P16F1827 and LCD Problems
Results 1 to 29 of 29
    Dec 2010
    Michigan
    Talking
    I only have the demo version which does NOT support the 16F1827.
    I have:
    MPLAB 8.63 PICKIT3
    MikroBasic
    MikroC-Pro
    MikroPro-Suite
    I found the Assembly template file for the 16F1827 and will start using that to build with.
    From my reading last night I figured out that I have to define or tell the program the pinout of the LCD to the PIC. Set the LCD for 4bit High nibble, then I can send the initialization string to it. (I think)
    My first goal is just to get it to Initialize.
    Second Print some text.
    Third read and display the value of a switch.
    I will do this, even if it takes a sledge hammer
    Dec 2010
    Michigan
    Default Getting there
    Managed to get some code written and displayed.
    THANK YOU ALL FOR THE POINTERS
    Bob
    Aug 2010
    Maryland, USA
    Awesome Bob!!
    -Bert
    Aug 2008
    Portugal
    Well Done Bob!
    Thanks and Regards;
    Gadelhas
    Now how about sharing it for humanity purpose
    Hello BobW
    About "your" MikroC Pro program ...
    1) are you sure it has been written ( by you ??? ) for a '1827
    2) did you create a project ??? ( the " module " error comes from here )
    once " trimmed " it gives :
    0 1 mikroCPIC1618.exe -MSF -DBG -pP16F1827 -DL -O11111114 -fo8 -N"C:\Program Files\Mikroelektronika\mikroC PRO for PIC\Examples\tEST.mcppi" -SP"C:\Program Files\Mikroelektronika\mikroC PRO for PIC\defs\" -SP"C:\Program Files\Mikroelektronika\mikroC PRO for PIC\Uses\P16_Enh\" -SP"C:\Program Files\Mikroelektronika\mikroC PRO for PIC\Examples\" "tEST.c" "__Lib_Math.mcl" "__Lib_MathDouble.mcl" "__Lib_System.mcl" "__Lib_Delays.mcl" "__Lib_ADC.mcl" "__Lib_LcdConsts.mcl" "__Lib_Lcd.mcl"
    0 1139 Available RAM: 368 [bytes], Available ROM: 4096 [bytes]
    0 126 All files Preprocessed in 50 ms
    0 122 Compilation Started tEST.c
    63 123 Compiled Successfully tEST.c
    0 127 All files Compiled in 80 ms
    0 1144 Used RAM (bytes): 63 (17%) Free RAM (bytes): 305 (83%) Used RAM (bytes): 63 (17%) Free RAM (bytes): 305 (83%)
    0 1144 Used ROM (program words): 1198 (29%) Free ROM (program words): 2898 (71%) Used ROM (program words): 1198 (29%) Free ROM (program words): 2898 (71%)
    0 125 Project Linked Successfully tEST.mcppi
    0 128 Linked in 210 ms
    0 129 Project 'tEST.mcppi' completed: 451 ms
    0 103 Finished successfully: 30 janv. 2011, 18:02:00 tEST.mcppi
    1198 ROM .... should compile fine with the demo version, no ???
    [HUMOUR ON]
    How much with PBP ????
    nooooooo .... not on the head !!!
    With PBP, give or take a few:
    Program Memory Words Used: 285
    Program Memory Words Free: 3811
    Give or take a little. So, about 7%, compared to MicroC's 29% used.
    Now, this is not a fair comparison, because I don't know what MicroC's test program you are using, or what it does. PBP numbers are for just printing two variables to an LCD display.
