? I need another Me.
    Sep 2007
    Hay Darrel,
    In the DT_INTS-14 (SPWM_INT - Multiple Software PWM) It says:
    DutyVars   VAR BYTE[3]              ; DutyCycle Variables
      DutyVar1 VAR DutyVars[0]          ; group them in an array for easy access
      DutyVar2 VAR DutyVars[1]          ; with FOR loops etc.
      DutyVar3 VAR DutyVars[2]
    I do not know how to use arrays or how it can benefit in loops. The way I am doing it now is very cumbersome and code intensive. I have searched the forum and RTFM but I can't get my head around how this concept. Can anyone point me in the correct direction.
    Best Regards,
    Kurt A. Kroh
    KrohTech
    Default Simple example ...
    If you wanted to set all LED's to the same brightness, you could ...
    LoopCount  VAR BYTE
    FOR LoopCount = 0 to 15         ; 16 channels
        DutyVars(LoopCount) = 50    ; 50% (0-100)
    NEXT LoopCount
    LoopCount  VAR BYTE
    NEXT LoopCount
    Hi Darrel,
    could you please explain DutyVars(LoopCount) = 50 ; 50% (0-100), I understand the counter loop but do not understand the operation here. Thank You
    JS
    Sep 2007
    Hi Derrel,
    Thanks for the code, Unfortunately I was hoping for something that would allow me to set different values to the duty cycle of each channel. The way I have it configured I use CH# as the var name:
    DEFINE SPWM_FREQ  100               ; SPWM Frequency
    DEFINE SPWM_RES   101               ; SPWM Resolution
    DutyVars   VAR BYTE[16]             ; DutyCycle Variables
      CH1 VAR DutyVars[0]          ; group them in an array for easy access
      CH2 VAR DutyVars[1]          ; with FOR loops etc.
      CH3 VAR DutyVars[2]
      CH4 VAR DutyVars[3]
      CH5 VAR DutyVars[4]
      CH6 VAR DutyVars[5]
      CH7 VAR DutyVars[6]
      CH8 VAR DutyVars[7]
      CH9 VAR DutyVars[8]
      CH10 VAR DutyVars[9]
      CH11 VAR DutyVars[10]
      CH12 VAR DutyVars[11]
      CH13 VAR DutyVars[12]
      CH14 VAR DutyVars[13]
      CH15 VAR DutyVars[14]
      CH16 VAR DutyVars[15]
    and change the duty in this manor:
    gosub CKINPUT
    CH1 = 100
    CH2 = 0
    CH3 = 0
    CH4 = 0
    CH5 = 0
    CH6 = 0
    CH7 = 0
    CH8 = 0
    CH9 = 0
    CH10 = 0
    CH11 = 0
    CH12 = 0
    CH13 = 0
    CH14 = 0
    CH15 = 0
    CH16 = 0
    gosub CKINPUT
    PAUSE T5
    CH1 = 100
    CH2 = 100
    CH3 = 0
    CH4 = 0
    CH5 = 0
    CH6 = 0
    CH7 = 0
    CH8 = 0
    CH9 = 0
    CH10 = 0
    CH11 = 0
    CH12 = 0
    CH13 = 0
    CH14 = 0
    CH15 = 0
    CH16 = 0
    gosub CKINPUT
    PAUSE T5
    and so on... If anyone can suggest a better method I would be very interested in learning better ways to program.
    Best Regards,
    Kurt A. Kroh
    KrohTech
    Hi Darrel,
    JS
    Anybody ???
  1. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 21:02
  2. DT Instant Interrupts help
    By perides in forum mel PIC BASIC Pro
    Last Post: - 26th November 2008, 19:41
  3. 12F683 and DT Instant Interrupts
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2008, 13:47
  4. 18F1220 and DT Instant Interrupts
    Last Post: - 30th June 2008, 06:37
  5. Replies: 1
    Last Post: - 1st November 2006, 04:11
