# 20 updated to our friend's desires ...
hi, the code works fine under slow speed, it will count up to 3 and go off the led for 1 s, then on back again.
Please see actual code.
I need much faster reading from the pic, other wise, it will count moreto go off, on breadboard, it may not even go on again.Code:DEFINE OSC 4 cnt VAR BYTE delay var byte boton VAR GPIO.2 mosfet VAR GPIO.1 ' ANSEL = 0 '12F675 for test CMCON = 7 OPTION_REG.7 = 0 'Pullups enabled WPU = %00000100 cnt = 0 GPIO = %00000110 ' Nosurprise startup ... TRISIO = %00000100 '****************************************************************************** Detect: 'Button presses W/Debounce ' delay = 0 BUTTON Boton ,0,255,0,delay,1,pressed ' Slow Things down GOTO Detect '****************************************************************************** Pressed: ' Some > 10ms press detected IF cnt <=1 Then 'tocount uptu 3, bigger values will add up. cnt = cnt + 1 ELSE cnt = 0 LOW mosfet PAUSE 1000 high mosfet ENDIF WHILE !Boton : WEND ' Wait Boton release !!! goto detect END
For some oscure reason, my Pbasic compiler, does not like the configuration line you put, after the OSCAL SETTING, in line one.
So I have to set it manualy, using software configuration bit facility.
See my circuit, but, instead of 2 only one led, on GP1, and Push boton on GP2.
Best regards.
Thanks Acetronics.
Keep cool ... there's no miracle in that ...oooooomg!!!! you did it!!! it works!!!
If you need faster response ... forget about your pushbutton !!!Button bouncings will give a totally random functionning ...
another "detector" type has to be used.
Now, modified code reacts for 2 pushings only ???
The obscure reason is you use PM as an assembler and not MPASM with your Microcode IDE ...
Hi thanks for your response, much appreciated.
The compiler, i use is Pbasic?..with Mplab ide....these are at least the software names.
Do you need a screen capture of the compiling results?
And about the button...what type would you use?...I am absolutly clue less.....and desperate...and tyre...and bald....and...etc...
Any way....Ir sensors?...proximity switches?....
I once more depend on your wisdom master....![]()
Hi Ace,
Thanks for your reply.
The button is pressed by the piston on a gear box. As i said on other post, my actual reading is 15 to 20 cycles per sec. And i need to stop the piston, after 3 cycles.
I have some Ir sensors. But putting them inside the gearbox or some where around, it is not a good idea.
Hence, buttons is the best for my application i think.
Thanks.![]()
