Help with pic 12f629
Results 1 to 40 of 53
    # 20 updated to our friend's desires ...
    Sep 2010
    Talking
    oooooomg!!!! you did it!!! it works!!!
    but i had to change it a bit.
    I will post the results later
    I am still shaking....
    Sep 2010
    Wink
    hi, the code works fine under slow speed, it will count up to 3 and go off the led for 1 s, then on back again.
    Please see actual code.
        cnt VAR BYTE
        delay var byte
        boton VAR GPIO.2
        mosfet VAR GPIO.1
     '   ANSEL           = 0     '12F675 for test
        CMCON           = 7
        OPTION_REG.7    = 0    'Pullups  enabled
        WPU             = %00000100
        cnt             = 0
        GPIO            = %00000110                 ' Nosurprise startup ...
        TRISIO          = %00000100
    Detect: 'Button presses W/Debounce
    delay = 0
    BUTTON Boton ,0,255,0,delay,1,pressed
                                      ' Slow Things down
        GOTO Detect
    Pressed:  ' Some > 10ms press detected
        IF cnt <=1  Then 'tocount uptu 3, bigger values will add up.
            cnt = cnt + 1
            cnt = 0
            LOW mosfet
            PAUSE 1000
            high mosfet
    WHILE !Boton : WEND                                ' Wait Boton release !!!
    goto detect
    I need much faster reading from the pic, other wise, it will count moreto go off, on breadboard, it may not even go on again.
    For some oscure reason, my Pbasic compiler, does not like the configuration line you put, after the OSCAL SETTING, in line one.
    So I have to set it manualy, using software configuration bit facility.
    See my circuit, but, instead of 2 only one led, on GP1, and Push boton on GP2.
    Best regards.
    Thanks Acetronics.
    Keep cool ... there's no miracle in that ...
    If you need faster response ... forget about your pushbutton !!! Button bouncings will give a totally random functionning ...
    another "detector" type has to be used.
    Now, modified code reacts for 2 pushings only ???
    The obscure reason is you use PM as an assembler and not MPASM with your Microcode IDE ...
    Sep 2010
    Talking
    Hi thanks for your response, much appreciated.
    The compiler, i use is Pbasic?..with Mplab ide....these are at least the software names.
    Do you need a screen capture of the compiling results?
    And about the button...what type would you use?...I am absolutly clue less.....and desperate...and tyre...and bald....and...etc...
    Any way....Ir sensors?...proximity switches?....
    I once more depend on your wisdom master....
    Some testings show the minimum time for 3 pushes is ... around 78 ms !!! @ 10ms debounce time and a Pause 0 for scanning ...
    so, I really doubt any finger could do that !!!
    Quote Originally Posted by gutisie View Post
    so What moves the button ???
    Sep 2010
    Hi Ace,
    Thanks for your reply.
    The button is pressed by the piston on a gear box. As i said on other post, my actual reading is 15 to 20 cycles per sec. And i need to stop the piston, after 3 cycles.
    I have some Ir sensors. But putting them inside the gearbox or some where around, it is not a good idea.
    Hence, buttons is the best for my application i think.
    Thanks.
