DT Instant Interrupts
Results 1 to 39 of 39
    OH!, nevermind!
    ADCON1 = $0F
    Sep 2007
    Thanks Darrel,
    That worked, I think I need to learn that register, TIME TO HIT THE DATA SHEET...
    Best Regards,
    Kurt A. Kroh
    KrohTech
    “Goodbye and thanks for all the fish”
    Thumbs up
    That's a good one to learn.
    You'll need some variation of it in almost every program you write.
    Also, Since the TMR0_INT handler is only toggling a pin, it's not using any PBP system variables.
    You can change the TMR0_INT's "Type" to ASM.
    Then it won't be saving all the system variables when it doesn't need to. Time is critical with that many simultaneous PWM's.
    Then you can remove the ReEnterPBP-18.bas include file, which will save some RAM and Code space.
    Sep 2007
    Thanks again Darrel,
    I just fully tested the SPWM_INT running 16 channels @ 100Hz 0-100 resolution. I tested each channel with a 7 amp led cluster (Agilight Brightstrip see below) of typical sign led strips powered through a MOSFET. This worked great. I am able to dim all the way down to 1% without any flicker and smoothly fade up to 100% with no flicker or noticeable stair stepping effect. This is smoother than when I used the older multi SPWM program.
    I really appreciate you help
    http://www.agilight.com/brightstrip/index.htm
    Best Regards,
    Kurt A. Kroh
    KrohTech
    Thumbs up
    Great Testimonial Kurt!
    Mind if I use it on my website?
    Sep 2007
    Darrel,
    Feel free to use my testimonial in any way you see fit.
    Best Regards,
    Kurt A. Kroh
    KrohTech
    Thanks Kurt!
    Ioannis,
    I've mentioned it a couple times here in the forum, but I just spent about an hour trying to find them, and failed.
    I really should write some more pages for the website.
    Anyone got a Cloning Machine? I need another Me.
    I may missed that little but critical details. Are these described somewhere Darrel?
    And may be others too that I am not aware off...
  1. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 21:02
  2. DT Instant Interrupts help
    By perides in forum mel PIC BASIC Pro
    Last Post: - 26th November 2008, 19:41
  3. 12F683 and DT Instant Interrupts
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2008, 13:47
  4. 18F1220 and DT Instant Interrupts
    Last Post: - 30th June 2008, 06:37
  5. Replies: 1
    Last Post: - 1st November 2006, 04:11
