P16F1827 and LCD Problems
Results 1 to 29 of 29
    Hello BobW
    About "your" MikroC Pro program ...
    1) are you sure it has been written ( by you ??? ) for a '1827
    2) did you create a project ??? ( the " module " error comes from here )
    once " trimmed " it gives :
    0 1 mikroCPIC1618.exe -MSF -DBG -pP16F1827 -DL -O11111114 -fo8 -N"C:\Program Files\Mikroelektronika\mikroC PRO for PIC\Examples\tEST.mcppi" -SP"C:\Program Files\Mikroelektronika\mikroC PRO for PIC\defs\" -SP"C:\Program Files\Mikroelektronika\mikroC PRO for PIC\Uses\P16_Enh\" -SP"C:\Program Files\Mikroelektronika\mikroC PRO for PIC\Examples\" "tEST.c" "__Lib_Math.mcl" "__Lib_MathDouble.mcl" "__Lib_System.mcl" "__Lib_Delays.mcl" "__Lib_ADC.mcl" "__Lib_LcdConsts.mcl" "__Lib_Lcd.mcl"
    0 1139 Available RAM: 368 [bytes], Available ROM: 4096 [bytes]
    0 126 All files Preprocessed in 50 ms
    0 122 Compilation Started tEST.c
    63 123 Compiled Successfully tEST.c
    0 127 All files Compiled in 80 ms
    0 1144 Used RAM (bytes): 63 (17%) Free RAM (bytes): 305 (83%) Used RAM (bytes): 63 (17%) Free RAM (bytes): 305 (83%)
    0 1144 Used ROM (program words): 1198 (29%) Free ROM (program words): 2898 (71%) Used ROM (program words): 1198 (29%) Free ROM (program words): 2898 (71%)
    0 125 Project Linked Successfully tEST.mcppi
    0 128 Linked in 210 ms
    0 129 Project 'tEST.mcppi' completed: 451 ms
    0 103 Finished successfully: 30 janv. 2011, 18:02:00 tEST.mcppi
    1198 ROM .... should compile fine with the demo version, no ???
    [HUMOUR ON]
    How much with PBP ????
    nooooooo .... not on the head !!!
    With PBP, give or take a few:
    Program Memory Words Used: 285
    Program Memory Words Free: 3811
    Give or take a little. So, about 7%, compared to MicroC's 29% used.
    Now, this is not a fair comparison, because I don't know what MicroC's test program you are using, or what it does. PBP numbers are for just printing two variables to an LCD display.
    Now, this is not a fair comparison, because I don't know what MicroC's program is doing
    Hoooooo ...
    See #4
    Program just reads voltage on ADC channel 2 , prints a text on line one of the LCD and prints the ADC voltage in V.VVV format on the second line ... of course with the Unit !
    Comparison is not unfair at all as the shortest MkC Pro available way to display numbers is used here ...
    you had also noted the LONG type use for "calculations" ... unavoidable with MkC.
    I already made a comparison on this Forum and result was similar ...
    PBP and Proton were quite the same for the result.
    Dec 2010
    Michigan
    Talking
    I am not sure which program you are referring to?
    The one That gave me the display was written by me on a PIC16F88 using C.
    I gave up on the 16F1827 do to lack of programming knowledge and lack of sample programs for that chip. Now that I have a somewhat grasp on the basics, I have been able to read and display the ADC value of a pot, (will use that later to read 3 switches on one pin).
    It is all the PIC dependent declarations at the very beginning of the program that trip me up.
    Bob
    You have to crawl before you walk, and I am starting to crawl pretty well.
    Quote Originally Posted by Bobw55 View Post
    Without any further notice we all were on posts #1 and #3 ...
    Of course result was not exactly that expected with #3 program ...
    So, comes the killing question ...
    Did you notice we're aboard a PICBASIC PRO ( MeLabs brew ) forum, and we are supposed to "speak" Basic ???
    me too ...
    Dec 2010
    Michigan
    Yes I do know this is a BASIC forum.
    My post was only to thank those who were trying to help me get started.
    Bob
