Help with pic 12f629
Results 1 to 40 of 53
    You might not need the
    but it is a good idea to put it in. That is the line that tell PBP how fast the chip is running. I assume you are using the 4MHz internal.
    The state of the mosfet/led depends on how you have the hardware setup. Just change the LOW/HIGH around to do what you want.
    Like I said before. This will need a good denouncing routine to work correctly. Now that you say the button could be pressed at 20HZ even more so. What is going to press a button that fast?
    Here are a couple of threads that might help you.
    http://www.picbasic.co.uk/forum/showthread.php?t=13516
    http://www.picbasic.co.uk/forum/showthread.php?t=2180
    Read them all the way through.
    Sep 2010
    Hi dave,
    Thanks for your help, I will have a look at the links later.
    Yes you are right, I am using the internal oscillator at 4 mhz.
    The botton is pressed by a piston.
    So I need to stop the piston after 3 pulses.
    Thanks.
    Is it really a button type switch or some other kind of sensor?
    I ask because a mechanical switch may not be the best at high speeds.
    And the way you have the code implies the button is pulled high and at button press goes to zero volts. This can cause arcing as the contacts open giving the chance of several "make/breaks" on each press.
    If the switch were wired pulled low and pressing it brought it high then the arcing is almost not a problem.
    Just thoughts....
    Sep 2010
    Just thoughts....
    yes the idea is a proper botton switch, the wired to pull it low it is some thing that i dont understand.
    The voltage for the circuitry is 5v....amperes very little, I think is not going to be a problem.
    I am more concern with the switch being able to work at that speed...i dont know...i rather first understand the code, see what it should be, have something that i can built my proptotype on, and then see pros and cons.
    Otherwise this can be very long...
    Thanks for the help guys.
    Best regards.
    Aug 2010
    Maryland, USA
    Quote Originally Posted by gutisie View Post
    You should ALWAYS assume EVERY mechanical contact switch bounces. The effects can be made less with tricks like DAVE suggests, and with higher quality snap type switches. But heres the thing: as 1 contact approaches the other, they WILL arc. The arc is the "bounce" this happens when opening and closing. Also, switches HATE DC. So if you want this to work for any lengh of time, be certain the switch is DC rated. DC causes the contacts to "plate" and then the bounceing gets worse until the switch quits all together.
    Best regards.
    Not a bad approace at all. Good luck!
    -Bert
    # 20 updated to our friend's desires ...
    Sep 2010
    Talking
    oooooomg!!!! you did it!!! it works!!!
    but i had to change it a bit.
    I will post the results later
    I am still shaking....
    Exclamation
    Thanks.
    Some Hall effect sensor would be to consider, instead ...
    just me ...
